Question about Philips Audio Players & Recorders
Philips DVD player not working connected to Onida TV.
As my Philips DVD player is not working, I want to integrate Philips 5.1 DVD player to Onida TV 21” Black. I have rechecked connection to the between TV & DVD player as per user manual. Some times I am getting the electric shock in new DVD player once connected to Onida TV.
Please let me know how to integrate both of them
Regards,
Rajesh MR
SOURCE: configuration
IWANT TO COMPLETE INSTALATION TO 24 PORT MANAGABLE SWICTH WITH DEMO
Posted on May 16, 2008
SOURCE: 'SHARP LC 26SH12U' & Philps DVP 5160
sounds like you are using standard audio/video cables (yellow, blk., wht) in the component conections on either the tv, vcr or dvd player. If you intend on using component connection you will need to use different cables.
Posted on May 27, 2008
SOURCE: Movie playing black and white
the problem sounds like its with the s video connection, try using the composite video input
Posted on Jun 05, 2008
  • 34 Answers
SOURCE: connect tv vcr and dvd player to digital converter box
Yes you can first connect the converter box to the antenna first. Next hook the tv out on converter box to vcr in on vcr. Next hook the vcr out to the tv in and watch vcr and converter box on channel 3 sometimes channel 4.on the actual tv and of course change channels with converter box remote. For dvd player hook it straight to tv with red,white,and yellow cables that come with your dvd player. Then to watch dvd player if it's hooked up that way you have to put your tv on a input like video 1 or input 1. This can be done by using the tv remote and looking for a button that says tv/video or input or source button. This is some common names for that button on tv remotes.
Posted on Nov 08, 2008
SOURCE: How to restore factory settings for Coby 755 DVD Player
how do i program my dvd player with a universal remote?
Posted on Nov 11, 2008
I had onida black 300 TV. when i attach DVD player Display is not coming only audio is coming. what to do please answer me
Try to check the connection or cables that connecting your dvd and tv. There may be a loosed connection or or damage plugs.Try to replace a new wire or cable connectors.
Jul 13, 2011 | Televison & Video
Unable to connect DVD player in onida tv
check to see if rca wire is connect each other. dvd video out to tv video in. be sure tv is in video mode
Feb 06, 2011 | Televison & Video
How can i hook up my player to my tv with no rca inputs
There are adaptors. I bought a Philips brand that allows any dvd player to be connected to any television. You connect the RCA cables to the Philips adaptor from the DVD player then you connect the Philips adaptor to the rf input of the television with a coaxial cable.
Nov 07, 2010 | Mintek DVD-2580 DVD Player
Integrating MAC with Philips TV & DVD Player to BOSE Companion 5
The best option here is to use your TV as a secondary monitor for your iMac. Doing so would require the correct type of connector in your case a mini-DVI to HDMI connector.
Once it is connected, you have three options - you can have it mirror what's going on on your iMac's display, have it act as extra monitor 'real estate' - that is to say extra space that you can drag windows onto and so on - or you can have the TV act as your primary monitor.
All of these options can be changed when your TV is connected through Apple menu > System Preferences > Display > Arrangement.
You don't really need to worry about the DVD player on the TV as the Mac OS has a DVD player application built into it. You can use it or the TV's DVD player, it's really up to you.
As for connecting both of them to the same speaker system, you should be able to purchase a connector that will go from the audio out port of your TV to the audio in on the back of your iMac. You would then be able to select the TV's output in Apple menu > system preferences > sound > input.
Jun 06, 2010 | Apple iMac 24" Desktop
ONIDA DFX-7100 DVD player unable to play VCD/CD
dvd player s-video pin use to tv tuner card
May 18, 2010 | Televison & Video
Philips DVD connected to SET TOP Box with W/R/Y cables. DVD connected to Philips TV via HDMI. Turn on DVD and TV screen says "Format Not Supported"? Help
Change the video resolution format from HDMI set up menu. This way you can know that if Player and TV supports/displays any one or some of the resolutions and if you can get a video on TV.
Jan 05, 2010 | Philips DVP3982 DVD Player
Connect philips dvdr80 to intigrated freeview tv
Solved the problem by connecting the freeview box back into the dvd recorder. Apparently because the dvdr was made before tvs with integrated freeview, it can only recieve decoded signals from a freeview box, ie analog
Jan 16, 2009 | Philips DVDR80 DVD Recorder
Unlock region code for Philips DVP 3256
Region code hack for PHILIPS 3256 x/94
1. Go to Setup. [from remote]
2. Select the Preference Page.
3. Press 1, 3, 8, 9, 3, 1 on the Philips DVD Player remote.
--> It will show current region code [ for example 5 ]
4. Now Press the up/down key to select "0" which makes it region free.
5. Press ok and exit setup.
Probably the same would be applicable for 3258, 3268, 3986.
Good Luck!
Jan 02, 2009 | Philips DVD625 DVD Player
I need the universal code for my bush dvd player?
TRY THIS. It works on my Philips DVD player: To make some DVD players play disks from different regions. 1. Connect DVD to TV ensuring both are then switched on. 2. Press "OPEN/CLOSE" button on DVD player. 3. Enter "8421" using remote control. 4. While watching TV screen repeatedly press "Select" on remote control until region 9 is reached.  5. Press "OPEN/CLOSE".
Dec 18, 2008 | Televison & Video
Getting dvd player to work
OK from your DVD player connect the Composite video output jack of the DVD player marked in yellow to the composite video in of the TV. The connect the audio output (red and white) to the audio input of the TV. Then set the TV to connect to the composite port should have at least AUX1.
Oct 09, 2007 | Philips DVP5140 DVD Player
124 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
