Question about HP G60-230US Notebook
Wireless fails to come on when switched on - HP G60-230US Notebook
  • Aaron Fox
    Aaron Fox May 11, 2010
    Does the light turn blue or does it stay orange?
Goto Start menu, Control Panel, Administrative Tools, select Services. Scroll down to and click Wireless Zero Configuration, Then click Start the service.
Posted on Aug 02, 2009
The blutooth stack is download and install but "i activate the keys the key is fn + f11 then where is a radio on off switch pls tell me where is radio on off switch ? pls".
nitin m patil,
Wireless Switch
Wireless Technology
  1. The Vostro 1510 system ships with a wireless feature called the wireless switch. It is located on the left side of the system next to the ExpressCard slot. This switch serves to dectivate or activate the wireless antenna.
Wireless Switch LED Settings
The LED (located on the Hinge Cover) on the wireless switch works only when the system is powered on. A user can activate the switch and have it scan for networks only after going through a complete boot process. The switch is used to detect only wireless signals. This setting is in the BIOS under the Wireless section.
The LED indicates the following functionality:
  • Solid Blue - The system has detected a wireless signal.
  • Off - The system failed to detect a wireless device installed.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Aug 17, 2013 | Dell Vostro 1510 Laptop
Tip
How to turn on the wireless switch on your Dell notebook computer The first...
The first thing you need to do is locate your wireless switch. It is normally located on the left hand side of your notebook computer.
Next examine the switch to make sure that it is in the middle in the On Position. See the picture below. Note a common issue that will happen is when taking your notebook in and out of your bag that the switch with get knocked into the Off Position.
dc3cc28.pngIn regards to the Momentary Position this for the Wi-Fi Catcher. If you have you already have wireless networks configured and you are in range of the networks the computer will automatically connect to the network. Note this has to be setup through the Dell QuickSet utilities for Wi-Fi network connections.
Below listed are the different color indicators for the Wireless Activity Indicator
Flashing green - The system is searching for a signal.
Green - The system has detected a wireless signal and has good strength.
Yellow - The system has detected a wireless signal, but it is moderate to weak in strength.
Red - The system failed to detect a wireless signal, or the wireless signal is extremely weak.
on Sep 23, 2010 | Computers & Internet
My wireless won't connect to the internet. The switch is on. The laptop can connect when I use a cable.
Try downloading the latest drivers from Toshibas site
If that fails, open the base of the laptop (should be a cover there), check that the wireless card is installed and the two wires that attach on push posts are present and attached. One is black (main) the other white (aux).
In device manager, check that the wireless hardware is detected, if it is not seen and the card is presnt and connected, the wireless controller has failed, or the card itself is damaged and will need replacing.
Jan 30, 2011 | Toshiba L305-S5955 Notebook
CANNOT SWITCH THE WIRELESS ON...ITS A INSPIRON 6000
Have you tried "Fn+F2" (both keys together) by any chance? If that still fails, you might need to check if you have the proper wireless card driver installed (can download the latest Dell wireless drivers from their website)
Aug 06, 2010 | Dell Inspiron 6000 Notebook
My f8 key does not switch on wireless where is location of switch
check the front of your machine, there should be a little button for the wireless connection. Go to page 4 of this short technical
Failing that usually the F# numbers need another key pressed, usually called the Function (Fn) key
Dec 10, 2009 | Toshiba Satellite L10 Notebook
MC7090 showing WIFI unavailable
Check that the radio is switch on. This can be either done Using the wireless manager or by clicking teh radio symbol with red cross and and then [Enable Radio].
Failing that try a warm boot.
Failing that try a cold boot.
Failing that try reinstalling the operating system.
If that doesn't work contact us and we'll see what we can do.
www.biastechnology.com
helpdesk@biastechnology.com
Aug 27, 2009 | Symbol MC9090 Barcode Scanner
I CANT GET CONNECTED TO BT HUB
have you typed the key exactly? viz uppercase/lowercase. The switch(hub) might have MAC address filtering on. also check if the switch(hub) has a DHCP running, which allocates IP addresses, if not you need to set your wireless connections IP address within the same range as the switch. If all else fails attempt to connect the switch via a utp network cable which should have been suplied with the switch(hub) so you can access the switch and make the necessary changes... email me on djtracer@vodamail.co.za should you need more info.
Aug 11, 2009 | Computers & Internet
Wireless Connection fails. Gone through many troubleshootings.
these devices build up static electricity. Just unplug the router for 10 seconds and replug in and all will be good
Jul 10, 2009 | Sony VAIO VGN-SZ491N/X Notebook
My wireless light on my hp g6000 notebook stays orange when switched on instead of going blue.And the wireless won't work
My only solution was to send my laptop back to HP for repair - turns out the light means that the on board wireless has failed
Aug 24, 2008 | Computers & Internet
Belkin 2-port kvm switch
mcdevito75 here, You can try to contact Belkin itself, but with-in the 2 years you had wireless, many more users of different computers, and satalites that the wireless needs have also changed.
Jun 01, 2008 | Belkin F1DK102P 2-port KVM Switch
HP G60-230US Notebook Logo
76 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
