Question about Nintendo Wii Console
My wii has power but doesnt turn on or eject the disc. but i put it in front of a radiant heater (carefully) and warmed it up and it worked, is this a temperature problem? and sometimes it doesnt play some slightly scratched discs.
  • 56 Answers
Mama Mia (Again) Get A New Wii For Christmas . You Run And Get Your Homephone Or Cellphone And Call This Number: 1-800-255-3700. Well Is The Disc Jammed Through The Nintendo Wii
Posted on Jul 16, 2009
Disc will not eject
Turn the Wii off and on again after about 20 seconds. Press the eject button again.
Unplug the Wii's AC power supply if Step 1 doesn't work. Wait 1 to 2 minutes, and trying to eject the disc again after turning the Wii back on.
Hold down the eject button for 5 to 10 seconds
Try ejecting the disc with the Wii at different angles. If you hold the Wii upside down, it may help the disc fall out.
Call Nintendo and send the Wii back if non of these steps work. In most cases, a disc stuck in the Wii should be covered by warranty.
Nintendo says to see if power light was coming on, AC adapter reset. unplug from both ends for 90 seconds.Hold eject button for five or 10 seconds.
Aug 22, 2010 | Nintendo Wii Console
My wii doesnt work ****
Why ?
Doesnt read disc ? NEW LASER
Doesnt power on ? New Power Supply ?
If you did a software modification and updated ? NEW MOTHERBOARD
Visit www.repaircentral.com.au for more details
Mar 06, 2010 | Nintendo Wii Console
An error has occurred please press the eject button and remove the disk. turn the wii console off and...
clean the whole system not just the lens it probley is to dusty in the system. you can also try to remove the power source from the back of the system not the wall wait a min or 2 plug it back in turn it on with out the disc in it and go to the load screen where it says start put the disc in and click start. but i suggest you take it in for a cleaning at a small local game store they usuall dont charge if they dont have to do anything but dust it out. if that still fails then you most likly need a new cd drive.
Aug 22, 2009 | Nintendo Wii Console
Wii Fit disk will not eject
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
aqwtr-101
Jun 13, 2009 | Nintendo Wii Console
I can't my Disc to eject from my Wii Console. Does anyone have a solution to this problem, other than taking it in for service?
Try all of these steps:
1. Turn the Wii off and on again after about 20 seconds. Press the eject button again. If no help:
2. Unplug the Wii's AC power supply if Step 1 doesn't work. Wait 1 to 2 minutes, and trying to eject the disc again after turning the Wii back on. If no help: 3. Hold down the eject button for 5 to 10 seconds. Still not: 4. Try ejecting the disc with the Wii at different angles. If you hold the Wii upside down, it may help the disc fall out. if no help: 5. See if power light was coming on and do the AC adapter reset. unplug from both ends for 90 seconds.Hold eject button for 5-10 seconds Finally: Call Nintendo 1-800-255-3700 and send the Wii back if non of these steps work. In most cases, a disc stuck in the Wii should be covered by warranty. Good Luck
Mar 03, 2009 | Nintendo Wii Console
Ejecting Wii disc while power is off
Your disc is stuck in Wii Console, It needs to eject manually. You might check out Wii Fix Guide, that gives step by step information on Dis-Assembling with screenshots, even a novice can fix the disc eject problem with the help of this DIY Guide. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Jan 29, 2009 | Nintendo Wii Console
Game stuck in console
Try thees steps
Turn the Wii.html#" target=_blank itxtdid="7750962">Wii off and on again after about 20 seconds. Press the eject button again. 2
Unplug the Wii's AC power supply if Step 1 doesn't work. Wait 1 to 2 minutes, and trying to eject the disc again after turning the Wii back on. Hold down the eject button for 5 to 10 seconds. 4Try ejecting the disc with the Wii at different angles. If you hold the Wii upside down, it may help the disc fall out. 5Call Wii.html#" target=_blank itxtdid="7751052">Nintendo and send the Wii back if non of these steps work. In most cases, a disc stuck in the Wii should be covered by warranty. Nintendo says to see if power light was coming on, AC adapter reset. unplug from both ends for 90 seconds.Hold eject button for five or 10 seconds Good Luck
Jan 23, 2009 | Nintendo Wii Console
Not accepting discs on wii
make sure the front of the disc is facing the right if it still doesnt work then try cleaning the disc and try again
Oct 13, 2008 | Video Game Consoles & Games
Cd stuck
Well, Recently the same thing happened to me, My bro dropped my WII on the floor and the eject button on it got stuck i was soo mad!!!
I tried loads of ways nothing really hard, just follow this and hope fully the WII will eject:
1.Make sure the WII is stood up properly.
2.Then switch on the WII (As i said early the WII won't eject the CD.
3.Now look near the eject button if it is stuck follow (A) or if not coming out follow (B).
(A1).Right if it is stuck and not coming out then the top bendy bit of the eject button put your nail through it and press it down it should eject but after a while it did not work any more for me :(.
(A2).Now, Disconnect all the Cable's in the WII not TV leave it for a while (and don't smash it again!), After a while approx 5 Min's plug 'em back in, switch on the WII then press eject hopefully that will work :D.
(B1).Now if it does not come out either look inside the drive or WII (I don't suggest that) or just do what i did with A2 hopefully that will work.
Hope your WII works by now and enjoy ejecting cd's from your WII but 1 more thing before you go (DON'T BREAK YOUR WII AGAIN OR YOU WILL HAVE TO DO THIS ALL OVER AGAIN :P AND IT MIGHT NOT EVEN WORK IF SMASH IT TO MANY TIMES!!! SO BE-CAREFUL!!!!
Sep 30, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
142 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
