Question about Panasonic PT-51HX40 51" Rear Projection Television
Diagnostic Mode? The following appeared on my screen (upper right) last night: "CHK" followed by a long string of alpha and numeric digits. Someone told me the TV is probably in its diagnostic mode. How do i get it out of the diagnostic mode?
  • Fred Cooke Nov 21, 2007
    The following appears on the screen last two weeks ago "CHKOF1FO OOOOOOOO. WHAT IS THE PROBLEM AND SOLUTION.My model is PT-51HX40B.
  • mynithia Nov 11, 2008
    My tv has the same problem. Except now it flashes different codes and will not exit "aging" mode. It pops up the tv menu randomly and goes into other parts of the menu without prompting from the remote. It also exits whatever video mode I'm in (if in component 1 it switches to video 1, etc.) and will also try to change the channel of the tv randomly. Lastly, it shuts the tv off on occassion. I tried the solution but after 1 hr or so, the problem keeps coming back. Please help
  • Panasonic Master
  • 5,138 Answers
Press and hold power & action button on front of tv hold untill tv turns off release - Set will come back on with other menu just press channel up . this should clear setup mode.
Posted on Dec 08, 2007
'tab' button doesn't work on Motorola MC3190
You get 3 different keypad models of the Motorola MC3190:
- 28 Key Numeric
- 38 Key Shifted Alpha
- 48 Key Alpha Numeric
So depending on the type of keyboard your model has, using TAB are different across these 3 keypads.
Please Note: Keypad functions can be changed by an application so the mobile computer keypad may not function as described.
When the FUNC button is pressed the icon "F" appears on the taskbar on WinCE devices or the icon "Blue Circle" appears at the bottom of the screen on Windows Mobile 6.1 devices.
In order to use the TAB function, do the following:
28 Key Numeric - Press the blue FUNC button (Bottom right next to Power button), and press the RIGHT ARROW button.
38 Key Shifted Alpha - Press the blue FUNC button (Right side below RIGHT ARROW button), and press the RIGHT ARROW button.
48 Key Alpha Numeric - Press the blue FUNC button (Right side below ENTER button) and press the number 9 button.
Apr 18, 2014 | Zebra Symbol MC3190G Handheld Mobile...
Call service
If you hold down the clr and 8 keys together a alpha numeric code will appear in the upper right corner of the display. I would need this to diagnose further.
Nov 13, 2013 | Toshiba E-Studio 3511 Color Copier
How do you enter fractions into the ti-84 plus?
It depends on the version of the Operating system.
This works for Older and newer OS
Enter numerator, press the [division key], enter the denominator, press the [MATH] key and select [1:ToFrac] [ENTER]
With the newer OS versions 2.53 MP and following you can manipulate fraction more easily. If your calculator MODE is set to MathPrint, you can use the [Alpha][Function keys] to access some functionalities
This gives you access to the Tabs shown in the following screen capture.
Press 1:n/d for improper fractions or 2:Un/d for mixed numbers.
Press [ALPHA][Y=/F1] to activate the FRAC menu. You get a template for a stacked fraction, where you enter the numerator and denominator at their right places. Note that fractions are always reduced to their simplest forms.
Aug 25, 2011 | Texas Instruments TI-84 Plus Calculator
Integral of sinx how to calculte in casio fx991 es
Configure the calculator to be in MathIO : [SHIFT][MODE][1:MathIO].
Press the Integral key, the one judt beloe the [ALPHA] key.
The template of the integral appears, with the cursor in larger rectangle. Enter the function the screen displays the integral, a small upper sqaure, and a small lower square. The left parenthesis of the function is already supplied by the calculator.
Press [ALPHA] X to enter the argument of the function.
Press the right parenthesis.
Remain the limits.
Use left arrow to move the cursor just before the s of sin and press down arrow to enter a numerical value for the lower limit.
Press the up arrow to move cursor in upper square.
Key in the numerical value of the upper limit.
Press [=].
Warning. To have meaningful result, make sure the angle unit used is conform to the problem you are trying to solve.
Hope it helps.
Nov 01, 2009 | Casio FX-300MS Calculator
In the programs I have made when I use the Request enter a integer, I always have to press the alpha button before entering a # in the field when running the program, is their a way to program a request...
The syntax of the command is as follows
:Request Message, VarName
where Message is a character string containing the message that will be displayed as a prompt, and VarName is the name of the string variable where the input will be stored.
If you want to input a numerical value you must convert it from character string to a numerical value (I know, it is like splitting hair but string 123456 is not the same as number 123456)
You convert from string to numerical value with the expr() command.
:Request "Value of a? ", s
:expr(s) --> a
That should do it.
Hope it helps.
Oct 15, 2009 | Texas Instruments TI-89 Calculator
I have symbol LS2208 handheld, Keyboard Wedge what is the setting to make my handheld recognize "Ctrl + S" ? I have tried this but still not work : *1st trial : Enable Convert to Code 39, Enable Code 39...
If your barcode is $V scan the following barcodes from the LS2208 Product Reference Guide.
Begin New Rule
Specific String At Start
$ (from the Alpha-Numeric section of the guide)
S (from the Alpha-Numeric section of the guide)
End of Message (from the Alpha-Numeric section of the guide)
Send Control S
Save Rule
That should do it.
Jul 09, 2009 | Symbol LS2208 Handheld
When I turned on my 48gx a month ago some of the alpha keys did not work. Today most of the keys(alpha,numeric as well as functions) don't work. I've owned this unit for over 7 years and have barley used...
Before thinking of repairs, you should first determine if it needs repairs.
You can reset the calculator:
Turn the back of the calculator towards you. Extract the top left rubber pad on the back of the calculator and use a paper clip to press the Reset button. If that does not restore the calculator to health, you should perform the dagnostic tests.
The following procedure valid for the 48G should work for the HP48GX.
Make the calculator perform a
Self test.
  1. Turn calculator on
  2. Press and HOLD the key [ON]
  3. Press and release the key with "E" to its right (the one before last in first row)
  4. Relaese the [ON] key.
It tests the RAM and ROM. You will see various patterns on screen. Afterwards you should see
The self test will continue repeatedly until you perform a
System Halt
  1. Press and HOLD the [ON] key
  2. Press and release the "C" key
  3. Release the [ON] key.
The empty stack should appear.
If you do not see IROM OK and IRAM OK, the calculator requires service.
If the above procedure is successful, you may want
to test the keyboard.
  2. Press and HOLD the [ON] key
  3. Press and release the "D" key.
  4. Release the [ON] key
  5. Press and release the "E" key. KBD 1 should appear on the top left corner of the screen.
  6. Starting at the upper left corner of the keyboard, and moving Left to right, press every key in sequence. If you follow the sequence and the keys are functioning properly you should hear a hight pitch sound at each press.
  7. If everything is OK, when you press the last key (+) the screen displays KBD 1 OK.
To exit the keyboard test proceed as described above under System Halt.
If you follow the proper sequence and a hexadecimal number appears after pressing a key, the calculator requires service.
Hope it helps.
Mar 04, 2009 | HP 48gx Calculator
Set up new panasonic th-37px80b tv last night. Its connected to a v box via scart and hdmi and dvd player via scart. It is not connected to an aerial so only watch tv via the cable box. The problem is I...
Mar 08, 2008 | Panasonic Televison & Video
Just appeared on the screen
the following appears on the screen CHKOF1EE OOOOOOOO
sometime it comes as CHKOAB 48884848 and so fort.
what can I do to remove it?
PT-51HX4OB 51in
Oct 26, 2007 | Panasonic PT-51HX40 51" Rear Projection...
Help please stuck in service menu
You should have purchaced the service manual before you went into the sevice mode, as the service mode is a dangerous place to be if you do not know anything about it. You can get the service manual from for about 20 bucks or so. A lot less expensive then a serviuce call I would think.
Aug 02, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-51HX40 51" Rear Projection Television Logo
203 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
