Question about Electronics - Others
My Imation 8gb flash drive does not open in Windows
I have an Imation 8gb flash drive. I ran Mcafee scan on it, once when I attached it to my Vista laptop. Since then Windows Vista does not recognize it when plugged into the usb.
It says 'Please insert a disk into Removable Disk F:'
Ubuntu Linux OS also does not show it as mounted. I can not read or write from the drive.
What should I do?
  • Douglessd
    Douglessd May 11, 2010
    I you don't have data on the drive you want to keep you could try to format the it? If you only want to use it with windows then NTFS would be the best file system to use. If you want to use linux and windows then you might want to consider Fat32. I think recent versions of Linux will cope with NTFS But I have not tried it. Anyway give it a try and let us know if it helpsl
SOURCE: pen drive is showing o bytes
ple hielp me my email id is mannapur2000@gmail.com
Posted on Oct 05, 2009
  • 93 Answers
SOURCE: vista recognizes the disk but wont open anything
try keying in the address of ur removable disk directly onto ur address bar. if not change ur usb port and try again.
Posted on Aug 06, 2009
  • 10406 Answers
SOURCE: 'Please insert a disk in to the removable disk drive k"
It's possible that the USB stick has "failed".
Shutdown the computer, and remove the USB stick.
Start the computer, and let Windows fully start-up.
Insert the USB stick, and see if Windows recognizes it.
If not, it is "dead".
Posted on Nov 25, 2009
SOURCE: my usb 4gb flash don my computer only reads in a secure K with 1m
See http://www.maxell.eu/FAQ2/FAQ.html
Venture USB contain two partitions - one named 'Public' and the other 'Secure'. Unfortunately we have noticed a compatibility problem between these drives and some computers running Windows Vista. In these cases only one drive is showing in 'My Computer' - usually the 'Secure' drive. As a result you are unable to access the user manuals and software which are in the 'Public' drive and cannot alter the partition sizes to allow access to the entire capacity.
Please follow the below instructions to resolve the problem:
1. Connect the USB to the computer
2. Please unzip and run the attached program
3. After completion please unplug the USB
4. Re-insert the USB to the USB port
5. You should now be able to access both drives.
Please click here to download the program and instructions
Posted on Jan 28, 2010
Format imation defender F150
Connect it to your computer.
Open "My Computer".
Right-click on the icon for the device.
Click "Properties".
Click "Tools".
Click to 'format' it.
Jan 23, 2014 | Imation Defender F150 8GB USB 2.0 Flash...
What is the password for the new kingston USB DT109?
It is true that locking mobile storage devices, such as USB drives, with Imation Lock is an excellent way to protect your data.
However, using Imation Lock with a Kingston USB drive can create problems.
Learn how to unlock your Kingston USB drive so you can use it once again.
Ensure that your Kingston USB drive has been removed from your computer's USB port.
Start the Imation Lock software by double clicking the Imation Lock.
Plug in the Kingston USB into a USB port immediately after the "Please Insert the Device or Run This Utility as Privileged User" message appears.
Access your Kingston USB drive by clicking Start > Computer.
Double click on the device.
Start the Imation Lock software again by double clicking the Imation Lock.
Disable the password protection by clicking the open lock icon.
or
If you have password protected a USB drive or partition on your computer and have since forgotten the password, you will need to completely erase the drive.
Erasing and reformatting the drive will remove any password protection, software and data on the drive preventing you from accessing the drive.
The process is simple using Window's Disk Management utility.
Log into the computer as the administrator.
Open the Windows Start menu, select "Run," type "Compmgmt.msc" and click "OK." In Windows Vista and Windows 7, simply type the command into the "Search" field.
Select "Disk Management."
Locate the password-protected drive.
Right-click it and select "Delete." Confirm the action.
The drive will be erased and become unallocated free space.
Hope this helps.
Nov 28, 2012 | Kingston Ultra Thin DataTraveler DT 109...
How to view Hidden Files on a Pen-drive?
I f you are using windows 7
  1. Go to Control Panel
  2. Chose Appearance and Personalization
  3. Folder Options
  4. Show hidden files and folders
  5. Chose view tab
  6. And check (Show hidden files, folders)
Feb 09, 2012 | Imation Products - imation - Clip Flash...
I have an 8gb imation that become 4mb free space why it happen?
click start control panel administration tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in one box then select check now start or you might tick one box then return after its finished the first
then return and tick the second box
you should not do anything while the chkdsk utility is in progress any input may damage this drive
click start click on computer then right click on your usb drive select format
(note formatting will remove all data on your drive)
then right click on your imation drive select properties you will seea mmount of space used and ammount of free space
hope this helps you
Nov 11, 2011 | Imation Products - imation - Clip Flash...
NEED DRIVER FOR PNY 8GB USB ATTACHE
If you're using the drive on a PC with Windows XP or Windows Vista, you don't need a driver - just plug it into the PC and Windows will recognize it and install USB drivers automatically.
Dec 07, 2009 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
Imation pendrive is showing write protected how to cleare it
Your pendrive is infected with Autorun.inf virus
to remove this virus install malwarebytes (It is antimalware software)and scan your whole computer as well as your pendrive when you scaning finish remove all threats
IF the above method is not work
Try to format in other operating system like windows vista or in windows 7 because in vista and 7 you can force format your pendrive
Oct 25, 2009 | Transcend (589307) Media
Will it work on windows ME?
It works fine with my new Dell which is running windows.
Dec 13, 2008 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
Electronics - Others Logo
647 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
