Question about Fujitsu AMILO PC Laptops
Amilo m1451g the power socket gets very hot
How do I dismantle the laptop to repair the socket. Is this part of the motherboard or a separate daughter board?
Had similar problem and found it was just dust on the heat exchanger next to "power in". removed fan and dusted with a soft paint brush - been fine since
Posted on Jul 28, 2009
  • Fujitsu Master
  • 32,281 Answers
Of all laptops I have dismantled I have found the power socket on the motherboard, although I have not yet dismantled a Fujitsu Amilo.
To get at the power socket, it requires dismantling the laptop completely.
Posted on Jul 16, 2009
Daughter changed password on acer one 200 given to her by granddmother and now cannot open screen
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Feb 02, 2013 | Acer Ferrari ONE 200-1799 Notebook
Where do I access the Fujitsu Amilo M1451G wireless card?
Hi
I think the fujitsu amilo k series is not wireless compatible
but there are several different ways to access the wireless on different fujitsu laptops
some switches are on the top left of the key board
some are accessed by pressing the FN+F2 keys
and some are by pressing the FN+F1 keys
hope you find it
many thanks
Mar 21, 2011 | Fujitsu AMILO PC Laptops
I NEED GRAPHIC CARD FOR AMILO M1451G ( ATI MOBILITY RADEON X300 128MB PCI EXPRESS)
try to look on this site for lowest prices for that graphic card
http://www.pricewatch.com/gallery/video_cards/radeon_x300
Mar 27, 2010 | Fujitsu AMILO Pro V1000 Notebook
The battery saying dischargeing why when the laptop plug in it say charging then about five mins later it say dischargeing why
The power adapter lead/plug that connects into the laptop's power socket maybe be faulty or the laptop's power socket could be faulty.
Connect the power adapter to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
Dec 25, 2009 | Fujitsu Siemens AMILO Pro V1000 Notebook
Battery charger fine but lap top shows not charging
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. I suggest you get a quote first.
Oct 10, 2009 | Fujitsu Siemens AMILO Pro V2000 Notebook
I have a Gateway W340UI. powercord connection
When you wriggle the plug in the power socket on the laptop and the charge LED flashes and in the right position it charges, this indicates that the power socket is faulty or there is a dry solder joint on the motherboard where this power socket is attached.
To get at the power socket will require dismantling the laptop completely. A computer repair shop can do the repair, I suggest you get a quote first.
Sep 03, 2009 | Gateway Computers & Internet
Aspire laptop 3613wlmi user manual. My new battery will not charge. laptop will not come on at all. i have a new power pack too.
If you are confident, can dismantle, reassemble a laptop and use a temperture controlled solder iron then try and fix it. If not a computer repair shop can do the repair, I suggest you get a quote first.
Aug 26, 2009 | Acer Aspire 3613WLMi Notebook
Battery stop charging with my hpnc2400 laptop can be intermittent
When you plug the adapter into the laptop's power socket and wriggle this plug does the charge LED light flash? If so the laptop has a faulty power socket or a power socket has dry solder joint on the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get access to the power socket. I suggest you get a quote for this repair before you get it repaired.
Aug 14, 2009 | HP Computers & Internet
AMILO M1451G display
if you can notice this problem in the BIOS then the problem is with the Display adapter .. if you newly bought your computer i suggest you send it back
Dec 29, 2007 | Fujitsu Siemens AMILO Pro V2010 Notebook
Fujitsu AMILO PC Laptops Logo
438 people viewed this question
Top Fujitsu Computers & Internet Experts
Computer Links
Tony
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
