Question about Canon i860 InkJet Photo Printer
Service error 5C00 - Canon i860 InkJet Photo Printer
  • 315 Answers
This shold work:-
Waste Ink Counter Reset.
(1) Turn off the printer.
(2) Press and hold the RESUME button, then press and hold the POWER button.
(3) Release the RESUME button, Next press and release the RESUME button two(2) more times in succession. Note: you are still holding the POWER button). The printer's carriage will “reset" or move momentarily.
If the above was properly performed the printer will enter the "Service Mode".
(4) Press the RESUME button 4 times, this will select the clear waste ink counter function. The lamp will alternate (change) color with each key press. Next press the POWER button to "set" the change, and return to the top of the function selection menu. Press the POWER button again to restart the printer.
Posted on Jul 16, 2009
jeffdynamics
  • 18 Answers
SOURCE: Service error 5C00 or 5100
5100 Make sure nothing is blocking the cartridge movement, if not requires service.
Posted on Apr 16, 2008
SOURCE: canon pixma ip90 printer
if your printer is flashing 4 orange and then back to green repeatedly - i found a solution to it for my ip90v - i opened the printer and checked the right hand side cogs - carefully turn them and you may see that some stray paper jam debris is blocking the cleaning unit from returning to its home in the bottom front of the printer - carefully remove it and replace the casing - turn on and with any luck you will have a dully functioning ip90 like i did.
Hope it helps some others out
Posted on Dec 13, 2008
  • 26 Answers
SOURCE: Canon IP90 Service error 5C00
BCI - 15 is not the same as the BCI -16. The look and feel the same, but the ink is handled differently by the printer - so while, in theory you could use them interchangable, the output would be terrible... Canon set it so that you can only use a BCI 16 in an IP90.
Buy a BCI - 16 cart and try that.
Posted on Apr 07, 2009
celibytes
  • 70 Answers
SOURCE: canon printer ix4000 service error 5C00
Focus on the purge unit,remove it from the printer and better check the two gears left and the sensor.
Posted on Aug 25, 2009
cene765
  • 787 Answers
SOURCE: canon ip3000 shows service error 5c00
5C00 is Purge unit error.Check for object around the purge unit.
Posted on Oct 15, 2009
CANON MG8100 series error 5C00
Per http://www.canon.co.uk/support/consumer_products/product_ranges/printers/pixma/error_codes/#5c00
5C00 - Orange and green blinking 4 times Description:
A service error has occurred.
Resolution:
  1. Turn off the printer.
  2. Disconnect the power cable.
  3. Open the printer cover.
  4. Check for any orange protective tape or white polystyrene and remove if necessary.
  5. Check that there are no foreign objects in the printer (such as a paper clip) and remove if necessary.
  6. Close the cover.
  7. Reconnect and turn on.
If the above solution has not resolved your error, please contact your nearest Canon authorised service facility using the link at the top of the page.
May 27, 2014 | Canon PIXMA iP3500 Printer
Canon ix4000 error 5c00
Error code 5C00 means purge unit is broken. You need to bring the printer to the service center to get broken purge unit replace. I hope this short information help you. Thanks.
Find more printer troubleshooting only at: Printer Clinic
Jan 09, 2011 | Canon PIXMA iX4000 InkJet Photo Printer
Service error 5c00 canon ix4000
Purge cam sensor error [5C00], PG position error [5C10]
Mar 23, 2010 | Canon PIXMA iX4000 InkJet Photo Printer
Canon i9950 printer problem error 5c00
According to the Service Manual Error Code List these are the two possible candidates to cause this failure:
- Purge unit (Part-No. QM2-1307)
- Logic board ***’y (Part-No. QM2-1272/QM2-1273)
which means, this device has to go to the service.
(Or to bereplaced)
Best Regards
cominarosa
Mar 04, 2010 | Office Equipment & Supplies
Error code 5C00
Error code 5C00 refers to a purge unit error. This is a service call error and requires that the printer be taken into a canon authorized service facility for diagnostic and proper repair.
May 15, 2009 | Canon I900D InkJet Photo Printer
Canon printer ix4000 service error 5C00
bagai mana caranya menanggulangi eror 5c00 Printer ix4000, mohon petunjuknya
Apr 01, 2009 | Canon PIXMA iX4000 InkJet Photo Printer
Canon ip3000 shows service error 5c00
Feb 23, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
MY PRINTER
i AM GETTING 5C00 ERROR
Aug 27, 2008 | Canon i80 InkJet Printer
Mar 27, 2008 | Canon BubbleJet i560 InkJet Printer
Canon i860 InkJet Photo Printer Logo
232 people viewed this question
old marine
old marine
