The pot or the whole coffee maker?
The pot you can wash with dish soap and warm water. Rise really good. If you want to clean the whole coffee maker you can fill your coffee pot with about 1/4 cup of vinger and the rest water run that through it and after that has run then run it 2 more times with just warm water to make sure all of the vinger is out.
Limescale
needs something stronger than basic dish soap to remove it. Citric acid and
vinegar are both very good products for cleaning coffee pots. Using a ratio of
about one part citric acid to 20 parts water, brew the pot of coffee as you
normally would. After that, do another 2 cycles of 'brewing' using just plain
water. This should clean your coffee pot out nicely. Good luck.
