Ford Tractor 8n Front Emblem
Problem for Ford Tractor 8n Front Emblem
Have Exmark 52 LazerZ with Kohler ch25 engine.
By jvanvliet on Jul 16, 2009
Have Exmark 52 LazerZ with Kohler ch25 engine. Engine stalled in heavy grass. Tried to re-start; engine turned over several times at lower RPM but stalled almost immediatly (PTO switch disengaged & deck lifetd out of the grass), then... nothing. No response to ignition switch, no clicking nothing.
Checked starter by applying power directly to it. Starter cranks but engine does not start. Checked fuses; 2 X 20amp fuses located behind to ignition switch. One bad, partially melted. Replaced this, tried to start engine & new fuse blew immediatly.
The wiring connector to the ignition switch is badly corroded. I cleaned this & replaced the switch; did not solve the problem.
Had an earlier problem starting - similar symptoms. Noted no or little fuel in the fuel filter but it started eventually after several tries. Engine started fine for 5 or 6 weeks, now this.
Solution #1
posted on Jul 16, 2009
Somewhat Helpful)
kg4aau
Rank: Guru
Rating: 87%, 117 votes
try looking for a broken wire or a wireing harness shorted to ground, the fuse blowing in the harness will lead you to it if you are able to see where the wire goes. you have a short somewhere may be the fuel pump, too
Was this helpful?
Yes
No
Popular Solutions for Ford Tractor 8n Front Emblem
Questions and Unsolved Problems for Ford Tractor 8n Front Emblem
Do you recommend Ford Tractor 8n Front Emblem?
Answer
Answer
I have an Airens 8hp snowblower that when it is in gear it won't move forward. It takes alot of... (More)
Answer
I have a snowblower (MTD #195-990) that attaches to an MTD tractor #145-995. I have modified the... (More)
Answer
st504 leaks from primer cup. i have kit to replace gasket and pin with spring, but can't figure out... (More)
Answer
a friend of mine has a 8n with front loader i was useing. the fan belt broke.I pulled the pump bolts... (More)
Answer
the fuse next to gas tank keeps blowing and shuts the engine off. the fuse is right behind the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Riding Mowers and... Experts
Top Garden & Power Tool Repairmen
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
