Clothes are left with a residue on them. I use
Clothes are left with a residue on them. I use liquid detergent because i think it dissolves better but still get white marks on clothes. i have cleaned the machine, descaled nd had it checked by an engineer - all works as it should! please advise
  • Washing Mach... Master
  • 1,606 Answers
Do you use a liquid fabric softner also ? Marks are usually left on clothes from undisolved fabric softner . Try using dryer sheets instead of washer softner .
Posted on Jul 16, 2009
For months i was getting white marks on dark clothing. still not sure whats causing it, but using the advice here and on other websites, i soaked clothes in a diluted vinegar solution, washed again and all marks were gone!
Posted on Jul 29, 2009
Why does my LG top load washer have mold in the detergent area?
This is a common issue, they make cleaning products to remove this gunk. Hot water and bleach will kill it as well.
Feb 01, 2017 | LG Washing Machines
Hi. I have a 2nd hand WD8016C LG but dont know which compartment is pre wash, wash + fabric softener. Also, bubbles form at the window and stay at the end Thankyou
First compartment on right side of drawer is prewash, next to it on the left is wash, second compartment on right is softener. Bubbles because you are using far too much detergent. Only use 2 tablespoons max for normal fairly large wash load, even less for smaller loads. Front loaders use little water, so need much less detergent. Also, highly suggest you not use softener, leaves residue in washer that soon turns to mildew and bad odors. Use white vinegar in its place. Helps remove detergent residue from clothes, keeps tub smelling good, and is very inexpensive. Liquid detergent is also an issue--it too leaves residue behind. Powdered detergent works much better and also is cheaper(counterintuitive you would think liquid dissolves better, but it doesn't).
Dec 16, 2016 | LG Washing Machines
What type of detergent is best liquid or powder
Liquid detergent is better for all washing machines.
Apr 22, 2016 | Miele Washing Machines
My clothes are coming out dirty with lint build up from the washing machine- kelvinator smart drive 053, have undone and cleaned centre- is there a trap underneath anywhere that may be full or blocked?
9 WASH PERFORMANCE INFORMATION
9.1 Creasing
Creasing can be caused by over loading the washer or the dryer. Permanent Press or Delicate
cycles have been designed to minimise creasing as they use a lower spin speed. Do not leave wet clothes to sit in the washer or laundry basket.
9.2 Soiling
Soiling is the result of insufficient detergent for the load. White clothes are better washed
separately. Separate lightly and heavily soiled items, as clothes can pick up soil from dirty wash water. Cold water below 68oF / 20 oC does not wash effectively. Select the wash temperature according to soil type. For example, blood and mud are better washed in cold water, while sweat and oil based soil wash better in warmer water. Loads made up of articles of varying sizes will wash better (e.g. full loads of sheets may not wash that well). Hard water requires more detergent than soft water.
9.3 Linting
Wash lint givers (eg. towels, flannelette sheets) separately from lint collectors (eg. synthetic
fabrics). Over loading the washer can increase the likelihood of linting. Insufficient detergent for the load can increase linting as there will not be enough detergent to hold the lint in suspension. Over drying synthetic fabrics in a dryer can cause a build-up of static electricity and result in the fabrics attracting lint.
9.4 Detergent Residue
Over loading the washer can result in detergent residue being caught in the creases of the fabrics.
If this occurs, decrease the load size. Some detergents need to be pre-dissolved. Check the instructions for the detergent. Cold ambient temperatures, cold washes or short agitation times may not let the detergent dissolve properly. In these cases pre-dissolve the detergent. Overdosing of detergent can also cause residue when foam breaks down and will show as white specs on the clothing. Poor quality detergents can result in residue.
9.5 Black Marks on Clothes
A build up caused by the interaction of fabric softener and detergent (scrud) can flake off and mark
clothes. Do not use too much fabric softener, maximum 75cc. If this is a problem, it is recommended that the machine is periodically filled with hot water, plus 1-2 cups of dishwasher powder and left to soak.
9.6 Grey Marks on Clothes
Not enough detergent for the amount of soil on the clothes can result in grey marks on clothes. If
this is a problem it is recommended that the machine be periodically filled with hot water, plus detergent and left to soak.
9.7 Dye Transfer
Wash and dry non-colorfast clothes separately. Non colorfast clothes left sitting in a washer or
laundry basket can transfer dye to other clothes.
9.8 Tangling
Washing with too much water (i.e. under loading) can cause the clothes to tangle around each
other. Do not load the machine by wrapping clothes around the agitator.
Sep 18, 2013 | Fisher Washing Machines
Sludge On white clothes
12.1 Creasing
Creasing can be caused by over loading SmartDrive or the dryer. Permanent Press or Delicate
12.2 Soiling
water. Cold water below 20oC does not wash effectively. Select the wash temperature according
soft water.
12.3 Linting
fabrics). Over loading SmartDrive can increase the likelihood of linting. Insufficient detergent for
12.4 Detergent Residue
Over loading SmartDrive can result in detergent residue being caught in the creases of the
fabrics. If this occurs, decrease the load size. Some detergents need to be pre-dissolved. Check
12.5 Black Marks on Clothes
recommended that SmartDrive is periodically filled with hot water, plus 1-2 cups of dishwasher
12.6 Grey Marks on Clothes
this is a problem it is recommended that SmartDrive is periodically filled with hot water, plus
12.7 Dye Transfer
Wash and dry non-colourfast clothes separately. Non colourfast clothes left sitting in a washer or
12.8 Tangling
other. Do not load SmartDrive by wrapping clothes around the agitator.
Aug 09, 2013 | Fisher and Paykel Washing Machines
My Fisher and Paykel Aquasmart is leaving white marks on my clothes. I am using the correct washing liquid, so how can I fix this? I am sick of re-washing half of my clothes
12.1 Creasing
12.2 Soiling
soft water.
12.3 Linting
12.7 Dye Transfer
12.8 Tangling
May 24, 2013 | Fisher and Paykel Aquasmart wl80t65c
How do you clean **** buildup in a top load washer?
9.1 Creasing
9.2 Soiling
than soft water.
9.3 Linting
9.7 Dye Transfer
9.8 Tangling
Dec 03, 2012 | Fisher and Paykel Washing Machines
Fisher Paykell washer left black grease spots on some clothes
9.1 Creasing
9.2 Soiling
than soft water.
9.3 Linting
9.7 Dye Transfer
9.8 Tangling
Sep 21, 2012 | Fisher and Paykel GWL11 Top Load Washer
How do I clean gw711 lint filter
There is no lint filters in these machines,
It is automatically pumped out with the drain water.
9.1 Creasing
cycles have been designed to minimize creasing as they use a lower spin speed. Do not leave wet
9.2 Soiling
than soft water.
9.3
Linting
9.7 Dye Transfer
9.8 Tangling
Jul 09, 2012 | Fisher and Paykel Washing Machines
Fisher and paykel washing machine GW703-U leave black spot on clothes during final spin
12 WASH PERFORMANCE INFORMATION
12.1 Creasing
12.2 Soiling
soft water.
12.3 Linting
12.7 Dye Transfer
12.8 Tangling
Jan 30, 2012 | Fisher and Paykel Washing Machines
Washing Machines Logo
715 people viewed this question
Top Washing Machines Experts
