I have run the ground to the block and didnt solve. so i ran ground directly to battery and also +12 hot wire directly to battery. no avail. i traced the small red wire, +0v when key on. still no charge. i can hook small red to battery and hear alt turn on but still no charge. what do i do?
Is it possible you have a blown fusible link? Wiring diagram should show where these are located. You say the small red wire is zero volts with key on. Is this the wire that supplies "exciter" volts to alt? If so, it should be 12 volts at key on I think.
Testimonial: "i figured it out, the main power wire to the back of the ignition switch wasn't hooked fully, i replaces the regulator on driver side firewall. 14.23 volts. odd thing was, i pulled every single fuse in the fusebox, and the car stayed running? scary if you think about it. its unkillable. 365,0xx miles, thanks for the info man!!"
