Question about HP Color LaserJet 2600n Printer
Magenta is weak/fading out
Do you have some comments on this ?
HP Color LaserJet 2600n (Q6455A). Magenta is weak/fading out on the left side (Magenta toner is replaced). The printer had the same problem in October last year, then mirrors in laser / scanner module was cleaned. Now it seems that the same thing has happened. Could it be that the printer is very susceptible in dusty environments, or may be paper dust is sprinkled down into the laser module?
This has become a common issue on these machines - due to design two laser-to-drum mirrors in the laser/scanner assembly face upwards. Because the unit is not sealed, the upward facing mirrors are a nice place for toner dust to settle.
The repair is rather easy for a trained professional - in theory anyone with the right set of instructions could perform the procedure, but I'd highly recommend a novice not try.
Instead call a trusted computer repair shop and explain the situation and that you need to have the mirrors in your laser/scanner assembly cleaned to resolve issues with faded color output. A reputable service agency with experience in HP printer repair should have no problem doing this procedure in less than an hour – so they shouldn’t charge you for more than an hour or two of bench labor. If the repair facility you contact doesn’t understand your request or tries to blame your toner cartridge; hang up and call another company.
Posted on Aug 03, 2009
  • 25 Answers
Well there is something that is getting on the lenses of the laser which is causing it to block the left side of the image. NEVER use that canned air stuff on LaserPrinters because this is what happenes to them if you do. The exess toner goes right onto the lenses and you have to take them apart to be cleaned.
Posted on Jul 16, 2009
When i print toner status black color is faded as well as yellow and cyan, magenta showing white color, can you please give the best solution for this. by the way i am using hp 2600n. thank you very much.
First, make sure that the toner cartridges have enough toner. The toners may be exhausted. In case the toners are ok, the printer requires servicing/ cleaning of lenses and mirrors inside the printer.
Please refer here to my earlier solution to this problem, which was very helpful for the users of Color LaserJet 2600n Printer.
GoodLuck!
Dont forget to appreciate the solutions if I could have been of any help!
CreativeTECH
Dec 08, 2010 | HP Color LaserJet 2600n Printer
The color red is dull when printing
I assume you've checked magenta toner cartridge level, and tried cleaning.
If so, the next thing to do is try cleaning the scanner mirror. On these models the mirror nearest the magenta toner builds up dust the most quickly, hence why it is the first colour to fade on prints. Only use dry swabs (no solvents) and compressed clean air on the mirrors.
Nov 03, 2010 | HP Color LaserJet 2600n Printer
The Magenta colour on my 2605dn is no longer coming out properly (very faint). The cartridge was replaced by made no difference. All other cartridge colours work fine. Tried cleaning and calibrating but...
A faded magenta on this model is probably a dirty scanner mirror.
The printer design puts a fan in an area that blows magenta toner directly at the laser scanner.
The more toner on the mirror, the more faded the print.
You will need to remove the scanner and clean it.
Nov 02, 2010 | HP Color LaserJet 2600n Printer
I have a red streak on the page coming from my hp color laser Juest 2600n
are you sure the colour is not magenta,if so replace the magenta toner
May 15, 2010 | HP Color LaserJet 2600n Printer
This printer has stopped printing reds and oranges correctly ? they are faded. Changed the toners & no difference
Print a "Config Report" from the printers menu...If u notice that the fourth square on the left side (fourth being the bottom square) for Magenta (reds and orange) is missing or very faded, this could indicate that the optical mirrors inside the printer have to be cleaned...Design flaw. ESP..if changing toners doesn't work and your your faded issue is with Magenta (Pink, red, or orange) colours are the only faded ones...With this design flaw in the optical mirrors, magenta mirror is the first to be affected!
Hope this helps!!!! I work in the industry :)
Feb 22, 2010 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n toner problems
In speaking with other tech support people it appears my image drum needs to be replaced. Also sounds like it will be more economical to buy a new printer.
Feb 19, 2009 | HP Color LaserJet 2600n Printer
Every page covered in magenta and black won't print across the page
This is caused by toner contamination in the laser scanner unit, it is quite a complex job removing and cleaning the laser scanner. I would suggest you contact HP regarding the repair.
Sep 04, 2008 | HP Color LaserJet 2600n Printer
MAGENTA TONER IS FADED
try to calibrate your printer. also try to change your drum unit.
Jul 08, 2008 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n Printer Logo
479 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
