Question about InFocus Play Big IN76 Multimedia Projector
Infocus in76 i replaced the bulb, but the lamp will not light i reinstalled it shoot it gently (recomended by infocus) still won't come on 3 red blinking lights on teh led
  • Anonymous Mar 22, 2014
    I replaced the bulb but it doesn't switch on currently. Shows green light flashing in LED.
  • Anonymous Mar 28, 2014
    how to replace lamp for infocus in32.
  • 115 Answers
Reset the Lamp as per shown in the user's manual.
Check the ballast unit, if dont work.
Posted on Nov 19, 2007
  • oxo4237
    oxo4237 Feb 17, 2012
    but how can we who have this "won't power up" problem reset our lamp counters, if we can't even get as far as the startup screen? is there a way to do this externally, by hooking it up to a computer?
Heard a pop , bulb blew out , replaced bulb , it worked for two days , now red light blinks three times pauses then three times and so on , tv won't turn off light won't turn off unless I unplug...
3 blinks indicates lamp door is not on or has not been reinstalled properly. This also could mean the lamp door switch has failed itself. Try removing the lamp door and putting back on, if that doesnt correct the problem then I recommend having the switch replaced.
Oct 26, 2011 | Sony KDF-E42A10 42 in. LCD Television
Infocus X1 Projector started with 3 blinking red lights.
Its due to lamp Ballast power supply is faulty,it need to repair or replace otherwise again it will damage Lamp so be careful
Mar 09, 2010 | InFocus X1 Multimedia Projector
Infocus IN72 - blinking RED light
firdt off, did you reset the lamp counter? did you clean the dust out of the projector? it may be overheating as well. if the lamp looks ok, you may have just blown the ballast. try projector doctor online.
Mar 03, 2010 | InFocus IN72 Multimedia Projector
Lamp burned out on X1 infocus projector, Replaced lamp, new lamp stopped working in about 5 hours, got another new lamp and it does not light at all. Still blinking 3 red blinks(saying the bulb is bad)
make sure the colorwheel is spinning. if it is not, replace it. also, blow the dust out of it with canned air. excessive dust kills lamps quickly. you'll also need to reset the lamp timer. are you using an sp-lamp-009? the sp-lamp-018 looks exactly like it, but is used in th x1a and x2. the x1 only uses the sp-lamp-009. if all else fails, replace the power supply.
Jan 08, 2010 | InFocus X1 Multimedia Projector
My infocus will not come on. the red light blinks. change the bulb but didn't do any good
check the colorwheel. if the colorwheel doesn't spin, the lamp won't light. if no fans come on either, replace the power supply.
Oct 25, 2009 | InFocus LP650 Projector Lamp
Infocus IN24 lamp not lighting up
MAKE SURE BLUB WIRING IS THE SAME AS OLD BLUB, IN24 AND IN24+ WIRING IS DIFFERENT IN CONNECTOR.
Mar 20, 2009 | InFocus Projector Lamp for IN24+, IN26+
Infocus Lp240 Projector Will not power on NEW BULB. Red light Blinks on and off.
The owner's manual should have a troubleshooting chart that will indicate what the blinking lights mean. If the new bulb did not clear it, the problem may be the ballast (part that starts the bulb). Also, when you replaced the lamp, you should also reset the lamp timer. Some units will continue to indicate a lamp needing replacement until the counter is reset. The procedure for that should also be in the manual.
Keep us posted.
Dan
Dec 18, 2008 | InFocus LP290 1100 Lumen XGA LCD Projector...
Infocus lamp not firing
more then likely the ballast has gone bad and the lamp is not getting the right voltage to fire. Only other thing you can do is remove the lamp the turn the power on and check the voltage at the connector. This will not check the triggering voltage mine you only the lower operating voltage. But since you have replace the bulb with a known good one I'm betting on the ballast is bad.
Dec 08, 2008 | InFocus Replacement Lamp Projector Lamp...
Infocus 4805 blinking red light problem
My first questions is:
Is this the first lamp you have placed into your Infocus pj? If not, did you reset the hours when you did it last time? Otherwise that can also confuse the projectors internal system thinking there is NOT a new lamp in there and there for make it stop working once the clock hours are expired and over the 3000-6000 suggested hour life.
Let me know so I can help trouble shoot other possible problems.
Oct 27, 2008 | InFocus ScreenPlay 4805 Multimedia...
Bulb failures
I experienced the same thing, only to discover it was the ballast that powers the lamp. I believe INFOCUS repairs for $390.00 per the technician that I spoke with on the phone at INFOCUS.
Jun 29, 2008 | InFocus IN72 Multimedia Projector
InFocus Play Big IN76 Multimedia Projector Logo
458 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
