Question about Enterasys Network adapter
6to4 adapter not working...
I have a gateway lapto...using vista i have yellow mark in 6to4 adapter in networking adapter i m unable to use my dsl internet although the modm is working properly. i have uninstalled the adapter and again reintalled it but it still not working pleaaase help me out
  • 57 Answers
Check the device status under the Device Manager. if the status of the device was just "drivers were not installed..." you may simply click on update driver button on the same window. If the error is code 10 or device could not start, the problem has something to do with the hardware. call the manufacturer of your laptop and check the warranty if it is still covered.
Posted on Jul 17, 2009
Can not pair to my computer.
If you see this status associated with a Microsoft 6to4 Adapter on a computer running Windows Vista in a home environment, you may be able to uninstall the 6to4 adapter to resolve the problem. To uninstall the 6to4 adapter, right-click it and click Uninstall. After you uninstall the 6to4 adapter (or if the problem is not associated with the Microsoft 6to4 adapter), it may also be helpful to run an automated troubleshooting service from the Microsoft Support Web site (http://go.microsoft.com/fwlink/?LinkId=192795).
If your computer is part of a business network, consult your network administrator for the most appropriate action. There may be company tested drivers for your computer or there may be other considerations before you disable any IPv6 components.
Jan 18, 2016 | Computers & Internet
What is the driver for microsoft 6to4 adapter #8
Hi Friend,
6to4 adapter is a component used for transmitting IPv6 packets trough IPv4 network correctly.
In some scenarios, there will be a code 31 or code 10 error appearing beside this component. A possible reason is, the network adapter doesn't support this feature. You may update the driver for your network adapter or chipset, and then try to Uninstall and reinstall the this component.
To Uninstall the component, right-click the item in Device Manager and select Uninstall.
To reinstall the component, in Device Manager, Action - Add Legacy Hardware - Next - "Install the hardware that I manually select from a list" - Network adapters - Microsoft - Microsoft 6to4 Adapter - Next - Finish the wizard.
If the steps above doesn't solve the problem, your network adapter is not a supportive one for this component. You can completely ignore this error, if there isn't IPv6 network deployed in the environment. The error won't affect your system.
To remove the error message, please right-click the Command Prompt and run as administrator, type the command netsh in 6to4 set state disable, press Enter. The component will be disabled and hidden.
Regards
Chiranjeet
Sep 17, 2010 | Computers & Internet
6 to 4 adapter no working and 1 Sat adapter #2 adapter not on, so I cant connect to internet, how can I fix this
I would like to bring to your notice one of the issue that came across with a Vista based PC of a EU who reported in his mail that in "Device" manager their are 6 to 4 adaptor is listing by name itself and for this he is unable to install any drivers as it is showing that the drivers are not installed for it. Even though EU is able to browse the internet.
Normally the above issue is related to TCP/IP transmission protocol that uses by Vista. As Vista by default support IPv6 TCP/IP protocol for data transmission over the network. 6to4 adapter is a component used for transmitting IPv6 packets trough IPv4 network correctly. If the drivers for this component is not properly installed or corrupted there will be a code 31 or code 10 error appearing beside this component. You may update the driver for your network adapter or chipset, and then try to uninstall and reinstall the this component as mentioned below. I am enclosing a snapshot of the issue along with the mail so that you can also have a clear idea of the issue.
=======Uninstalling 6to4 Adaptor==========
1. Click on Windows icon, and enter device manager into the Start Search field.
2. Right Click on all 6to4 adaptor and select uninstall from the droplist.
=====Reinstalling 6to4 Adaptor===========
2. From the device manager window select "Action".
3. Select "Add Legacy Hardware".
4. Click on Next.
5. Select "Install the hardware that I manually select from a list".
6. Select Network adapters from the window.
7. Select "Microsoft" from left window.
8. From right window select "Microsoft 6to4 Adapter"
9. Click on next and finish the wizard.
After performing the above steps issue shoule get resolve. If the issue persist then, I request you to disable this device in device manager. By disabling this it will not effect your internet browsing or your wireless conectivity, as Microsoft also confirm this in their database. In order to disable this device perform the below said steps.
1. Click on Windows icon.
2. Select Accessories.
3. Right click on "Command" prompt.
4. Select "Run as administrator".
Once the command window open, type the below said command.
After typing the above command press enter key on the keyboard.
After performing the above steps restart the PC.
Apr 05, 2010 | E-Machines eMachines Desktop PC
I have a gateway laptop....thier is yellow
when ever you have exclamtion mark on a device you simply have to uninstall it and reinstall it.that`s very simple and it will be fixed.
Jul 16, 2009 | Computers & Internet
Unable to connect to the internet at times.
Problem #1:
Please give more details about your setup -
  • What kind of router are you using (make. model, version)?
  • Do you have a wired or wireless connection from your computer to your router?
  • By "resetting" do you mean to "repair" the connection via the taskbar?
Problem#2:
This is apparently a well-known bug in Vista, but nothing to worry about. Take a look at the information from Microsoft.
Please give more details regarding problem #1 and I'm happy to see if I can be of any help.
Jun 10, 2009 | Computers & Internet
The 6TO4 and ISATAP Adapters have stopped.
You don't mention what laptop you have, but if you browse to the laptop manufacturers website, eg. www.hp.com, they always have driver downloads for their products.
Download the drivers for your laptop and reinstall these to get your network card working.
Feel free to ask me for any further assistance regarding this matter.
Best wishes,
Graemevm
May 21, 2009 | Computers & Internet
Yellow exclamation mark over the network adapter- 6To4 adapter. When I uninstalled and restarted my computer the adapter was not reinstalled. Sony laptop with Vista 32 OS.
the yellow exclamation mark indicates that the driver is not installed... run the installation disk once again install the adapter .. if unable to install with cd then, right click on the adapter from device manager and click update driver and manually update the driver ... it should work
Apr 16, 2009 | Packard Bell 1580509280 Network Adapter
6t04 adapter, yellow triangle and exclamation mark,
Ok, first thing you need to do is, see if you network adapter is enabled ... You can do this in the Device manager. If there even is an adapter ... If there isn't download the drivers for your Ethernet card, put them on a mem stick and just install them on your Vista machine ...
Mar 18, 2009 | Packard Bell 1580509280 Network Adapter
Network adapter
your adapter driver is not installed plz install it
Aug 13, 2008 | Computers & Internet
Enterasys Network adapter Logo
396 people viewed this question
Top Enterasys Computers & Internet Experts
George Nalley
Level 1 Expert
Jax Planet
Jax Planet
Nathaniel Berrios
Nathaniel Berrios
Are you an Enterasys Computer and Internet Expert? Answer questions, earn points and help others
