Question about Mitsubishi VS-50111 50" Rear Projection Television
All three colors are off by an inch or two can i fix it or is this a pro's job
  • 668 Answers
The Convergence Circuit has failed and a Professional would be needed to fix it.
Hope this helps,
Skyassoc
Posted on Jul 17, 2009
Testimonial: "the solution i recieved was very helpful in that it confirmed what i already expected but the do it yourself in me wants to still fix it myself "
    Problem Solver:
My Mitsubishi vs-50111 has green, red arced line at top and bottom with double vision like suddenly. Any ideas?
Posted on Oct 07, 2009
Panasonic Model CTP27805F 27 inch Color Television I have a Panasonic Colored Television Model CTP27805F. It is approximately 15 years old. The television was operating perfectly until about a month...
What I do with colour cast problems :-
1) check the voltage (with no aerial signal) on the collector of all three video output transistors (on the crt base) they should be +-5v of each other if one is different, then swap over this transistor with one of the other two and if color changes, its the transistor, If not then I use a 2k-4k wirewound and touch it from each collector to chassis in turn, and watch the screen (I use a mirror) each color should be equally bright with flyback lines, if not its probably the tube (CRT) faulty.
2) If all of tests are ok, then I find the three wires coming up from the the main pcb to the crt base panel and swap over the green/red and see if the color cast changes
If yes then its the chip on the main board, If no its on the crt base board, so check values of all the resistors there.
Jul 18, 2008 | Panasonic Televison & Video
I have colorful horizontal lines running through my imac
Colorful lines usually represent video problems. You will need to take your iMac to an Apple certified repair store to have it fixed. It's an advanced job that can only be done with the help of special equipment.
Good luck.
Tech from
Mac Repair Mississauga Apple MacBook screen repair Service MacBook pro...
Aug 30, 2014 | Apple iMac 24-inch, 2.66GHz Intel Core 2...
Spooler hangs/freezes when sending any print job to network share printer. I have tried every fix I could find online. I finally ran a sfc scan and fixed a corrupted windows file, the printer will p
I think you're on the right track with the firmware and driver updates, but be careful about your driver and version selection. For instance, I have an old usb Minolta Laser and XP wants to install the driver for the 1200W. Problem is, my unit is a 1250W. It works eventually, but my spooler hangs for a solid three minutes and network jobs always fail... Good luck sir.
May 21, 2014 | HP Color LaserJet Pro 400 M451nw
Screen size
command + 0 will set the zoom to normal.
Apr 15, 2014 | Apple MacBook Pro Laptop Computer with...
Turns on for 30 sec then goes bright blue and goes back into standby. turn back on it does it agian
This is blue CRT problem in tv as it is rear projection tv that has three CRTs red-green-blue inside to project color picture on front screen.
Blue CRT (tube) will be replaced to fix the issue and it is job of Pro because lots of adjustments are required after replacement of tube.
Local tv repair shop will help you for that.
Thanks
Oct 02, 2010 | Sony KP-51WS500 51" Rear Projection...
Color serperation of red and green
The convergence output IC's have failed which is a common problem with all projection tv's. They need to be replaced and this is somewhat of a major job. Unless you are real handy those big amps are not easy to get to or desolder and replace. A reputable tv repair shop usually charges around $200 to $350 to do the job.
May 27, 2009 | Philips Magnavox 9P6034C 60" Rear...
Copier not working in color
sounds like a jobg for copier man.
at any rate, you'll find that most likely your cartridges are leaning towards empty, check em first.
Feb 21, 2008 | HP OfficeJet Pro 1170c InkJet Printer
Green colors are seperated from rest
You might have a bad green convergence output IC either loose from the circuit board or open internally OR shorted. Stargazer
Apr 22, 2007 | Pioneer PRO-99 TV
Mitsubishi VS-50111 50" Rear Projection Television Logo
167 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
