Rotation screen has stopped working
It could be switch of electric gizmo that makes it rotate.
SOURCE: Screen Rotation
you have to drop the device back to its native resolution 800x420 for the rotate function to work
Posted on Jan 09, 2008
SOURCE: My roomba 560 has brushes that spin one rotation
Here's the solution to this problem...
Remove the rollers and run the Roomba and see if the problem goes away. If so, here is the solution to the problem...
Each roller has a little yellow cap on one end. Pull this cap off (it should come off easily) and remove the crud that is wrapped around the "axle" of the rollers. The crud keeps the cap from going far enough down on the axle, essentially making the roller longer. This causes the roller to get into a bind and results in the roll-thump-roll-thump-roll problem. Once the crud is removed, replace the cap, replace the roller (notice how it drops in easier now?), and enjoy your Roomba again.
Posted on Apr 25, 2009
SOURCE: LG Xenon - Screen Rotation not working AGAIN!!
Rub a magnet across the back. The problem may be with your phone case. i found this on another site and it has worked for me
Posted on Jul 27, 2009
  • 69 Answers
SOURCE: Numark TT1 need to be manually started by moving platter
that'll be a blown component of some sort on your main board i think mate,youll wanna get some one handy wiyh a multi meter.gd luck
Posted on Aug 08, 2009
SOURCE: screen rotation lock is now audio muting. i want
Unfortunately, this is a new feature from a past update. There is no current way to change the lock button back. However, you can access the screen rotation lock by double clicking home, swiping right, and toggle the screen rotation lock. As a future note, in the next update, you will be able to change it back.
Posted on Mar 01, 2011
I have a connect tablet
Auto Rotation
  1. To open the Notification Panel, swipe down from the top of the screen.
  2. To stop the rotation, touch Auto rotate in the Quick Setting Panel.
  3. Depending on the screen orientation when touching the Auto rotate icon, the icon changes the screen to either Landscape or Portrait.
BEST OF LUCK !!!!!
Jul 30, 2017 | Tablets & eReaders
My FaceTime screen is at 90 degrees
  1. Verify that screen rotation lock is off. If you see this symbol in the status bar, rotation lock is on: lock_rotate.png Follow the steps below to turn off screen rotation lock.
    • Swipe up along the bottom of the screen to display Control Center (you can do this from any screen, including the Lock screen).
    • Tap the Screen Rotation Lock button.
    • If the button was highlighted, the button will appear dimmed after tapping it.
  2. Not all iOS apps are designed to rotate. Some may use only portrait or landscape mode, or switch depending on the content. To test screen rotation, open the Calculator app that comes with your device. If the screen does not rotate as expected while using the calculator app, continue troubleshooting.
  3. If the issue persists, restart your iOS device.
  4. If the screen remains locked, back up and restore your device.
Oct 05, 2014 | Apple Ipad I-pad
How can I get the screen to rotate over to the correct position?
You might have your Orientation Lock on. If you are using iOS 7 or 8, swipe up from the bottom and disable Orientation Lock (http://cdn.osxdaily.com/wp-content/uploads/2013/10/stop-screen-rotation-orientation-lock-ios-7.jpg)
Alternately, the switch on the side of your iPad might be set to Lock Rotation, so go to Settings > General and see if Use Side Switch To: is set to Lock Rotation. This would mean that whenever the switch above the volume controls is down, the orientation is locked.
Sep 30, 2014 | Apple iPad Tablets & eReaders
How do I remove volume icon from the middle of my iPad screen?
You might try this...you can set your side button on upper left corner edge of ipad to either mute volume or lock screen (stop it from rotating). Check how yours is set...Go into settings>general>Use side switch to:
see if it is set on mute. If it is switch it to Lock Rotation. Now that side switch will lock or unlock screen rotation.
See if that might stop your volume icon from popping up. Good luck!
Apr 30, 2014 | Apple iPad 64 GB 3G Tablet PC
Allwinner A20 dual core android tab screen want rotate
Allwinner A20 is a name of a processor, so I'm not sure what tablet are you using.
There is an option to block rotation, for example if you want to read an e-book while laying on your back. Go to settings and try to find an option to unlock rotation.
Also, some tablets have a hardware (physical) switch on the side that locks rotation.
Jan 17, 2014 | Samsung Galaxy Tab Tablet PC
IPad mini with iOS 7.0.3 and I want to stop screen rotatiog and to enable it at later time
Like in all iPads the switch on the side, close to the volume buttons can be switched to screen rotation block or sound off in settings, general and then from the top the forth menu block. Put that option to rotation lock. Now you can use that switch to lock or unlock the screen.
Oct 29, 2013 | Office Equipment & Supplies
Washing machine stopped spinning & tumbling at any cycle. Have limited knowledge on multimeter use, but door lock/switch appears to be in working order. Belt around motor in excellent condition. ...
Check the condition of brushes. Replace if necessary. Check motor rotation. Not rotating, check if it has a soft starter for motor. If there is soft starter, bypass it. Check the motor rotation. If it does not rotate, then it is quite likely that the motor is burnt.
- sonsunny
Jul 09, 2011 | Washing Machines
The screen stopped rotating. what can I do?
You will have to do a factory reset, which will restore the default settings on your device.
1) With the device powered off, press and hold the Volume Up and Power buttons at the same time.
2) When you see the Samsung logo, release the Power button, but continue to hold Volume Up until the recovery screen appears.
3) Use the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection.
4) Press Volume Up to continue.
Mar 14, 2011 | Samsung Galaxy Tab Tablet PC
How do you unlock the rotation on an iPad? I've looked it up and I'm told the switch above the volume control turns it off and on, but on my iPad it just turns the volume off and on.
Use the following steps to enable screen rotation lock:
  1. Rotate iPad so the display is in the desired orientation.
  2. Double-click the Home button to display recently used apps.
  3. Flick from left to right along the bottom of the screen.
  4. Tap the rotation lock button on the bottom left of the screen.
  5. A padlock will appear in the rotation lock button.
Dec 28, 2010 | Apple iPad (16 GB) WiFi Tablet PC
Washer stops and make clicking sound
sounds like the timer needs a little assistance to get "over the hump". perhaps many cam switches must be switched at his point of cam rotation. if machine is getting old, then attempt to lubricate the electric motor that turns the timer mechanism. also lube the shaft bushings for the timer cam plate as well if possible.
Aug 17, 2007 | GE WHRE5260E Top Load Washer
Heating & Cooling Logo
69 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Ronny Bennett Sr.
Ronny Bennett Sr.
Marvin
Marvin
