Question about Epson Stylus Photo R1800 InkJet Printer
Can check ink levels on epson r800 or cx4200
Since installing leopard, I can check the ink levels on either of my printers.   Using the offical print and fax control panel, I get "information not available".  If I pull up the utility in the print dialog the utility either crashes, or it gives me a "communication error with printer".  any help would be appreciated.
  • 3 more comments
  • bayoureggie Nov 24, 2007
    I am having exactly the same problem.
  • Anonymous Dec 01, 2007
    me too
  • Anonymous Jun 01, 2008
    same problem. can't check ink levels. don't know which one needs replacing.
  • Anonymous Sep 15, 2008
    Exact same problem. Can't even print and downloaded supposedly the "new" driver and nothing happened.
  • Anonymous Mar 25, 2014
    the check the ink level cannot be found, its like it disappeared
I just off the phone with Epson and one problem with Leopard is that it uses Apple's drivers for printing instead of Epson's.  I couldn't print directly to CD because of that.
To see if that's your issue, go into system setting -> printers & faxes and then select the Epson printer from the menu.  On the right, it will give information about your printer including KIND.  If it has your printer name followed by GUTENBERG, that means it discarded the epson drivers in favor of the Leopard ones.
You have to delete that printer (hit the minus button while it is highlighted).  He then had me go to Macintosh HD-> Library->Printers and delete the entire Epson folder to prevent it from automatically reloading... this may be overkill, but...
Then go to and download the latest mac drivers for your printer and install them.  Go back to System Prefs->Printers and Faxes and click on the + button to add a printer.
When I did this it, my r1800 came up, but it had a drop down menu to choose the KIND and it still had the Gutenberg option, but it now had 'EPSON SP 1800'-the actual epson drivers.  I chose that option and now it works flawlessly and I can again print to CD.
Posted on Jan 17, 2008
  • Eric Sobocinski Dec 27, 2010
    I'm running Snow Leopard (10.6.5) and Epson just released its "Common Updater v4.00" for Mac OS X. After running the updater, make sure to go into "Driver" under System Preferences > Print
I suspect this will be a tricky one! I am printing from a new iMac / CS5 setup. I am using OCP inks and Ilford paper. I am printing the same images to both machines. The print settings are identical....
hi Anthony, i spent a month trying to figure out a similar problem with an epson 2200. Now, the printers are different but not that much, and, the changes in paper and ink gave me "some" color issues but not as bad as what i was getting. your problem seems very similar. i run a PC so this is similar but not exactly the same. what i found was that a Magenta/ violet cast was due to double profiling. I could verify that i had the correct settings but i was wrong! I print from CS3 into the epson 2200. What i found was there is an error(no one is talking about) in the printer driver. You cannot shut off the color management completely! Assume this scenario, you are printing with CS3 applying your profile in CS3. Make the settings in CS3 as normal, then you are directed to the printer settings. Go to the print driver and make the selections for ICM Color, and select "no color". The KEY is to make sure you do this step LAST , make sure to click on the "apply" button, then "Close". Once you make the selection of "No Color" do NOT click on anything else. If you change screens in the print driver once you select "no color mgmt" the driver CHANGES your settings. ANY settings in the other pages in the print driver cause the driver to apply a printer profile, this effectively "double profiles" your photo print causing the magenta cast. None of this should happen if the driver was created correctly but there it is! It took a long time to test and verify but it is as i stated. Once i got it sorted out my photos are excellent ALL the time. Good luck, worm1855.
Nov 21, 2010 | Epson R800 InkJet Printer
My Epson Stylus CX4200 will not print because my Cyan ink is out. I tried printing in black and white only but still won't print because of the one empty cartridge. Is there any way I can still print...
I have a CX4800 and after clicking Print, I click Properties, then check Black ink only (is this how you are printing black and white - or is your document black and white)
If you haven't tried this option - it is worth a shot.
Mar 01, 2010 | Epson Stylus CX4200 All-In-One InkJet...
Parts inside your printer are coming to the end of their life
It could be the Waste Ink Pad. Call Epson tech support for the correct answer. If it is the pad go to the site below and get a Waste Ink Container. It sits outside the computer. Lood at the CISS, it will save you Tons of money.
Aug 04, 2009 | Epson Stylus Photo® R800 InkJet Printer
Epson Stylus CX 4200 won't print color copies of anything
Uninstall the printer software.
Restart your computer.
Download the latest drivers and software for the printer.
Load the software.
Part of the software could have corrupted itself...
Jun 11, 2009 | Epson Stylus CX4200 All-In-One InkJet...
Epson Stylus Photo R800 Print Head Nozzles ??
Don't use nozzles clean function, besides ink consuming it can cause damages that cannot be fixed: black lines on the back side of the page that will be permanent. Instead put two photo paper together (2x260 gr) and push the two papers together into the printer while printing a motive including many colors. Do so a couple of times and the clogg usually disappears. Good luck! jonk
Aug 25, 2008 | Epson Stylus Photo R800 InkJet Printer
Can't print to 1410 after I upgraded to Leopard
I believe I had a similar problem. Try this:
Go to System Preferences > Print & Fax > '+'
Select the Epson 1410 and then under Print Using go to Select a driver to use the Epson Styls Phot 1410 - Gutenprint v5.1.3
I hope it helps.
Jul 25, 2008 | HP PSC 1610 All-in-One Printer, Scanner,...
Epson R800 Red Color Problem
Actually magenta is the weakest compared to cyan and
yellow using even K3 inks. Now epson is releasing
K3 with vivid magenta ink. Using any color management
I have found it very difficult to reach a real red without
a lot of tweaking in my color profiles. Now it appears
that Epson sees the problem and is changing magenta
out for vivid magenta ink to solve the weak magenta.
Jul 17, 2008 | Epson Stylus Photo R220 InkJet Printer
My epsonstylus cx4200 wont print with black ink.
Please ensure that you have removed (Completely) all yellow tape on the top of the cartridge.If it is not completely removed a vacuum can form preventing the flow of ink.
Run a few cleaning cycles.
Try a local print test...
As for thr G4 sorry but I can help you except to power off all devices, power up and reboot.
Feb 09, 2008 | Epson Stylus CX4200 All-In-One InkJet...
Epson R800 prints very wet, very very smeared pictures
it depends on the type of paper you are using. it is how the ink chemicals react to the chemicals on the photo paper.
Jan 01, 2008 | Epson Stylus Photo® R800 InkJet Printer
Epson Stylus CX4800 All-In-One
One possible solution that we can advice is to do a complete trash & reinstallation of printer driver as well as the scanner driver.
For iMac with Leopard, there is a big possibility that the printer driver is not the correct epson series printer driver that's why you can't ink levels is unavailable. Just to set an expectation, printer driver for CX4800 is pre-installed as resident driver in Leopard. Please try to the following to solve that issue:
Determine Which Driver is Currently Being Used
1. Click on the Apple icon in the upper left corner of the Finder and open System Preferences.
2. In the System Preferences window, click on Print & Fax.
3. In the list of printers on the left side of the Print & Fax window, click once on your Epson printer to select it.
4. Check the name of the driver being used; it is displayed in the center of the Print & Fax window next to “Kind”.
5. If the driver name displayed next to “Kind” is Gutenprint, the incorrect driver is being used. Follow the steps in the next section to select the correct driver.
Selecting the Correct Driver
1. Turn off the printer.
2. Delete the print queue and remove the printer from Print & Fax by clicking on the minus (-) button under the list of printers. Click OK to confirm the removal.
3. Click on the Apple icon in the upper left corner of the Finder and open System Preferences.
4. In the System Preferences window, click on Print & Fax.
5. Turn on the printer. The system should add the printer automatically.
6. If the system does not add the printer or if it adds it using the Gutenprint driver, contact Apple for assistance. You may need to reinstall the Epson drivers provided with Leopard.
NOTE: To check ink levels, click the Utility button, then click EPSON StatusMonitor. The Supply Levels button will not show remaining ink levels for your Epson printer.
Dec 16, 2007 | Epson Stylus CX4800 All-In-One InkJet...
Epson Stylus Photo R1800 InkJet Printer Logo
1,412 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
