Question about Canon PC170 Copier
Won't photocopy / warning light flashing /
Having instructed the copier to print 10 copies it stops after 3, paper only halfway fed out. On opening the machine up another paper is fed under the printing bar. A warning light flashes - looks like a number eight i.e. 8, with a jagger'd saw-tooth projecting out of it. We don't have the user manuel anymore, which I'm sure would clear up the problem as I would like to know what the warning light is trying to convey?!
Canon photocopier.
Serial no: F126300. Canon PC-11?!
The paper feed system is worn (rollers, and separation pad). What is happening, is extra sheets are being fed into the machine primarily because the separation unit is not doing it's job properly. So rather than just one page at a time being fed, it is allowing an extra sheet to "creep" in intermittently, causing the jam. And the indicator you are seeing is the "jam" indicator.
Posted on Jul 16, 2009
All lights flashing
Hi
Check through the paper paths for any obstructions.
Remove stuck papers and make sure the paper feed tray is not filled to capacity.
Clear any print queues.
Disconnect the printer from power and re-connect again.
Turn it on and try printing now.
Hope it helps.Thanks!
Mar 02, 2012 | HP OfficeJet 6210 All-In-One InkJet...
When photocopying, leftside print missing/text
it is only happned when you takes only photocopy ? or Printing... The same will be affect while printing and copying may be the problem related to Laser Supply unit, open the LSU and clean the LSU mirror with a cotton waste. Your issues must be solve....
before that pls. check your cartridge unit...
Apr 24, 2010 | Samsung SCX 4200 All-In-One Laser Printer
Paper that was scanned is still in memory and won't stop printing
The Canon PC1061 never had a memory so I can only suspect that you have a component failure. Now try this. Place a brand new package of paper into your photocopier's paper tray. Now also lay one blank sheet of paper on the glass and run 10 copies of it. If you notice that the image that you saw before is getting lighter and lighter then most likely you just need to replace the drum unit (drum cartridge).
Dec 21, 2009 | Canon PC1061 Copier
Instructions for scanning on epson cx4300/cx5500/dx4400
Scanning the Document
Place the original on the glass.
1) Open the document cover and place your original face-down on the glass, in the upper left corner. Move your original about 1/10 inch away from the top and left edges so all of it will be copied. 2) Close the cover gently so you don't move the original . Caution : Never open the document beyond where it stops and do not place heavy objects on top of the CX4600. If you need to copy or scan a thick or large document, you can remove the document cover. Just open it and pull it straight up. If you need to press the document flat while you copy or scan it, do not press too hard and be careful not to move it. Caution : Do not use excessive force on the document cover, and do not twist it diagonally. You may damage the document cover. When you are done, replace the document cover by inserting the tabs back into the slots. Copying a document. 1) Load paper. 2) Press copy button until you see the desired number of copiesin the Copy window You can select up to 9 copies at a time. 3) Press the paper type button to select PLain Paper. The light indicates which type is selected. 4) Press the paper size button to select Letter. 5) If you want your copies automatically reduced or enlarged to fit the loaded paper size, press the Fit to Page button. 6) To make color copy, press the Start Color button To make black and white copy, press Start B&W button. The ON light flashes and after a moment the CX4600 starts printing. If you need to stop copying at any time, just press the Stop button. Do no pull out paper that is printing, it will eject automatically to the output tray. Hope this helps. Please rate my response. Thanks Have a good day.
Nov 25, 2009 | Epson Stylus CX4600 All-In-One InkJet...
My Brother HL-2040 paper led light won't stop flashing, the paper's not jammed or anything, I just put in a new toner, too. I tried doing what someone else said about opening the cover and holding Go until...
Hi. The reasons listed in the manual that cause the LED to flash normally are:
Front cover is open
Close the front cover of the printer.
Back cover is open
Close the back cover of the printer.
Paper jam
Clear the paper jam. See Paper jams and how to clear them on page 6-5.
If the printer does not start printing, press the Go button.
No paper fed manual feed slot
Put the paper in the manual feed slot. See Printing on plain paper, bond paper
or transparencies from the manual feed slot on page 1-10 or Printing on thick
paper, labels and envelopes from the manual feed slot on page 1-13.
Memory full
The printer memory is full and the printer cannot print full pages of a
document. See Solving print problems on page 6-15.
Print overrun
A print overrun occurred and the printer cannot print full pages of a document.
Drum Error
The corona wire needs to be cleaned. See Cleaning the corona wire on page 5-14.
If you check out page 6-5 it tells how to clear the paper jam from the rear of the machine! A point often missed.
Check out the website below if you don’t have a copy of the instruction manual =
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002089/US_Eur.pdf
If all else fails, try a reset of the printer Drum & Page counter:
  1. With printer tuned on.
  2. Press and hold the “internal button” behind front cover, until all LEDs illuminate.
  3. Make sure Drum light is off, then release and close front cover.
Hope some of this helps………..Please post a response back here and let us all know if it works?............Regards, Cornwellnet (UK)
Jul 12, 2009 | Brother HL-2040 Laser Printer
RX 420 PRINTER WONT PRINT AS PAPER JAMMED WARNING KEEPS FLASHING
hi i hope i can help you? remove the cover from the machine and load paper as normal. and watch if the mechanics is sticking or anything that you can see give a clean with wd40clean all rollers check that you are puting in the correct amount off paper.check for loose connections.check for dirt on the switches.
May 04, 2009 | Xerox Phaser 8400 Laser Printer
After printing a page, 2 red light signals show and doesn't print anymore until after certainparts of the copier were opened and then closed. When the swiych in turned on again, it copies only 1 and then...
1)check properly if there is no paper jam, make sure all jams have been removed
it this doesn't work
2) Remove the paper in the paper tray and replace with papers tha do not have folded edges
Make sure you are not using a paper that cannot run smoothly through the photocopier (too light or too hard)
3) Also check if some papers are stucked under the paper tray.
Apr 08, 2009 | Sharp AR-5316 Advanced Digital Imager...
Data light flashes , documents won't print.
this is not a network problem.because machine is receiving documents thats why light is blinking. check the paper in the tray whether they are of correct size, change the paper size from computer, or call your tech service rep it may be due to usb cable or faulty network cable, or it may be the problem of main communication board of photocopier machine.
Feb 10, 2009 | Konica Minolta bizhub C351 All-In-One...
Hp psc 1219
dear szaszy
as per your information your printer paper jam sensor is having problem.Please get it serviced
Apr 04, 2008 | Office Equipment & Supplies
Canon PC170 Copier Logo
226 people viewed this question
old marine
old marine
