You can see the cable if you pull on the hood as far as it will go
What you will need to do is go from the bottom up with a sturdy metal rod with a 90 degree bent end and try to release the latch. This will probably take some time as room is scarce. If you are looking from the bottom up, the latch release is towards the middle left of the white plastic coolant reservoir tank. You will need to try to push it towards the drivers side.
For step by step troubleshooting click the link below:
http://fexya.blogspot.com/2016/06/honda-cr-v-hood-release-cable-broken.html
this will help.
Thanks.
SOURCE: 1986 Honda Accord: The hood will NOT open!!!
Use a flashlight and look in & up through the grille & you may be able to see where the sleeve of the cable runs to the latch. When you look at it, should allow you to figure out which way to pull or pry to get it to release hopefully.
SOURCE: My hood wont open
use a pair of needle nose pliers and pull the cable to open the hood..im assumeing the plastic cable lever snapped or broke off... if that doesnt work, remove the left front wheel and left front fender liner and u will see the cable.. u can pull on that there as well.. first try the needle nose pliers (up to u if need to remove the wheel..i did . i have big hands.
SOURCE: how to open hood when the dash release cable is broken 1996 accor
reach under the front of hood , and pull cable .
SOURCE: '99 Honda civic LX. The hood latch requires a lot of force to ope
What you should do is spray the latch with pb blaster,556,or wd40.Shut the hood and after a couple of times it should work better also do a visual inspection of the latch and make sure nothing is bent.
SOURCE: I have a 2005 Honda CRV. The hood release cable
You should be able to get to the cable with some plyers to open through front grill
