HP pavilion portable PC running XP-connected printer OKI C3200-all fine until tried to print a powerpoint with two pictures jpeg who were strongly zoomed to see a detail (lots of bits..) . Printer hanged . My explanations are translations of a french XP version. For info black drum life of OKI really was at the end.Tried a few things -no way to print-replaced black drum and ink by brand new. OKI Test page will print all OK. No way to print something else because Message about spooler problem-surfed on internet -Tried config>services>spooler>stop then printer off then config>serv>spooler>start then start (lower left)printers>oki>delete all docs then printer on . No change. Deleted all OKI software using config panel >delete SW reinstalled Driver and OKI sw -When printing a small word doc OKI message about drum life of 3 colour cardridges -message hangs-if closing Word message : authority NT/system print spooler terminated in unexpected way -a counter of time remaining counts down and stops at random time but PC will not stop (except once when counter could go down to zero )so I have to Shut down using Start (lower left)-stop Got idea now to try my other portable PC and ... the same OKI printer state hangs on the screen BUT when I try to close it with click on white cross on red box , it closes neatly but continue or cancel icons of OKI message will not work Can you help??
  • 1 more comment
  • jlah807 Jul 16, 2009
    Thanks for next printing suggestion .
    My printer is a C3200 and has no letter afterwards. No display on the printer,so your suggestion does not apply .
    I called OKI and they say that if message is "colour cardridge life" the printer will hang.
    The guy was very young and had obviously little experience . I am 62 and come from computer industry :-))
    I got this OKI printer message JUST WHEN the problem with the powepoint large jpeg occured and so the 3 colour drums would be empty at the same time .
    Sorry can not believe this . It is very likely a SW problem .
    Looking at your suggestions and info sent I see a "fuse to reset on OKI "suggestion .
    You get the ball .
    Thanks for 1st try anyway .
  • jlah807 Jul 19, 2009
    your suggestion is unvalid because it refers to a C3200 N printer .
    After searching internet myself and trying lots of things ,even some registry cleanup with reinstall
    the issue of a missing dll named hpz2ku04 (thousands of help mail on web sites) appeared to be
    the solution . However in all forums and blogs all people got no help . When on HP web site it starts saying there are more than 300 models using this dll but refuses to deliver it ...
    Other web site just want to sell you a registry tool . I puchased 2 in the past and it did not solve my
    problems .
    AND SUDDENLY A WEB SITE SAID:DID YOU TRY RESTAURATION !!!!
    No I once again forgot about this impressive Microsoft tool .
    All works fine again :-)))))))))))))))))))))))
    your proposal has a lot of overlap with what I tried before contacting you .
    I searched internet and the issue boiled down to a missing dll. I spent half a day searching for
    hpz2ku04.dll and found thousands of people with the same issue .However no way to find that dll , even on HP web site who starts saying there are more than 300 models using it but when you try to locate it ,their sw says :nothing found (sounds familiar ) .
    OKI support center said I should change all drums !!!! to unlock.
    Then digging into a blog with a answer about cleaning registry and reinstall , a one line suggestion
    popped up : Did you try windowsXP restauration ?
    No , again I had forgotten about this very powerfull tool (I am 62 and like bits and bytes)
    EVERYTNING WORKS FINE AFTER ONE LONG RESTAURATION .
    Yours
  • 2,359 Answers
C3200 is a nice and simple LCD printer. It's dated back in 2005.
The first thing I will check is the base memory and check for extended memory installed inside this unit.
Try to see what's the max ram you can install and scale down the pictures accordingly.
In window printer setting,it may has 300 or 600 dpi. Try on that works for you. You may have other mode to help you print this mix graphic /text page.
Test print one at a time.
Good luck.
Posted on Jul 19, 2009
    President:
  • 2,777 Answers
It is definitely a software problem since you verified the printer is functioning with the test page you created. You will want to make sure to reinstall all OKI software on your XP machine and reinstall it. Make sure you remove the printer from printers and faxes in the control panel after you uninstall the software. Reinstall the software and the printer. If still no go then either the software has somehow corrupted itself on your XP box, or there is a communication error, you may want to try another cable. If that still doesn't work try attaching the printer to another machine entirely and installing the software there. If it still doesn't work you probably have a failing communication port on the printer.
Hope this helps,
Tim
Posted on Jul 16, 2009
  • 19,396 Answers
What may happen is that you tried to print a too big image for Printer's RAM, probably the Powerpoit document.
Remove Jpeg from document, resize them in Photoshop or similar, and insert smaller definition Jpeg in the document if you want to print them in the future.
Regarding the printer, first ensure that the printer has same problem on several computer, to ensure that the cause is not the Operative System or the controller software.
Then try unplugging the printer power cord, to do a basic reset. Restart computer and try again.
If that does not work, try resetting printer NVRAM to initial settings. The procedure should be the one below:
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
Service procedure from Oki 3200n.
Regards.
OKI C3200, status monitor
Check our USB cable. It should contain AWG marking on it. Depending on AWG number there is a limit to USB cable length as follows:
28AWG = 0.81 m
26AWG = 1.31 m
24AWG = 2.08 m
22AWG = 3.33 m
20AWG = 5.00 m
Make sure your cable does not exceed the maximum length according to its marking. Replace the cable if it exceeds the length.
Jun 07, 2009 | OKI C3200 Led Printer
OKI C3200n and HP LaserJet 3052 Can't be in the same PC
You do not say what operating system you are using?. They are both compatible with Windows 10.There should be no conflict between the two printers. Use system restore and go back in time before you had the problem. Disable your antivirus and try and install them again. That should work.
Jun 26, 2017 | OKI C3200 Led Printer
How can I reset my Drum Life Counter on my Printer?
http://my.okidata.com/PP-B4250.nsf?opendatabase
Guide Users: B4250 download user manual
American English
May 06, 2009 | OKI B4250n Laser Printer
Drivers for a C3200 Oki laser printer to go with an Apple MacBook
Do a google search, there are 3rd party drivers that work all sorts of old and odd stuff, the Oki sounds mainstream, the term is GIMP driver I think
Feb 01, 2009 | Apple LaserWriter 300 Printer
Print spooler service not running on Windows XP
Spooler depends on the RPC service being running. But you really need to get into event viewer and check for anything related to either RPC or Print Spooler. If you're trying to print to a network printer you could have firewall issues either within Windows or your router. Think about what changed on your system around the time this problem began.
Dec 30, 2008 | HP Pavilion dv6000z Notebook
Printing Pictures
I use Gadwin PrintScreen (Free version) and tweak it to capture any size rectangle that you draw on the screen.
To tweak, right click on the Systray icon. Select properties, then select Source, put a dot in the "Rectangular Area".
I have even used it for movie type files, just stop the motion where you want to, and run the Gadwin.
Dec 02, 2007 | Adobe Photoshop 7.0 for PC
Oki ML 320 Turbo/D IBM - JetDirect 170x Print Server prolems
Check the receive buffer on the Oki. I usually set it to the highest (88k or 128k). You might also check the print head gap if you are printing multi part invoices. If the print head is too close it may overheat and stop printing. If you have a different printer, swap it out and see if it prints correctly. It may be a problem with the JetDirect 170x, not the printer.
Nov 08, 2007 | OKI MICROLINE 320 Turbo Matrix Printer
Computers & Internet Logo
76 people viewed this question
David Payne
David Payne
