Question about Samsung HP-R4252 42 in. Plasma HDTV
"Not supported Mode" message
I have a new HD R4252 42 in Plasma with no remote or installation book. (Open item) I am getting a "not supported mode" message. I am trying to connect to my directv hd box.
  • 1 more comment
  • Anonymous Nov 30, 2007
    Samsung Plasma HDTV giving "not supported mode" on motorola 6416
  • Anonymous Dec 02, 2007
    tried connecting my Samsung 46inch and received same problem...answers?
  • Anonymous Jul 02, 2008
    i am haveing a problem getting my ps3 running
The above information about setting everything to 1080i does work, though you may need a call into your cable/FIOS office. I thought I had everything set, but it still wouldn't work. I have Verizon FIOS and my HD channels were working just fine, but the normal alspect channels were not. It kept saying unsupported mode. I set everything I could on both the TV and the DVR/settop box to 1080i, it still wouldn't work. A call to Verizon found that the 4:3 override was set to 480i though -- this was burried deep inthe menus. If you have a Verizon Motorola DVR or HD box, here's how to change it. From the front controls of the set top box, power it on, then off. Immediately press SETUP and SETUP again. that should bring up a very user unfriendly menu with codes D1 .... D20, etc. Choose D12 (User settings). This displays the user settings and you probably shoudl see 16:9, but check the 4:30 override. It should be OFF. If it is not, press POWER and then press MENU once. The set top box should display 16:9 and then open the previous D12 screen in EDIT mode. Using the cursor keys on your remote, scroll down to the 4:30 override. Set it to off. Then press POWER to save. Power back on and the normal aspect channels will now work. Good luck.
Posted on Dec 24, 2007
Hook up the component cables on the tv and the dtv box
go to set up on the menu select HDTV or display and deselect all of the 480i and 480p and in some cases also the 720 and only select 1080i to be display. you can then hook up your hdmi cable again and it shoud be supported. Let me know if that works.
Posted on Dec 03, 2007
I can't see my or friend's messages in window. installed latest version and latest version of java
Some virus can cause this bug in Yahoo Messenger. Check your Internet Options, go to Security Tab, and see if there is a new item. Normal items there are Internet, Local Intranet, Trusted sites, and Restricted sites. If you see a new item, chances are you were hit by a virus.
To resolve this, open a registry editor (click Start, click Run. On the Open box, type: regedit and then press Enter). Navigate to the following key: HKEY_CURRENT_USER \ Software \ Microsoft\ Windows \ CurrentVersion \ Internet Settings \ Zones
There should only be 5 items there, numbered 0 to 4. If you see a different one, especially if you see items that shows up as box, try deleting it. (Backup your registry first). If you were able to delete that extra item, this might fix the bug, and you will be able to see the chat messages again in yahoo messenger.
Mar 08, 2011 | Yahoo Messenger
Plasma tv showing "Mode not supported" message
Apr 24, 2010 | Samsung PN58B860 58 in. HDTV Plasma TV
I have a 2006 Hitachi Ultravision 42 inch plasma
plasma tv units use a lot of power ,well into the hundreds of watts 9 some big screens use up to 800 watts to work)
I suggest that you consider a new led unit which uses barely any power and you will get a remote with it
Jun 24, 2017 | Hitachi UltraVision 42HDS52 42 in....
Deep sleep mode on digital tv
We turn off the TV. Turned it back on using the tv turner remote that comes with the set, we push the HDMI1 mode button immediately! Must do before it goes to Deep Sleep mode. You should not use RGB mode as this will cause the problem to repeat. (Vizo HD 50") Keep trying if doesn't work the first time. You have to be ready and quick to get the mode HDMI1.
Oct 28, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
My mother purchased a new 20 in plasma. It is set
You need to go to service mode. Here how you go - use Samsung remote off the TV then press Mute-1-8-2-Power. Tv then boost up the service mode which is you could fine the line - user reset or hotel mode or both. You can press the user reset. If there is hotel mode - check it and put it OFF. Good luck
Aug 12, 2009 | Televison & Video
Lost code book||type=CONSUMER||locale=ca_en||mode=gcs_text||item=Remote%20controls%20%20%20Universal%20remote%20controls&xsl=search_result_headers.xsl
start here to search for the remote you have
Nov 06, 2008 | Philips Magnavox Learning Universal Remote
Toshiba 42hp93
Press the MUTE button twice on the remote control, then press and hold the MUTE button, while pressing the MUTE button press the MENU button on the TV at the same time. This should get you into the service mode Good luck and be careful.
Oct 26, 2008 | Toshiba 42HP83 42 in. HD-Ready Plasma...
hi there, i have the LG 50in Plasma and just updated the channel connection by doing the following:
1. Make sure your remote is in "TV" mode.
1. Press the Menu button.
2. Highlight "Auto-program" (Should be the first item on the Menu)
3. Scroll over to "To Start" and press OK.
The TV will automatically search for all available analogue, digital and HD signals and may take a few minutes.
Once complete, it will return to the last program you were on and you will find all channels available.
To check the guide or the time, you need to press the "guide" button. Make sure your remote is in "TV" mode. Alternatively, pressing OK at any time shows you the time and channel that you are on.
Hope that helps!
Sep 20, 2008 | LG 50PX4DR 50 in. Plasma TV
Cannot install Quickverse 7 version from year 2000 because of Microsoft DAO.
Hi, I had the same problem and fixed it, (loaded my quick verse bible software by loading the software in SAFE-MODE. This mode stops the dao that is running. (probably micorsoft office at start up). This solution worked perfect....God bless
Sep 06, 2006 | Parsons QuickVerse 7 Essentials (fe11044)...
Samsung HP-R4252 42 in. Plasma HDTV Logo
719 people viewed this question
Jerry Greenberg
Jerry Greenberg
