Question about Clarke Power Products Clarke 40 Piece Variable Speed Rotary Tool Kit CT4009
Cant get replacement brass cleaning wheels - Clarke Power Products Clarke 40 Piece Variable Speed Rotary Tool Kit CT4009
    Problem Solver:
  • 19 Answers
Harbor freight....they have all those things...a rotary grinder is a rotary grinder, they are all the same
Posted on Jul 19, 2009
Remove steering wheel
if you cant get a puller you will need a brass hammer, take the nut off the middle of the wheel almost all the way bring the nut off so it is flush with the bolt sit in seat, put both your knees hard against the bottom of the wheel one hand on the top of the wheel pulling hard give the bold in the middle a good hit with the hammer till it pops free then remove nut and wheel.Howie
Apr 22, 2012 | 2002 Chevrolet Camaro
Driver side lower control arm how do i install new one
  1. Raise and support the vehicle with safety stands. Refer to Vehicle Lifting.
  2. Remove the tire and the wheel. Refer to Tire and Wheel Removal and Installation in Wheels, Tires and Alignment.
  3. Unload the torsion bar. Refer to Torsion Bar and Support Assembly Replacement
  4. Remove the wheel driveshaft nut and washer.
  1. Disengage the wheel driveshaft from the wheel hub and bearing assembly. Place a brass drift against the outer end of the wheel driveshaft in order to protect the wheel driveshaft threads. Sharply strike the brass drift with a hammer. Do not attempt to remove the wheel driveshaft from the wheel hub and bearing assembly at this time.
  2. Remove the stabilizer shaft. Refer to Stabilizer Shaft Replacement (RWD) or Stabilizer Shaft Replacement (4WD).
  3. Remove the shock absorber. Refer to Shock Absorber Replacement (RWD) or Shock Absorber Replacement (4WD).
85105731
  1. Remove the nuts and bolts securing the lower control arm to the crossmember and the frame bracket.
  2. Remove the lower ball joint stud from the steering knuckle. Refer to Lower Ball Joint Replacement (RWD) or Lower Ball Joint Replacement (4WD).
  3. Remove the lower control arm from the frame.
have fun and be careful wear always lens and gloves
Oct 21, 2010 | 2000 Oldsmobile Bravada
I have a polaris 500 atv after sitting for a couple of days the left front wheel acts like it is locked up. I can back up a few times and then it releases. I cant tell if it is the break or the hub
As it is a atv i expect the brake is binding try removing the brake calliper and checking the brake piston for rust or dirt,gently clean with brass brush dont damage the rubber seal though . Allso try removing the calliper before leaving atv if it sticks with calliper removed may be dodgy bearing in hub.
Jan 07, 2010 | Lego Creator Revvin' Riders, Motorcycles...
'01 Chevy Blazer transmission randomly switches from 2 to 4 wheel
Try this.My Blazer the same.Took the dash switch out, removed the back plate from the switch.Cleaned the four brass contact areas on the circuit board with a pencil eraser, then rubbing alcohol.Re-installed & works perfectly.
Sep 04, 2009 | 2001 Chevrolet Blazer
Cant unlock steering wheel to start car
I would chalk that up to old age and wear and tear. I expect that when you take the steering column apart you will find a lot of play in the linkage between the ignition and the lock. These will probably be dealer only items to replace unless you can find them in a scrap yard. It will probably be easiest just to remove the lock mechanism and leave it that way. Just make sure that everything else works before you put the column back together.You may also be able to shim out the play with some time and patience if you can't find parts. Copper and brass work the best. Hope this helps.
Aug 02, 2009 | 1983 Nissan Sentra
How do I replace a front wheel hub on a 03 Suburban 4X2?
remove wheel. remove brake caliper. remove rotor. diconnect abs wheel speed sensor connector follow black coated wire and remove it from its clips. remove 36 mm nut from axle shaft and make sure its free do not hit end of shaft with hammer as it can damage threads. use brass punch or cover with block of wood. next remove the three or four 15mm bolts from back side of hub and beat till it comes off carefull not to damage backing plate. reverse to install making sxure to clean rust out of hib before you install
Jun 11, 2009 | 2003 Chevrolet Suburban 1500
Changing a keyswitch
You need a steering wheel puller tool.Another way is to put the nut back on the shaft(so as not to damage the threads),prop your knees against the steering wheel using blocks at your feet,apply as much pressure as you can on the wheel pushing it towards you & then tap the center shaft with a BRASS hammer.Careful not to hurt the threads.Good luck,
ChevRev
Mar 24, 2009 | 1991 Chevrolet Caprice
Primer button bowl brass bolt and plastic.
what is plastic ? all there should be is a bowl , then small round gasket , then brass nut . if it doesnt go on you must have disturbed the bowl gasket ( black round )
Sep 19, 2008 | Garden
2003 trailblazer lt 4wheel drive
  1. Remove the tire and wheel center cap.
  2. Remove the drive axle nut.
  3. Raise and support the vehicle. Remove the tire and wheel. .
  4. Remove the brake rotor.
  5. Disengage the wheel drive shaft from the wheel hub and bearing. Place a brass drift against the outer end of the wheel drive shaft in order to protect the wheel drive shaft threads. Sharply strike the brass drift with the hammer. Do not attempt to remove the wheel drive shaft from the wheel hub and bearing at this time.
  6. Remove the wheel hub and bearing from the steering knuckle by removing the three bolts coming in from the back side of the knuckle.
Of course you may have to use a hammer to loosen the bearing from the knuckle.
Good Luck
Sep 05, 2008 | 2004 Chevrolet TrailBlazer
Clarke Power Products Clarke 40 Piece Variable Speed Rotary Tool Kit CT4009 Logo
87 people viewed this question
Top Clarke Power Products Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Clarke Power Products Saw Expert? Answer questions, earn points and help others
