Question about Technics Audio Players & Recorders
Technics SL-1700 Mk2, tonearm doesn't lower, cueing doesn't work
Hi, I own a Technics SL-1700 Mk2 and the tonearm doesn't come down anymore. When I press the cueing-button a purring sound starts, that doesn't stop if I push the button again.The cueing mechanism is not responding. How to proceed? Can you override the mechanism or is there something seriously wrong? Thx in advance for help!
There's a rubber belt or O ring that broke. I couldn't find one at Technics, so I took the old parts to the hardware store and found an O ring in plumbing parts that was very close. Been working for years just fine!
Eddie
Posted on Nov 30, 2010
Technics sl qd22
You can have any mechanical issue causing the tonearm to bind. For more information, please visit my website at audioserviceclinic.com.
Thank you.
Nov 25, 2013 | Audio Players & Recorders
Tone arm cueing problem on technics sl 1210
The turntable may not be level and consequently beyond the ability of the balance and antiskate adjustments to correct
Jun 26, 2013 | Panasonic Technics SL-1210MK2 Turntable
Tonearm doesn't automatically return technics sl-d 202
Hi, at the base of the tonearm (left side) you will will find a rubber grommet or hole. Insert flat blade screw driver. Adjust until tonearm is lifting at end of record. Cheers john.
Apr 09, 2013 | Audio Players & Recorders
He doesn't start anymore
I'm havin the same problem,
did u manage to work out what the fix is?
Dec 20, 2009 | Panasonic Technics SL-1210MK2 Turntable
Technics 1210 tonearm skates when cueing vinyl backwards
I've seen this on technics turntables before. Try tightening the screw on the arm.
May 20, 2009 | Technics SL-1210 Turntable
Tone arm cueing problem on Technics SL-BD27.
the auto stop mechanism needs adjusting
Apr 07, 2009 | Technics SL-BD22 Turntable
Tonearm lifter in UP position - how to fix
I have also had this problem with the same model turntable. I opened mine up and the problem seems to have been that the grease on the arm lift and cueing lever was gumming up the linkage between the two. (I suspect that my turntable hadn't been used in some time.) I managed to free up the parts by manually working the the arm lift (pressing it down) several times. I'm not sure that I needed to open up the chasis for this fix but it did help me to see what was going on. Good luck with yours.
Tim Orange
Mar 20, 2009 | Technics SL-BD20D Turntable
Technics SL 1600 MK2
Your tonearm is damaged. More than likely the bearings on the tonearm have been damaged. Unfortunately, there is no easy fix for this. You'll have to have the tonearm replaced, however, parts for the SL1600MK2 have been discontinued. The tonearm for the SL1200MK2 might fit it, but you will need to do some retro-fitting in order to make it work properly. Something only a qualified service center could perform.
Hope this helps some.
DIGITAL ANALOG THERAPY
May 29, 2008 | Technics SL-1200MK2 Turntable
Tecnics 1200 MK2 No sound.
It's more than likely your tonearm or your RCA cables. Does the sound come in at all? Try wiggling the RCA cables. If no sound whatsoever, then more than likely it's your tonearm, and will need to be replaced.
Tonearms for this model are available HERE, however, I don't recommend trying to replace this yourself, as it is rather complicated, and you could cause more damage to the unit.
- DJ PRO AUDIO
www.DJPROLAB.com
Mar 17, 2008 | Technics SL-1200MK2 Turntable
1,551 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
