Want to put a 1.5T Hard drive in my laptop.
How can i tell if my laptop will support a SATA1 and/or SATA2 Hard drive? Thanks in advance.
Basically, right now you can't put a 1.5tb disk in a laptop at all.
laptops use 2.5" disks which only go up to 500gb (i think 640 and 750gb ones are coming out around now, but you may have trouble finding them for sale right now.
the 1.5tb disks you see for sale are all 3.5" disks that will not physically fit inside a laptop chassis so the only way you could use one with your laptop would be externally with a 3.5" USB disk enclosure.
i imagine it'll be next year at the earliest before laptop hdd's will get that big, sory to disappoint.
Posted on Sep 26, 2009
    President:
  • 1,383 Answers
Yes check in bios when you power up press F2 or del key to enter in bios.
Then go to advanced sata option.
Enable it if you want to use sata.
Posted on Jul 16, 2009
How to connect a SATA2 HDD to a SATA1 motherboard?
It should work. If not, there are jumpers on some drives. Not a DIY task because it requires unusual skills. Does not always work in any case.
Jul 06, 2014 | Hitachi 1TB HDS721010CLA332 SATA2 U300...
Aspire one can not detecthard drive
Repair laptop hard drive is not detected
Solution 1
1. Open the hard drive cover (remove two screws)
2. Remove the hard drive screws, then slide the hard drive (see the arrows)
3. Wait 15 minutes, then plug the hard drive
4. Turn on the laptop.
Solution 2
1. Remove the hard drive
2. Clean the gold layer with a pencil eraser
3. Plug the hard drive, then turn on your laptop
Solution 3
2. Plug jumper on the hard drive
Solution 4
1. Remove the hard drive, plug the external cable.
2. Connect the hard drive to another computer, with USB connection
3. If the hard drive can be detected, eject the hard drive
4. Plug the hard drive to the laptop, then turn on
Intended to make the hard drive can work with the help of another computer
Solution 5
1. Remove the laptop hard drive
2. Plug the laptop hard drive to my PC.
SATA1 - PC hard drive
SATA2 - Laptop hard drive
3. Boot the computer from a PC hard drive
The purpose of using a PC computer main-board as drivers of the laptop hard drive.
I hope this information helps. Thank you for using FixYa!
Oct 15, 2011 | Acer Aspire One PC Notebook
I have k8-upgrade-NF3. I tried to connect two SATA CD-ROM to SATA1 and SATA2 ports but the computer restart constantly. The domada is: i can connect cd-rom and cd-burner on SATA1 and SATA2 matherboard?...
you need to change the BIOS setup. Go to the booting menu change the arrangement of your hardware.
1.Primary Disk (Hard disk) 2.CD/DVD ROM 3. Floppy 4.others
then save and exit. Your PC will reboot and MUST detect first your hard drive to proceed to your desktop..
I hope it will help you..
May 21, 2011 | Asrock K8UPGRADE-NF3 Socket754/nForce3...
You can tell by either checking the manufacturers site for the laptop specs, by looking at the existing drive if you're qualified to open it or by commenting back here with the required info, your Make and Model, so it's possible for us to look the info up for you if you're not sure how.
Chris
Jul 16, 2009 | Seagate 1 TB SATA II Hard Drive
New Hard drive
is it in 2.5 if it is 2.5 it will work but have to make sure that the drive can support large capacity drive
Jul 16, 2009 | Seagate Barracuda 7200.10 500 GB SATA Hard...
I would like to know if i can put a Seagate Barracuda 1.5 TB Internal Hard Drive on a laptop? Thanks in advance.
The answer is yes, if your BIOS will support a 500 G/B drive.
If you were running a 5400 and want to jump up to a 7200 NO PROBLEM.
If your BIOS supports SATA1 and 2.
You may have to use Disk Manager to setup the drive before hand.
Example, I am running a ASUS high speed M/B at home which only supports SATA1 and does not support SATA 2 drives.
The Speed in which I wanted was 100mb/sec
I had to negotiate down to half that.
It is fast for a SATA but not SATA2 fast.
Good luck, Check the specs. on your laptop and see what it will handle.
John Ray
john@johnrraycomputer.com
Readers, please rate your technician's
Jul 13, 2009 | Seagate Barracuda 7200.10 500 GB SATA Hard...
I can detect no SATA' HDD
The ECS PM800-M2 only supports SATA 1.0 hard drives. If you are using a newer SATA 3.0 hard drive, there is a jumper on the hard drive which has to be set to SATA 1.0 in order for the VIA 8237R chipset southbridge (which Is on your ECS PM800-M2) to recognize the newer SATA 3.0 hard drives. This Is applicable to all motherboards with the Viatech PM800 / 8237R chipsets. Note: the location for the SATA 1.0 / 3.0 jumper varies on each brand of hard drives. Also check If SATA Is enabled In the BIOS and select IDE mode.
Apr 23, 2009 | VIA ECS PM800-M2 PM800 P4FSB 800 Supports...
P4VM800 SATA HDD Problem Plz Help me!!!
Check your user documentation for the hard drive to see if it has a user-accessible jumper that will switch it to 1.5Gb mode. I know that Seagate/Maxtor drives have a jumper they refer to as Force 150 and Western Digital calls their jumper OPT1 Enabled. If this option exists with this hard disk, it should solve your problem.
Mar 21, 2009 | Asrock P4VM800 Motherboard
945GCT-M/1333 recognize Primary IDE Master as IDE 3 Master
Hello. Some motherboards set SATA1 as IDE primary master, for compatibility. Try connect the DVD RW to SATA2 or SATA3 Port.
Feb 26, 2009 | Computers & Internet
Sata unable to recognize my book 500gb
The A7V8X-LA motherboard only supports SATA1. Your new hard drive is likely SATA2 (SATA-II). You'll likely need to change jumpers on the drive to make it compatible with SATA1.
It's a tiny bit slower than SATA2 (okay, twice as slow). But, it's still faster than PATA (IDE).
David L. Burkhart
Burkhart Technology Services
http://www.BurkhartTech.com
Jun 22, 2008 | ASUS A7V8X Motherboard
Computers & Internet Logo
123 people viewed this question
David Payne
David Payne
