Question about ASUS Xonar DX Sound Card
Sound error..not detected - ASUS Xonar DX Sound Card
  • 702 Answers
If your system is running Windows XP, you can try the tips for fixing sound problems in Windows XP.
If it is Vista, similar steps are possible of course.
In most cases the right sound driver will fix these issues, but make sure there are no resource conflicts in the Device manager.
Jules
Posted on Jul 16, 2009
Error 231 E3
RFID Reader I/F Error An interface error was detected
with the RFID reader device.
01: communication error between
the RFID reader and the engine
PCB.
02: the transceiver circuit error of
the RFID reader.
03: communication error between
the RFID reader and the Tag
chip.
04: the RFID Tag detection error
(more than 4 chips).
Apr 07, 2014 | OKI B4600 Printer
My xps m1330 booths up stays on for like 20 to 30 mins. then shuts off. After it shut off if i press the power button it willbooth back up again but this time it will shut off in within 5 to 10 mins. I get...
Sounds like the fans need cleaned or replaced. If the board and or the processor get to hot they may actually throw an error code. Try cleaning it and making sure the fans are moving.
Aug 25, 2017 | Dell XPS M1530 Laptop
Sound card not detected
The Sound Card not detected is part of laptop. Download the Win 7 Sound driver. Unzip and run the setup.
http://www.samsung.com/us/support/owners/product/NP300E5A-A01UB
Oct 15, 2012 | Samsung NP300E5A 15.6 Laptop i3 2.4GHz 6GB...
Error 163 on oki c5500 printer
163 Toner Sensor Error, Color: Black An error has been detected in your printer's Toner Sensor.
1 Machine Check Exception A problem has been detected in the printer hardware
2 DSI Exception The printers main logic has attempted to look up an invalid address.
3 ISI Exception The printers main logic has attempted to read the next instruction, which has failed to execute for some reason.
4 Alignment Exception The printers main logic cannot access the memory for some reason.
5 Program Exception The printers main logic has issued an exception code.
6 Floating-point Unavailable Exception A floating-point instruction is executed when the MSR floating point enable bit is set to Disable.
7 Instruction Address Breakpoint Exception The printers main logic has attempted to look up an invalid address.
20 CU ROM Hash Check Error 1 CU ROM hash check error has been found. Check reproducibility if possible.
21 CU ROM Hash Check Error 2 The printers CPU has a checksum error in it's memory.
23 CU ROM Hash Check Error (resident) Seek service if restarting the printer does not correct the problem.
25 CU ROM Hash Check Error (DIMM2) Seek service if restarting the printer does not correct the problem.
30 CU Slot1 DIMM RAM Check Error An error has been detected in operation checks on the RAM in slot 1
31 CU Slot2 DIMM RAM Check Error An error has been detected in operation checks on the RAM in slot 2
35 Slot1 RAM Spec Error Check the specification and install in slot 1 RAMs supported by the product
40 CU EEPROM Error The EEPROM mounted on the CU board needs to be replaced
41 CU Flash Error The CU Flash needs to be replaced
43 Flash File System Version Mismatch Seek Service if restarting the printer and initialising the flash memory does not correct the problem
42 Flash File System Error Seek Service if restarting the printer and initialising the flash memory does not correct the problem
43 PS Flash File System Error An Flash Memory error has occured and the printer needs to be serviced if restarting the printer does not correct the problem
51 CU Fan Error The CU cooling fan needs to be replaced if restarting the printer does not correct the problem
70 Postscript Failure An error has been detected in your printer's Postscript Core.
72 Engine Communication Error A communications error has occurred between CU and PU boards.
73 H/W Overrun Detect An error has been detected in your printer's hardware input area.
74 F/W Overrun Detect Occurs when the firmware is unable to set video data in response to video DMA's data request.
75 VIC Limiter An error has been detected in your printer's
80 Parameter I/O Error An error has been detected in your printer's Input/Output area.
81 Parameter Consistency Check Error The EEPROM and flash memory reformatted and initialized.
102 Engine RAM Error An error has been detected in your printer's engine RAM.
103 Engine SRAM Error An error has been detected in your printer's engine SRAM.
104 Engine EEPROM Error An error has been detected in your printer's engine reading/writing the EEPROM at power-up.
105 Engine EEPROM Missing Error An error has been detected in your printer's Engine
106 Engine Control Error An error has been detected in your printer's Engine Controller.
122 Power Supply Fan Motor Error An error has been detected in your printer's Power Supply Fan Motor.
123 Humidity Sensor An error. has been detected in your printer's Humidity Sensor
124 Temperature Sensor An error has been detected in your printer's Temperature Sensor.
127 Fuser Unit Fan Error An error has been detected in your printer's Fuser Unit Fan Error.
131 LED Head Missing, Color: Yellow When yellow LED head connection cannot be detected
132 LED Head Missing, Color: Magenta When magenta LED head connection cannot be detected
133 LED Head Missing, Color: Cyan When cyan LED head connection cannot be detected.
134 LED Head Missing, Color: Black When black LED head connection cannot be detected.
140 Drum Up/Down, Color: Yellow An error has been detected in your printer's Yellow Drum
141 Drum Up/Down, Color: Magenta An error has been detected in your printer's Magenta Drum.
142 Drum Up/Down, Color: Cyan An error has been detected in your printer's Cyan Drum.
150 Drum Fuse cut NG, Color: Yellow An error has been detected in your printer's Drum Fuse.
152 Drum Fuse cut NG, Color: Cyan An error has been detected in your printer's Drum Fuse.
153 Drum Fuse cut NG, Color: Black An error has been detected in your printer's Drum Fuse.
155 Fuser Unit Fuse cut NG An error has been detected in your printer's Fuser Unit.
154 Belt Unit Fuse cut NG An error has been detected in your printer's Belt Unit.
160 Toner Sensor Error, Color: Yellow An error has been detected in your printer's Toner Sensor.
161 Toner Sensor Error, Color: Magenta An error has been detected in your printer's Toner Sensor.
162 Toner Sensor Error, Color: Cyan An error has been detected in your printer's Toner Sensor.
170 Upper Thermistor, State: Short An error has been detected in your printer's Upper Thermistor.
171 Upper Thermistor, State: Open Restart the printer. If the problem continues the printer will need to be serviced
172 Upper Heat Temp, State: High An error has been detected in your printer's Upper Heat Temp.
173 Upper Heat Temp, State: Low Turn the printer off to let it cool down, then restart the printer.
181 I/F Error, Loc. Duplex An error has been detected in your printer's Duplexer.
182 I/F Error, Loc. Tray2 An error has been detected in your printer's Tray2.
187 I/F Error, Loc. Control Pnale An error has been detected in your printer's Control Panel.
190 System Memory Overflow An error has been detected in your printer's System Memory Overflow.
191 Page Memory Overflow An error has been detected in your printer's Page Memory Overflow.
200 PU F/W download Check Sum Error Error during PU flash download
201 PU F/W Flash Write Error An error has been detected in your printer's PU F/W Flash Write Error.
202 PU F/W Flash Data Missing An error has been detected in your printer's PU F/W download Check Sum Error.
203 Engine Page Sequences IMAGACK Error An error has been detected in your printer's Engine Page Sequences IMAGACK Error.
204 EnginePageSequences IMGSET Error An error has been detected in your printer's Engine Page Sequences IMGSET Error.
2005 Oki Data Americas, Inc.
Sep 14, 2012 | OKI C5500n Printer
No sound
download a new software download detective all driver also fine
Aug 02, 2012 | Gateway 505GR PC Desktop
I have a JVC CA-MXB5 stereo. As soon as you push the cd button error shows up on screen. Everything else works.
If you have a CD loaded, and you get that error, it means the laser can't detect focus on the CD.
If the laser detects focus on the disc but the turntable motor doesn't spin up you still get that error. Sounds like the laser is the problem in yours.
Oct 04, 2009 | Audio Players & Recorders
Please solve My problem-fujitsu V1020 Lifebook formated Vista then setup windows XP P2. sound detect but show message Error Code and PCI not detect.help me please.thanks
you cant able to the vista sound to xp the driver the company will give you only vista driver cd so get the sound drive for xp - download more than 3 diffrent sound driver for your pci slot realtec audio from internet and install it and it may works.
Jun 10, 2009 | Fujitsu LifeBook Notebook
Try to use a recent Fedora LiveCD to test the sound card. If sucessful install from the LIveCD and problem solved!
Feb 20, 2009 | fedora Linux Operating System
Speaker is not detected
If you are connecting a 5.1 surrround sound rather than 7.1, have you connected the surround speakers to the surround left and surround right rather than surround back left and surround back right?
Nov 11, 2008 | Onkyo TX-SR703 Receiver
PEN DRIVE ERROR
sounds liek a corupt upper or lower filter for cdrom devices also in usb section of registry.
prety much.. remove upper and lower filters and retry. or u got acess denied to system registry sections.
Jul 14, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
ASUS Xonar DX Sound Card Logo
319 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
