Question about CucinaPro 150-25 Imperia Ravioli Attachment
I have a old Pasta Express X-2000 machine. During the extrusion process, it appears that the gears are slipping. It makes a terrible "banging" noise. Any ideas on how to fix it or who would do this type of repair?
2003 ford sport trac front grinding noise from drivers side when sharp left turn
go to the magicmechanic website and send him this--hes the best there is and will rply
Jan 19, 2015 | 2003 Ford Explorer Sport Trac
Loud banging during kneading
you are right.for further help check this link.
www.repairclinic.com
Aug 29, 2008 | Breadman TR875 Bread Maker
Counter weight on front load machine is crumbling to pieces and machine makes loud noises during spin cycle
Cindy, you might want to check the gears in your machine. I had a similar problem and it turned out that the gears are made of a plastic/nylon material and they deteriorate pretty easy, making the washer make loud noises. Took the guy who fixed mine about 20 minutes and then it was nice and quiet again. Good luck.
Nov 27, 2011 | Kenmore Washing Machines
The machine is making a banging noise and wont process.
HI
Banging noise is usually a broken brew drive gear. Usual cause is having the small knob in the bean hopper turned all the way to the plus + side and you get an overcharge that the brew unit can't compress and it breaks the drive gears. Its either going to have to be sent in or if your handy you might be able to replace the gears. They will havee to be timed once the gears are installed.
Jan 24, 2011 | Gaggia Syncrony Logic 74884 Espresso...
Loud banging noise during washing cycle. Sounds like agitator is slipping,then banging. No noise during spinning cycles.
Grab the agitator at the base and attempt to rotate it clockwise and counter clock wise. It should remain firmly in place. If there is movement the agitator spline is worn.
This is your Agitator:
http://www.repairclinic.com/Appliance-Parts?s=t-WBSR3140DW-%3d%3dc201
It does not come with the fabric dispenser. It has to be ordered seperately. You should be able to transfer you old one to the new one if you do have to replace the agitator.
Besides the agitator the drive bell can also be the source of the noise. It is located under the agitator.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-WBSR3140DW-%3d%3dc239i1195917&PartID=1195917
This part is the most likely cause of the noise.
Thanks for using FixYa.
Kelly
Mar 07, 2010 | GE WBSR3140DW Top Load Washer
Whirlpool Cabrio WTW6700TW1 that is making a banging noise
The Cabrio unfortunately has many problems. Your problem however is the four suspension rods. If you know someone who is handy it's not that bad to do yourself. Just need a little patience. There are two clips just between the top panel and the front panel. Use a screw driver and a flashlight to see the clips. Then using the screw driver, push in on the clips to lift the entire top panel. This can be difficult. Once open you should be able to see the four rods that support the tub. That's what you need. Hope this helps...
Jan 17, 2010 | Washing Machines
Looking for a manual for the ctc pasta express 3000
Did you know your machine had a safety recall:
- In cooperation with the U.S. Consumer Product Safety Commission (CPSC), Creative Technologies Corp. of Brooklyn, N.Y., is voluntarily recalling about 50,000 pasta machines to replace some of their lids. When the safety cutoff switch on the lid does not activate, consumers' fingers can be severely injured if their hand is placed into the mixing bowl.
CPSC and Creative Technologies are aware of 11 incidents of the machine unexpectedly turning on, resulting in nine injuries including cut, crushed and severed fingers.
The lid replacement program involves the Takka Pasta and Dough machine (model X1000), and the Pasta Express machines (models X2000, X3000 and X4000). Only pasta machines that have serial numbers up to 78209 are subject to this replacement program. The model and serial numbers are located on a label on the bottom of the machine. "Pasta Express TM by CTC" or "Takka Pasta and Dough by CTC" is on the front of the machine. The pasta machines are beige or white. Some machines have chrome-plated front panels. Through this voluntary recall, Creative Technologies will provide consumers with a replacement lid.
When you get in touch, you can re-order the manual.
Nov 26, 2009 | Kitchen Appliances - Others
I have a old Pasta Express X-2000 machine. During the extrusion process, it appears that the gears are slipping. It makes a terrible "banging" noise. Any ideas on how to fix it or who would do this type...
Hi, Mike Sorry I can't help you but I found this 12 year old information on the net about certain Pasta Express X-2000. In the event you can't get the machine repaired I've been looking for some of the dies that fit over the extruder. Sincerely, Gerry MHere's some recall info.FOR IMMEDIATE RELEASE November 25, 1997 Release # 98-032 CPSC: Jane Francis (301) 504-0580 Ext. 1187
CPSC, Creative Technologies Corp. Announce Recall to Replace Lids on Pasta Machines WASHINGTON, D.C. - In cooperation with the U.S. Consumer Product Safety Commission (CPSC), Creative Technologies Corp. of Brooklyn, N.Y., is voluntarily recalling about 50,000 pasta machines to replace some of their lids. When the safety cutoff switch on the lid does not activate, consumers' fingers can be severely injured if their hand is placed into the mixing bowl.
The machines are sold in cardboard boxes identifying the model of the machine. A photograph of the machine is on the front of the box.
Department stores, mail order catalogs and warehouse clubs nationwide sold the pasta machines from 1989 through 1992 for between $90 and $200.
The U.S. Consumer Product Safety Commission protects the public from the unreasonable risk of injury or death from 15,000 types of consumer products under the agency's jurisdiction. To report a dangerous product or a product-related injury and for information on CPSC's fax-on-demand service, call CPSC's hotline at (800) 638-2772 or CPSC's teletypewriter at (800) 638-8270. To order a press release through fax-on-demand, call (301) 504-0051 from the handset of your fax machine and enter the release number. Consumers can report product hazards to info@cpsc.gov.
Mar 25, 2009 | La Pavoni Imperia Pasta Maker-Maunal (for...
The spin bang all over the machine
is it actually spinning or jsut making banging noise. if just noise
sounds like a broken motor coupling( this machines equivelent to a belt. part number 285753a . mounts directly to the motor shaft and connects to the transmission, order a new one it installs between the motor and transmission,assy
Jan 16, 2008 | KitchenAid KAWS850LE Top Load Washer
CucinaPro 150-25 Imperia Ravioli Attachment Logo
1,469 people viewed this question
Top CucinaPro Kitchen Appliances - Others Experts
Tom Chichester
Robert Kulkofsky
Robert Kulkofsky
Are you a CucinaPro Kitchen Appliances - Other Expert? Answer questions, earn points and help others
