Question about Plumbing
When pump runs lights go out then come back on
1.When pump comes on lights dim and then brighten.
2. There is no suction from the pump.
3. Placed pump on it own circuit.
4. When pump cuts in lights get brighter.
5. This is a 1/2 hp pump
YOU HAVE A AIR LEAK
Posted on Aug 08, 2009
Dash lights come on with the headlights then shut off
Do you have a dimmer for interior lamps? Like a rheostat, a little wheel that you turn up or down to brighten or dim interior lamps. Usually the instrument cluster lamps brighten and dim the same way.
Can you brighten and dim the other interior lamps?
Apr 17, 2016 | Cars & Trucks
Buick Rendezvous Head Up Display
not sure about that one but there is a dimmer wheel by the light switch. move it up and down to dim and brighten the dask lights/cluster. wheel may need replacing. also work the lights on and off switch manually to see if there every thing works smooth or hopes from dim to brite.
Feb 16, 2014 | Cars & Trucks
COOLING FAN ISSUE
is the engine over heating. Fan issue doesn't sound like a problem. Check the filament for the high beam.
May 14, 2013 | 2001 Suzuki GSX-R 1000
My panel lights are too dim and won't brighten. I checked all the fuses and they are all working fine. I turned the dimmer knob all the way to the right and they still won't brighten. When I first turn...
Your alternator may be going bad. Once the car is running, your battery has done its job and the alternator takes over. The alternator is responsible for firing the plugs, running your lights, your radio, your heater/AC, and anything else electrical, as well as keeping your battery charged. If the alternator is on its way out (or even has a less than good ground), you may experience some lights dimming, or even choppy radio signal. If the alternator is already gone, and your car is running off of the battery full time, you will also get the dimming you describe, and sooner or later the car will not even start. Take your car to an auto parts store (Advance, or Auto Zone, etc) and ask them to test your alternator. This is a free service.
Nov 23, 2010 | 2005 Chevrolet Impala
Burning smell
Hi theres two things that could have made it start doing that 1 the whires have a short in it or 2 the motor has gon faulty. you might want to buy a new machine
Jun 07, 2009 | Bissell Lift-Off(R) Revolution(R) Turbo...
My pump is running however it's pressure is less than 10 psi and the heater on the pool will not run.
With the Jacuzzi Magnum pool pumps, low pressure is going to likely be cause by one of the issues below. Try these troubleshooting tips.
1.Pump not primed
2.Leakage of air into suction system
3.Impeller clogged
4.Valve in suction or discharge line partly closed or suction or discharge line partly plugged or too small. 5.Plugged basket in skimmer or hair in lint strainer.
6.Dirty filter.
Jun 06, 2009 | Jacuzzi MAGNUM POOL PUMP 1-1/2 HP MAGNUM...
Lights dim and then brighten
This is your Alternator. Check the Battery Cables for Tightness in Addition.
Jan 12, 2009 | 1997 Nissan Pickup
Lights dimming and brightening on 2000 Chevy Venture
2000 chevy venture run good but my lights flickers and have to jump. After I jump the van and put my meeter on the battery its reading 14.volts at idle. I can drive around to store cut the van off come out it starts fine leave it overnite and it don't started.
Nov 21, 2008 | 1999 Chevrolet Venture
Click in circuit board Light in Icemaker dim bright Warm both sides
I didnt understand what you meant by refer(refrigirator???) and IM..??
Jun 26, 2008 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
Plumbing Logo
37 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
