Question about Nokia N73 Cellular Phone
I put a boost sim card in my phone and it said put code in and i did and it screwed up my phone my imei is :351767/03/158251/2 My Phone is a Samsung E2510 thankyou
How do I get my Boost Mobile SIMs card to work in a AT&T Galaxy Samsung phone
Hi Chad if you're putting your sim card into a different cell phone make sure the samsung isn't locked to another service provider
Mar 24, 2016 | Samsung Cell Phones
I put my sim card on a samsung impression & the phone asks for a phone lock code ?
Hi you can use codes to unlock the mobile .to get the unlock codes visit here
http://www.unlocking4free.com/
Here they ask the following details before rendering the unlock codes they are
1. Mobile model
2. Country from where you brought the mobile
3. Provider to which the mobile is locked
4. Imei number of the mobile
Finally they will send you the unlock codes at free of cost.once
you entered the code in your mobile as for the instruction
given by them .your mobile get unlocked and it accepts any network sim
to get the IMEI: Unlock Your Samsung Sgh-t528g Mobile Phone Via IMEI. Your phones IMEI is your unique number that is given to each phone. For each IMEI there is a unique unlock code that once entered into your Samsung Sgh-t528g phone will enable you to use any compatible sim card. You can get theIMEI for your phone by entering*#06# into your Samsung Sgh-t528g keypad. You will only need 1 unlock code to enable you to use any sim card in your phone and enable it to be "network sim free".
you can also try going to this site:http://www.foneszone.co.uk/unlock_codes/Samsung/Sgh-t528g.php
though this site may not guarantee a free service:
Sep 06, 2011 | Samsung SGH-A877 Impression Cell Phone
Can i use my boost sim card for a samsung propel
You can if you get your phone unlocked, if its currently locked to at&t get the imei number from underneath the battery & call at&t (have imei # ready) 1-800-331-0500 and ask them to help you out with a FREE unlock code & they will give you the steps and then you can use it with boost sim card. Good luck
Jul 06, 2010 | Samsung Propel A767 Cell Phone
Can you please help me unlock my samsung solstice Imei: 357044035137139 thanks....
hi try this
Samsung SGH-X600 Turn off the phone. Put a non-accepted SIM Card and turn it on. Type *#9998*3323#. Press Exit. Choose menu #7. After phone reboots type *0141# and hit the Call button. Turn off and insert another SIM Card. Turn on. The code is 00000000. In newer phones: #*7337#
May 18, 2010 | Samsung SGH-G600 Cellular Phone
I have a boost mobile I465 and i wanted to use with nextel but it asked it me for a special code
When you place a new or a existing SIM card from another phone provider into your mobile phone and it asks for a Security Code then :-
This phone is locked to the original mobile phone provider. You need to contact this mobile provider to ask for the unlock code (Security Code) for this phone. You need to provide proof of ownership etc and the phone's unique IMEI number which is located inside the phone under the battery. They use this number to generate the unlock code for your phone.
They should provide you with instructions on how to enter this code into the phone.
Once you unlock the phone, then you can insert a new SIM card in this phone or sign up with another phone provider using this phone.
You could ring the phone provider and ask for the unlock Security Code because you are going overseas and wish to use your phone with a prepaid SIM card from another country. This maybe a free service.
The other way to get your phone unlock is to use a phone unlocking company on the Internet, they usually charge a couple of Dollars for their services. Use Google and search for "Security unlocking code” companies in your area.
You can also try this WEB site :-
http://www.mobileunlockguide.com/mobile-phone/
The IMEI number is unique the each mobile phone.
The number is printed on the label under the battery.
You can also get the IMEI number by entering this on your phone
*#06# It will then display your IMEI number and you may also get a unique global serial number. Your IMEI number should be 15 digits
Jan 30, 2010 | Motorola Mobility Clutch i465 Cell Phone
I'm trying to transfer my Boost sims card to a Tmobile Samsung Behold but it asks for a network code? My IMEI for the Behold is 35191503181090/0 03
Boost Mobile runs on an IDEN network where tmobile runs on a GSM network. Unfortunately the boostmobile sim card will only work in nextel and boostmobile branded IDEN phones.
Dec 09, 2009 | Motorola Mobility RAZR V3
Subsidy code motorola i835
When you place a new or SIM card from another phone provider from the original phone contract then it asks for a Security code.
Your phone is locked to this mobile phone provider. You need to contact this mobile provider to ask for the unlock code (security code) for your phone. You need to provide proof of ownership etc and the phone's unique IMEI number which is located inside the phone under the battery. They use this number to generate the unlock code for your phone.
Once you unlock the phone, then you can insert a new SIM card in the phone.
Nov 21, 2009 | Motorola Cell Phones
SAMSUNG E250i sim crash problem
hi, don't panic! You mobile phone is fine, problem is with the sim card. Try inserting sim card in some other phone (Try Nokia) it will definitely work. If you dont hav different mobile phone then carry your sim card to customer care and they will change the same and give you duplicate sim. They may charge something for duplicate sim card.
Aug 14, 2009 | Nokia 1100
Can i put the sim card from my boost mobile phone
You can use this sim card only if the blackjuack was issued by Boost Mobile also or if The blackjack is an "unlocke" phone.
May 12, 2009 | Samsung Blackjack SGH-I607 Smartphone
Need Boost SIM card to work in Nextel Motorola Buzz+ ic602 phone.
I called Boost support about the same issue and I was told that that particular phone and any other Ic series phone by motorola will not work with Boost Mobile. There was also a few other phones that will not work. Try calling thier support line and requesting the list of phones that won't work. Good luck.
Mar 07, 2009 | Motorola Mobility ic602 Cellular Phone
Nokia N73 Cellular Phone Logo
61 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
