Width is short
I have a problem to increase the width of my PC screen. when i use menu to adjust it it already showing maximum, but screen from both side is half inch short. i don't know what to do now. please help
    Problem Solver:
  • 7 Answers
You will need to 'Auto Adjust' your sreen
Posted on Jul 16, 2009
My Acer 22" wide screen
change the resolution on the pc to 1024 x 1024 and then increase one size bigger each time till you find the correct one. Click start > control Panel > display settings then click settings change it in there (XP)
Apr 17, 2011 | Acer Computers & Internet
Tip
How to Increase your error undo ability on Adobe Photoshop CS2
By default this is set to 20 which in my experience is not enough you can increase this to a maximum of 99 however 50 should give you what you need under normal use.
Press <CTRL> + <K> to get to the General Preferences.
It is a good idea to save the adobe file every couple of hours or so with a different incremental number of the same file name, this will ensure that you don't loose your precious work.
Also press <CTRL> + <8> to get into the Memory and Cache screen whilst in the previous menu to set the Maximum Memory for use with Photoshop to about 70% of you available RAM
With 1GB of RAM this works out to be 635MB as about 100MB is already used for system processes running in the background.
on Jan 06, 2010 | Adobe Photoshop CS2 for PC
Cannot get rid of stitch width safety get double beep
In my case the problem was an error in the User Guide.
Press SET four times so that it displays SET 4. At the bottom right of the screen, where the User Guide shows a blank area, there is a setting for the maximum stitch width. If this is set to 0.0 you can only stitch straight. Change it to the other setting, typically 6.0.
Now go to ADJUST. At the bottom of the screen, the middle control is the actual stitch width, which you can set anywhere from 0.0 to the maximum. Set it to whatever width you want for the zigzag.
Oct 07, 2010 | Husqvarna Designer I
Unable to adjust the settings for brightness and contrast .
To adjust the display settings:
1. Press the flywheel control. The main menu appears.
The current display settings appear across the top of the main menu.
2. Rotate the flywheel to highlight an option. The name of the
highlighted option appears in the center of the menu.
3. Press the flywheel control to select the highlighted option, then
rotate the flywheel to adjust it.
Some options can only be enabled or disabled. There are also some
options that contain additional menus.
4. Repeat Steps 2 and 3 until you have made all your changes.
5. Rotate the flywheel control until Exit is highlighted, then press
it to exit the OSD control system.
OSD OPTIONS:
Contrast increases or decreases display image contrast.
Brightness increases or decreases display image brightness.
Horizontal Size increases or decreases the width of the display image.
Horizontal Position moves display image to the left or right side of
the screen.
Vertical Size increases or decreases the height of the display image.
Vertical Position moves display image to the top or bottom of the
screen,
Pincushion curves the sides of the display image inward or outward.
Trapezoid increases or decreases the trapezoid distortion of the
display image.
Degauss removes magnetic discoloration from the display image.
Recall returns most options to the original factory default settings
if the monitor is currently using a preset video mode. (See the “Video
modes” section in this guide for information about the factory preset
modes.)
Advanced Option opens the Advanced Option menu. Color opens the Color
Manager menu.
Language changes the display language for the OSD control system.
User displays information about the monitor’s preset modes.
OSD Manager moves the OSD control window on the screen.
Exit closes OSD control system.
Jun 21, 2010 | Gateway EV 910 19" CRT Monitor
Dynex 19 inch tv used as pc monitor; the pc display is bigger that the width of the viewable screen which cuts off about 1/4 inch on each side making it difficult on some things to shut down since the...
\http://www.retrevo.com/support/Dynex-DX-LTDVD22-TVs-manual/id/23122dj497/t/2/
Above is a manual link. usually you use multiple presses on the buttons to get to the menus. One button, is menu, the others are for up.down & left/Right. The same as for Horz Posn. You press the menu, use the L/R buttons to go to the menu item, then up and down to + or - the setting.
have a look at the manual.
Apr 23, 2010 | Televison & Video
Enlarge screen showing.there is screen not being
You need to expand your screen size with the buttons on the monitor, or increase your screen resolution, to a larger size, I think you need to adjust your monitor with the menu, +, -, buttons on monitor.
Feb 21, 2010 | Computers & Internet
Contrast and Brightness require adjustment
hi im josh in cebu phils. Maureen may i help you? If it happened yesterday that the contrast box keep on coming. there's a problem in your monitor.so try to check the buttons if covered with dust cleaning may solved the problem.Maureen if you have the manual use it in adjusting the resolution and if you dont have try to press the button mark + or increase just press both of the to the brightnest as posible so that you may be able to proceed another action. thats all for now.hope i helped you.good luck.
Feb 26, 2009 | HP Compaq 1720 (Carbon, Silver) 17" LCD...
Aspect ratio
increase the resolution to the maximum then check
Apr 17, 2008 | ASUS LCD Monitor
Dell m992 monitor screen width
The link below is a Digitally signed M992 monitor driver. http://support.us.dell.com/support/downloads/download.aspx?c=us&cs=19&l=en&s=dhs&releaseid=R44148&formatcnt=1&libid=0&fileid=51992 Also try upgrading to the latest ATI software and drivers. You can also try and change the frequency refresh rate to 75mhz. It in the Control Panel under 'Display' and tab 'Monitor'. It shows a list for frequencies you can try.
Oct 02, 2007 | Dell M992 19" CRT Monitor
Width problem
To have unlock your control (auto-adjust ...) you have to hold down the "menu Key" for about an 10 seconds. This will unlock your monitor! peroludiarom@abv.bg
May 30, 2006 | Samsung SyncMaster 753S 17" CRT Monitor
Computers & Internet Logo
110 people viewed this question
David Payne
David Payne
