Question about kawasaki Full Suspension Mountain Bike Men
Z1000 1979 only runs on choke dont run on tickover
Kawasaki z1000 1979 only runs on choke dont run on tickover and is running rich
    Problem Solver:
  • 12 Answers
Carbs need to come off and pilot jets need clean!
Posted on Jul 22, 2009
Why does my 98 Polaris Indy 500 snowmobile fall on its face after its warmed up runs fine when you first started
'falls on its face'?
Did you disengage the choke? The choke is there only for tickover running and will choke (literally) the engine if you use it when the engine is hot. It reduces airflow and increases fuel.
Jan 27, 2016 | Winter Sports
Mower running on full choke?
I installed a fuel shut-off. To solve my problem.
Apr 09, 2014 | Mtd Garden
Thundercat won't run without full choke
is airbox and filter all good no leaks, could be blocked small jet in carb, will it run ok higher in rev range
Mar 09, 2013 | 1995 Yamaha FZR 600
I have a 1998 kawasaki 1500 classic that runs rich to the point where the fender is turning black. Riders behind say they smell strong odor of unburnt fuel. Bike idles smoothly and does not fog black out...
The easiest way to tell is have a look at the spark plugs and see what colour they are.
The should be a light brown, if black then you are running rich and will need to adjust your carbs.
Please dont forget to vote this answer was helpful.
Many thanks
Mar 04, 2011 | 2003 kawasaki VN 1500 Vulcan Classic...
Replaced head gasket bike runs on tickover smokes a lot and seems to b burning the engine oil and will not rev
Try a thorough carburetor cleaning. If the carburetors are not set correctly, are dirty, and feeding an overly rich fuel mixture (malfunctioning choke, or stuck open float needles) this can cause smoking and poor acceleration. If oil and anti freeze got into the exhaust during the rebuild that could also be a source of some of the smoke . Only a long drive will take care of that.
Feb 17, 2011 | Honda CR 125 R Motorcycles
1200 zrx. starts but sounds like only running on 2 cylinders cuts out if you put choke of ?
Pull the plugs, if they are black dry and sooty those cylinders are running too rich which may be why it's cutting out when you put the choke on, it's getting too much fuel.
If they are wet and smell of gas you have no spark to those cylinders.
If it's carbuerated, then your idle jets or main jets are possibly clogged if the bike has not been run in awhile.
Could also be the coil is not firing to those two cylinders, check for spark first then check compression.
Check your choke cable adjustment also to make sure it's working properly.
Oct 18, 2010 | 2000 kawasaki ZRX 1100
Hi I recently bought a Kawasaki kdx 80.I've been riding it for about a week and has been fine,but a few days ago I filled the tank with premix 35:1 I think and not saying that's what did it but since then...
Black dry deposits are indicitive of a very rich mixture. On your two stroke, rich is a asset but you can go too rich. It sounds like for some reason you're getting too much fuel.
I think I ran into something like this before on a Kawasaki 80. Check the screws that holds the choke plate inside the carb. They will come loose and allow the choke to close on you while riding the bike. If the screw comes out, it will go into the engine and cause serious damage. If the screws are loose, them out one at a time and put a drop of Loctite 271 (red) on them and reinstall them.
Check the float and the needle and seat to make sure that you don't have any trash in the needle and seat. Also check your tank vent. If the tank builds up vacuum, you could be running out of fuel. Sounds funny that you can be running rich but run out of fuel. The problem is that you run out of fuel so quickly that the carbon from the rich mixture doesn't have time to burn off.
Good Luck
Steve
Aug 25, 2010 | kawasaki KDX 125 Motorcycles
Kawasaki prairie 360 atv spits & sbuters at wide open throttle & when you gas it from a dead stop but runs fine in between i have already cleaned the carburetor any ideas off what could be my...
its your choke. when the choke is to the left it will sputter around. try moving the choke completely to the right. mine does the same thing u just have to run the choke on the right side. i dont know if its supposed to be on the left or right but if u push it ALL the way to the right it should be fine. my kawasaki 360 prairie is pushin 55 mph so i think i have it set up right.- Kyle
Jul 23, 2009 | kawasaki Quad Bikes
Kawasaki GT 550 - erratic tickover
Put a carby kit through it and clean, inspect and blow all ports through, check intake rubbers for any leaks, (pin holes can change air fuel ratio) Especially check for obstructions in your idle/bypass jet, do the kit first so you know its right, then tune your idle mix until steady.
Feb 24, 2009 | 1992 kawasaki GT 750
kawasaki Full Suspension Mountain Bike Men Logo
302 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Wayne McNeil
Phillip Edwin
Level 1 Expert
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
