Question about HP Color LaserJet 4650DTN Printer
HP laserjet 4650 with 'phantom' paper jam
Hi, My HP colour laserjet 4650 dtn is claiming that it has a 'jam in the paper path' but after thorough inestigation (finding no jammed paper) , following all instructions the printer has given me and even trying the hallowed 'turn it off and then on again' it still refuses to work. Any advice? cheers
    Problem Solver:
  • 9 Answers
Hi , I had similar problem,the printer memory is locked on that last transaction feed,
either. check all copy transactions are deleted.you may not reolise you have 3 or 4 still programmed for shedule.
un-install the printer from your pc
the re-install shuld clear it.
set - printer to default mode
you may find your printer works fine on a friends pc, try all or either of above good luck colin leeds
Posted on Jul 16, 2009
Hp Color Laserjet 1600 says Jam in tray 2 bt there is not paper jams
Open the paper feed area and the printer, examine the paper feed path and make sure there isn't a page or piece of paper jammed in the path somewhere.
Aug 21, 2014 | HP Color LaserJet 1600
I have an HP CP2025 and when it goes to print it says there is a jam in tray 2 but there are no papers stuck, no debris, nothing. It just tries three times to pick up paper and then says there is a jam....
This is called a phantom paper jam and is caused by the printer not being able to grab the paper and feed it into the paper path to print on. There are paper pickup rollers right above the paper tray and when they get worn down they can not grip the paper so they slip. The printer thinks the paper is jammed because it never arrived in the printer. These rollers are user replaceable and come in a kit called RK-CP2025, they are available here:
http://www.ccl-la.com/catalog/product_info.php?products_id=318
I hope this helps,
BuddyMc
Mar 28, 2013 | HP Laserjet Cp2025n Printer
Hp cp3505 13.20.00 error
I'd recommend doing a thorough search with a flash light. You also might need to do some minor dis assembly to find pieces of paper. Another suggestion is to clean the paper path sensors with canned air. Lastly check all pick up rollers and make sure they are textured and have no smooth or bald spots. #1 cause of jams is bad rollers.
Jul 13, 2012 | HP COLOR LASERJET CP 3505 N PRINTER
My HP4100 DTN is continually having paper jams for no obvious reason. What can I do to resolve this? (I mean, I know how to resolve the jams, but how can I make sure it does not jam all the time)
Old age printer, prepare to replace the parts.
Step 1: Clean all paper path sensor, replace paper pick up rollers, seperation pads, check with out duplexer unit..
Step 2: Even paper jamming replace fuser assembly..
Step 3: Check with duplexer unit, clean deolexer sensors & rollers..
Nov 23, 2010 | HP LaserJet 4100dtn Printer
I have a total of 10 HP Color LaserJet 4650 printers, and 7 of them have the following problem: they jam at the fuser whenever a full-color picture, photo, or slide is sent to print (especially ones with...
This jamming has to do with third-party toner cartridges being used. I had this problem using Xerox toner cartridges and found that I would have no jamming if I used at least 2 hp-brand toner cartridges and the rest Xerox. I then used a different brand of 3rd party toner cartridges that would not jam as long as just the black cartridge was a genuine HP black toner cartridge. This issue has been confirmed even by the manufacturers of the generic toner cartridges. Hope that helps!
Oct 15, 2009 | HP LaserJet 4650 Color Printer
My hp laserjet 1150 series stops printing after a paper jam
you probably have a piece of paper inside printer or you have damage a paper sensor path while removing jammed paper.
Jun 22, 2009 | HP LaserJet 1150 Printer
Error 13.10 paer jam in HP laser jet 5100 DTN
HI ayyasamyr:
This your problem.
13.10 PAPER JAM The event log message for a paper-delay jam in the duplexer is 13.10.
1. Check the duplexer and the rear area of the printer for obstructions or damage.
2. Check PS1701 and PS1703 in the duplexer for correct operation. Replace the
duplexer if a sensor is defective.
Hope this helps
May 21, 2009 | HP Office Equipment & Supplies
PAPER JAM HP C4280
Hello sir; seems like your paper jamming in fusing unit, ok, her is the way, open the back cover, you may see have two blue handle on each side, lift them up then open the paper guide and remove the paper.
Apr 28, 2009 | HP LaserJet 4650 Color Printer Manual...
Instructions for replacing Paper Pickup Assembly on an HP 4650
Try this website. www.feedroller.com. On there, if you go to HP, there's a lot of service manuals you can download,one of them being the 4600/4650. This will assist with every aspect of removal and replacement
Feb 18, 2009 | HP LaserJet 4650 Color Printer
Hp laserjet 4650 crumples leading edge of paper
When you open the paper tray assembly you will see that on each side there is a silver bracket on each end of the paper tray that the paper sit under. You can bend these away from the paper in a sidways just a little and that will fix your problem. The paper is hanging on these plates as it feeds and is bending the paper as it feeds.
Oct 01, 2008 | HP LaserJet 4650 Color Printer
HP Color LaserJet 4650DTN Printer Logo
264 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
