A4Tech not compatible with YM v.9
I check this requirments http://help.yahoo.com/l/ph/yahoo/messenger/messenger9/webcam/mstacamreq.html
  1. Under “Color Space/Compression:”, choose one of the following formats:
    • RGB 24 (our recommendation)
    • I420
    • IYUV
    Note: If one of the options above isn’t in the list, then your webcam is not compatible with Yahoo! Messenger.
''I dont have those RGB, I420 and IYUV'' i do have MJPG
    President:
  • 627 Answers
Posted on Jul 16, 2009
If I will be using my web cam I have this error message. Error 502 - Bad Request The server could not resolve your request for uri:...
There's no problem with your webcam.Its the yahoo messenger error. I recommend you reinstall the yahoo messenger and reconfigure the webcam to yahoo messenger. By the way your error is an application error online when yahoo messenger cannot process your request online because of a broken server/heavy traffic via internet.
Feb 01, 2011 | A4tech PK-635 Webcam
I've been told to enable a webcam online by pointing the browser at an IP? address. How do I do that? Do I go http://www.192.168 etc
In order to use a webcam, it's required to configure it in the applications with which you want to use it.
For example, if youi want to use the webcam with Yahoo messagener then you can configure it with messenger.
First, check if the webcam is compatible with Yahoo messenger. You can use the link given below to check the compatibility requirements.
http://help.yahoo.com/l/in/yahoo/messenger/messenger9/webcam/mstacamreq.html
You can also use Internet Explorer to test if your webcam works with Yahoo! Messenger? using the link given below. Open the link given below after connecting the webcam to the Computer and turning it ON:
http://help.yahoo.com/l/in/yahoo/messenger/messenger9/webcam/mstatestcamie.html
check out the link given below to start a webcam conversation:
http://help.yahoo.com/l/in/yahoo/messenger/messenger9/webcam/mstastartcam.html
Nov 09, 2009 | Computers & Internet
My webcam cant use in my ym , its all black but in my pc its work,, only in my ym
Its good practice to disconnect and re-connect your webcam before you start - if you have been using it elsewhere the Yahoo software may have difficulty in locating it. Mine, I just unplug it from the USB and plug it back in, if yours is integral with the computer you will have to re-start the computer, unless the software has a feature for this.
Of all the chat programs, Yahoo is the most painful software to set up but if you follow these instructions you should be ok.
INTERNET CONNECTION
Webcam connected
Open messenger - on top toolbar. Left click ( > ) Messenger > Preferences > Connection - Select 'no proxies' or 'connect direct to the internet' depending on the version of messenger you have
make sure your internet connection and country are correct in the lower two boxes > Apply > OK
TESTING
> Messenger > My webcam - the warning panel will launch, click 'OK' and your webcam will start. You should be rewarded at this stage with your happy smiling face.
DEFAULT
With webcam still running > Messenger > Preferences > Webcam > Camera Source - set your webcam as default using dropbox. > Camera Settings - adjust settings to suit. > Apply > OK
Take a note of any additional software, if you have multiple choice for Camera Source, you may wish to uninstall any redundant webcam software later to prevent conflicts
PERMISSION OPTIONS
> Messenger > Preferences > Webcam - make your selections ( who you will allow to view you) > Apply > OK
IN USE
When you are both on line and wish to show your webcam > Actions > 'Invite to view my webcam'. This will launch an invitation on your contacts screen when they 'Accept' your webcam broadcast will start- There can be considerable time lag ( 1 minute) before they see you, so dont be too impatient ( You can check the status on the bottom left of your webcam panel. You can 'drag and drop' the frame to a convenient location by grabbing the top border.
There is a shortcut ( webcam icon ) down by your pic as well
Your contacts needs to configure their connection the same as above or they may get a "webcam not connected" message
If you complete the above and still have problems - check to see if your cam is compatible with Yahoo
YAHOO SPECIFICATION
To find out what the requirements are for messenger webcams, check out the following.
http://help.yahoo.com/l/uk/yahoo/messenger/messenger9/webcam/mstacamreq.html;_ylt=AghoQIvxhmhcugo.AOaNKaokPCV4
Aug 23, 2009 | Logitech QuickCam Connect Webcam
Server busy, close the window and try again later
Yahoo software is not noted for its generosity regarding webcams
You need to track what is happening during transmission. From the webcam frame menu click 'webcam' click 'statistics' from here you can see your frames per second. Do a few tests while broadcasting adjusting the slider (click 'file' click 'preferences') to improve quality ( at the expense of speed). If the fps drops to 0.0 your picture will be frozen.
You can also adjust your camera settings from here
Depending on your resources - internet speed - memory etc, will dictate the fps. The object of the exercise is to achieve maximum quality with a reasonable fps. Personally, I found the fps very erratic and about 0.0 to 3.0 with later mods the highest I could achieve was a modest 0.0 to 6.0 you may do better.
carry out the Yahoo mod to the registry
http://help.yahoo.com/l/us/yahoo/messenger/messenger9/webcam/mstacamfix.html
Download the microsoft software
http://help.yahoo.com/l/us/yahoo/messenger/messenger9/webcam/mstatestcamie.html
The webcam should now be controlled by VFM ( seen at the bottom of the statistics window)
Finally do your tests again, I transmit my image as 'small' ( 'webcam' > 'image size' ) and the contacts use 'Zoom' > '200%' to restore. this is to preserve what little resources I have.
Aug 09, 2009 | Labtec 961307-0914 Webcam
Usb webcam is not working in yahoo messenger
here is a link to test your web cam with yahoo messenger.
http://help.yahoo.com/l/us/yahoo/messenger/messenger9/webcam/index.html
Aug 08, 2009 | Computers & Internet
Your instruction for Messanger 9 did not work
Download the manufacturer's software ( by using the CD or from their website )
Once your webcam is working on your computer,you can configure it to Yahoo Messenger.
INTERNET CONNECTION
Webcam connected
TESTING
DEFAULT
PERMISSION OPTIONS
YAHOO SPECIFICATION
http://help.yahoo.com/l/uk/yahoo/messenger/messenger9/webcam/mstacamreq.html;_ylt=AghoQIvxhmhcugo.AOaNKaokPCV4 Any problems - click on my avatar and message me
Jul 20, 2009 | HP KQ246AA Deluxe Webcam
Cannot set up driver for web cam put disc in cd-rom & wizard will not install hardware says it is not compatable i do not know what brand the web cam is it was given to me with no box just the cam & disc...
http://help.yahoo.com/l/us/yahoo/messenger/messenger9/webcam/mstacamreq.html
Use this link from Yahoo Messenger help to download AMCap its a little bit of software that checks to see if a webcam is compatible to Yahoo Messenger. Make sure your webcam is plugged in and save it to your desktop. The link you want on the page is "click here"
The other suggestion I have is to find someone with Vista and is willing to help you. I have Vista Home Premium and I can plug any webcam into my USB and it goes off on a search for software.
May 01, 2009 | Computers & Internet
Acer webcam
You need to click on [Start] then click on [My Computer] and then [Acer Crystal Eye Webcam] will show up then click on the [Camera]. If this does not work then it could be that the cam driver needs reinstalling or maybe faulty. Take it back to your dealer!
Jan 09, 2009 | Yahoo Messenger
Yahoo messenger - Webcam is not connected
You cannot access camera source until the webcam is running in Messenger - try setting it up from scratch
1) The webcam is working outside of Messenger
2) Reboot webcam by unplugging the USB connection and inserting it again - its important if its been used elsewhere and prior to chat.
BODY,.aolmailheader {font-size:10pt; color:black; font-family:Arial;} a.aolmailheader:link {color:blue; text-decoration:underline; font-weight:normal;} a.aolmailheader:visited {color:magenta; text-decoration:underline; font-weight:normal;} a.aolmailheader:active {color:blue; text-decoration:underline; font-weight:normal;} a.aolmailheader:hover {color:blue; text-decoration:underline; font-weight:normal;} YAHOO SPECIFICATION
Once you have your webcam working outside of Yahoo Messenger you have to configure it to messenger CONNECTION
Open messenger - on top toolbar > messenger > preferences > connection - select 'no proxies' or 'connect direct to the internet' depending on the version of messenger you have
make sure your internet connection and country are correct in the 2 lower boxes > apply > ok TESTING
> messenger > my webcam - warning panel will come on click 'ok' and your webcam will launch. DEFAULT
With webcam still running > Messenger > Preferences > Webcam > Camera Source - set your webcam as default using dropbox. > Camera Settings - adjust settings to suit. > Apply > OK PERMISSION OPTIONS
>messenger > preferences > webcam - make your selections about who you will allow to view you
IN USE Your contacts may need to configure their connection the same as above or they may also get a "webcam not connected" message
Jun 16, 2008 | Logitech QuickCam Express Web Camera
Computers & Internet Logo
126 people viewed this question
David Payne
David Payne
