Question about Canon Pixma MP480 All-In-One InkJet Printer
Canon MP480- 5011 - Printer Error Has Occurred After Scan/Prt
Full text of message - 5011 - Printer Error Has Occurred. Turn of power then back on again. If problem persists, see the manual.
This is almost new printer/scanner. Error showed up on LCD after successfully scanning/printing color document.
Tried powering off/on many times. Disconnected both power and USB cables - error returns every time.
Interior check shows no paper jams or missed packing materials.
Tempted to try reinstalling drivers; except that this error occurred when I used printer/scanner as a standalone copier.
Anyone know how to fix this? Thanks!
  • 5 more comments
  • Anonymous Mar 13, 2014
    I have turned the printer on and off repeatedly but the error persists. It's Canon MP640, error C000
  • Anonymous Mar 20, 2014
    Just setting the printer up - removed all the plastics covering the printer according to manual, skipped the fax setup and went straight to switching on the printer.
    Pressed the power button and after it loads, error message 5011 "Printer error has occurred. Turn off power then back on again. If problem persists, see the manual" pops up instead of the language setup that should have appeared.
  • Anonymous Mar 22, 2014
    the on light and the alarm light is flashing and it says printer error has occurred 5011. How can I fix this?
  • Anonymous Mar 25, 2014
    canon mp250 will not scan and or print or alter message. led screen uptop keeps flashing alternatively 1 E 3 . can anyone explain?
  • Anonymous Mar 29, 2014
    error 5011 when turn on printer
  • Anonymous Mar 31, 2014
    no imprime
    President:
  • 2,306 Answers
You need to carefully clean the encoder strip. It's the clear strip behind the carriage that runs all the way from right to left. A damp Q-tip should remove any grease or fingerprints.
Posted on Jul 16, 2009
  • EveNL Nov 28, 2010
    and if that doesnt work? and if there's also no paper stuck?
    i already went back to te service center and of course my printer worked there. no problems at all so i had to bring it home again.. but i still get the problem :( (even after printing smootly once again) they said the shaking on the way to the store might have helped?! but i dont know which way to shake it now ;)
Another thing you want to check is that you have nothing lodged in the printer. that was my problem. I don't know how it got there but all the printer needed was to have the pieces of paper blocking its path removed.
Posted on Nov 23, 2009
How can I fix an error msg #6A81 on the Pixma mg5320?
Error 6A81 is described here: http://www.canon.co.uk/support/consumer_products/product_ranges/printers/pixma/error_codes/#5011
Description
A printer error has occurred.
Resolution
  1. Turn off the machine and unplug the power cord from the power supply.
  2. Plug the machine back in and turn the power on.
    NOTE- If you disconnect the power plug, all the faxes stored in the machine's memory are deleted.
If the above solution has not resolved your error, please contact your nearest Canon authorised service facility.
Feb 19, 2016 | Canon PIXMA Office Equipment & Supplies
Canon MX 892 = Printer error has occurred. Turn off power than turn back on. If problem persists see the manual.
The grinding noise would be a clue that something needs to be put right before the reset would work!
Open the cover and check the paper has not jammed or cartridge has not been placed correctly.......remove cartridge and replace! Then turn off power and back on again!
Oct 19, 2014 | Canon PIXMA MX892 multifunction printer
Canon mx374 error 5040 please advise ?
This might be a system board that has failed:
Here is the link to the error code:
http://www.canon-europe.com/support/consumer_products/products/fax__multifunctionals/inkjet/pixma_mx_series/pixma_mx374.aspx?type=errorcode&errordetailid=tcm:13-1333319
Description
Resolution
If the error message is still showing, then it is necessary to deliver or send the printer to an authorized repair center.
If the printer is still under warranty, (generally one year from purchase) and supporting documentation is provided, then a free of charge warranty repair will be carried out.
Dec 28, 2012 | Canon Office Equipment & Supplies
Getting error message
turn off printer while holding #9 button press power wait till display "full nv reset" problem solve
Oct 05, 2012 | Epson WorkForce 845 Wireless All-in-One...
Error when scanning
Hi Liz
Looking at that message I get the impression that the printer is not actually scanning but trying to 'import' from a non-existent camera card.
You don't normally get an import message when scanning.
The destination full or read only part is a puzzle but could indicate that it is also trying to copy back to that non-existent card.
I think your best option is to use Canon's web site and look at the support section. They may well have an on-line chat service in your area that can help you sort it out.
May 19, 2010 | Canon PIXMA MP470 All-in-One Printer
Error message is this: Error Number : 6A00 A problem has occurred with the printer mechanism. Cancel printing and turn off the printer. Wait a few moments, then turn the power back on. If the problem...
Unplug printer power supply from wall or powerstrip. Wait 10 minutes then plug in power supply and turn on printer and try again. If problem persists and it is under warranty contact Canon for repair. Otherwise it might be time to buy a new one.
Dec 05, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Have a canon mp 240 keeps flasing P and 3 and the alarm light and on button are also flashing......what the it wont scan it wont print does any one know what this means
When the Power and Alarm lamps flash alternately, and P and number (error code) are alternately displayed on the LED, an error requiring servicing might have occurred.
Turn off the machine, and unplug the power cord of the machine from the power supply. Plug the power cord of the machine back in, and then turn on the machine. If the problem is not resolved, contact your Canon service representative.
Nov 08, 2009 | Canon PIXMA MP240 All-In-One InkJet...
Error Message C000
Purge cam sensor error [5C00] An error occurred in the purge unit. - Purge unit
- Logic board prbelom
Sep 09, 2009 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
Canon Pixma MP480 All-In-One InkJet Printer Logo
11,315 people viewed this question
old marine
old marine
