My External hard drive is freezing any computer it gets on When defraging it says kenal32 dll error
  • 442 Answers
Remove all startup items by using Start - Run - MSCONFIG and then restart the computer and try doing defrag.
also download diagnostics for the external hard drive and diagnose the hard drive for any errors, you should be getitng a clear picture then.
Posted on Jul 16, 2009
Intel storage error, and computer keeps freezing, slow,
Hi
Possible reason why the computer running slow and sometimes freezing its because of the hard drive or the storage is almost full try to defrag the local drive and try to unistall software that you dont need anymore.
Dec 09, 2011 | Computers & Internet
250 gb seagate external hard drive is recognised b the computer but doest open. when open command given, error message comes 'i/o error' please help me
Sounds like the drive is dying. Your only hope might be to try a scandisk and defrag. From My Computer, right click on the drive and go to Properties. Select the Tools tab. Run the Error-Checking tool and make sure all check boxes are selected. Once that finishes, run a defrag from the same menu. If those don't work, the drive is likely done. Sorry.
Feb 27, 2011 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
I am getting the data error (cyclic redundancy check)
A cyclic redundancy check, known as a CRC error, often occurs when you're attempting to transfer data to a hard drive. It's most commonly caused by an interruption in the recording process, but also can be a sign that you've got problems with your hard drive or optical drive.
Here are some steps fixed the issue:
  • Rule out problems with your computer Start by defragmenting your disk. Click the "Windows or Start" button in the lower-left corner of your computer screen and select "Control Panel." Click the "System and Security" icon. Choose "Administrative Tools," then "Defragment your hard drive." This will clear up clutter on your hard drive that could be causing the error
  • Use the CHKDSK program in Windows to see if there are other problems with your hard drive. Click the Windows or Start button and select My Computer or Computer. Right-click the drive with the CRC error. Choose Properties, then select the "Tools" tab. Click Check Now. Make sure the program will fix disk errors by checking the top square in the dialog box. Click Start.
  • Thanks for using Fixya.
    Jan 31, 2011 | Western Digital My Passport Essential...
    Fatal error d3dperf SetOption(d3d9.dll)
    go into control panel administrive tools computer management then select event viewer depending on what operating sytem you have this may vary
    extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured you might have to uninstall then reinstall the program and its files
    If the ntdll.dll error only displays when you use a specific software program,
    uninstall the program, reboot your computer, and then install the latest version again from scratch.
    until you know what the problem is you cant fix it or you might try
    you could run the check disk utility
    click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive
    hope this helps
    Dec 30, 2010 | Computers & Internet
    Mybook 1 tb freezes? I can see files but when click in it it freezes? im using xp pro with 2.5 gig ram service pack 3
    try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/f which will automatically fix any corrupt files on your hard drive then defragment your hard drive
    hope this helps
    Sep 18, 2010 | Western Digital 320GB MyBook External USB...
    Should external hard drives be defragmented?
    It is good praktice to defragment also external hard drives but main problem with external hard drives is type of conection with computer (usb, firewire or SCSI) that will determinate speed, especialy when you work with video.
    Jul 12, 2010 | Maxtor Hard Drive
    While transfering a file from pc to hd computer froze. I then unpluged the drive and then pc come back to normal now the external will not get recognised
    It sounds like you have a serious problem. If you cannot get the HDD to read at all and your computer will not recognize it, you have a bad "sector" of the drive.
    As a metaphor:
    Your drive has little "squares," each square stores information on it. Your computer will break the data down into these squares and store it in segments. When your computer freezes its because it is "confused" as to why it cannot store the data. When you remove the HDD, the computer then assumes it's to stop and resumes regular activity.
    The solution:
    A) Go to “My Computer” right click on the Hard Drives icon and go to “Properties,” then go to “Tools” and then to “Error Checking.” Also then “Defragment”
    If that doesn’t work:
    B) Try to reinstall the updated drivers on the manufactures web-site. After you have reinstalled the drivers reformat the Hard Drive. Reformat your hard drive by going into "My Computer" and right clicking the HDD and selecting "Format." Follow the prompt.
    -Paul
    May 21, 2010 | SimpleTech Signature Mini 250GB External...
    Unknown Hard Error
    It's probably a corrupted file on the hard drive due a variety of reasons. A simple defrag might fix it but it's unlikely, so it is probably preferable to a Repair function from your XP install CD. These kinds of errors with XP were not uncommon. After the Repair assuming it works and I'm fairly certain that it will, defrag your hard drive and then start getting the new updates for your system.
    Illustrated procedures located here
    Aug 26, 2008 | ASUS P4VP-MX Motherboard
    External hard disk unreadable
    Your hard-drive is crashed and unreadable by win32.dll what you can do is try kick starting by using your friend computer it just might do it. I had same problem and I asked my son to using my hard-drive on his PC. It worked and still working. good luck
    Jul 26, 2008 | Seagate 160GB 3.5" External USB Drive 160...
    Defragmenting external drive
    run the command prompt, by going to start run and entering "cmd" then enter "defrag" followed by the drive letter.  if this doesn't work, enter "defrag /?" with the space for more options
    Jan 08, 2008 | Iomega (33090) 250 GB Hard Drive
    Computers & Internet Logo
    160 people viewed this question
    David Payne
    David Payne
