Question about Xerox WorkCentre C2424DN All-In-One Laser Printer
I need to restore NVRAM from the WorkCentre 2424.
I nned to restore NVRAM from the WorkCentre 2424.
How can i do it?.
Tanks beforehand
    President:
  • 627 Answers
1. From the System Setup menu, go to Information --> Troubleshooting --> Service Tools menu.
2. With the cursor at the top of the Service Tools menu, press both the Up Arrow and Down Arrow buttons to display the Hidden Service menu.
3. Reset NVRAM is in there
If that doesnt work try below.
1. Turn the system power ON.
2. Wait for the Xerox logo to begin moving across the display.
3. Before the logo is centered on the display (stops moving), press and hold the Back and Info buttons on the control panel.
4. Hold both buttons until the display reads 'Beginning Service Mode Initialization'. Release the buttons and the system reboots into service mode with the Service Diagnostics menu displayed. You should find it in the function sub menu.
Posted on Jul 16, 2009
What does mean konica minolta cd370 error code
CD370 errors occurs when• Multiple errors are detected by the
abnormal check of each NVRAM data.
You need to reset the printer's NVRAM . First find out how.
It isn't mentioned in the KBizhub350 User Manual, as required by government. Any fraudulent activity is also kept on the nvram. (copy bank notes).
Jun 26, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
My hp mini 1000 hungs and i try formatting after dat it display system/system32 missing or file corrupt pls what do i do?tanks
it looks like you need to run your recovery discs to restore your system 32. altenativly.
format memory and re-install your operationg system and any service packs. ensure to save any wanted data beforehand.
I hope this was useful.
Jan 12, 2011 | Computers & Internet
Printer error 07,007.40:80035
Xerox 2424 or 8400 series 07,007.40/49 is a process motor sequence error often caused by the printhead leaking wax on to the pivot shaft and bearing block mounted on the left side of the printhead unit, this stops the printhead tilting. Check for leaking wax around the silver block on the side of the printhead or around the waste tray, if wax gets into the tilt gear at the back of the waste tray slot, this is the error it shows.
Oct 24, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
Need to enter service mode on a Xerox 7435
The service tech should do this. The 7435 should be less than 3 months old, and Xerox should fix it. If you bought it from Global, or another company that does not actually employ Xerox technicians, try appealing to them, but I cannot tell you for sure what the outcome will be. Buying from an authorized agency ensures that you can use your "Total Satisfaction Guarantee".
Jun 04, 2009 | Xerox WorkCentre M-24 Color Copier
XEROX 2424 is printing in reverse order
Check your driver settings, in Layout option some people things that print in reverse order is going to print on both sides but its not. It wil print your job backwards though. So make sure you dont have that selected
Oct 20, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
System error
7,0XX.6x Errors - Program Faults
a.
Reset NVRAM and retest.
Jul 02, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
Scanner workcentre xerox C2424
Have you tried going to Xerox.com, click on support, then enter the 2424, then support again, then type in scanning? There is a lot of info there.
You can also call 1-800-821-2797 and ask for second level support.
Apr 24, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
Reset WorkCentre 24, Xerox
In menus you browse to the service tab, then serivice diagnostics. Go to NVRAM reset and perform the NVM reset.
Before you do that, print out a configuration page if you want to rememebr the network settings. It will set the IP address back to default also.
Apr 03, 2008 | Xerox WorkCentre M-24 Color Copier
Drum Full of Waste Toner
Try clearning the NVRAM most cases the drum fill count is baised on a setting and not if its really full.
  1. Press Menu.
  2. Press d_bottonb.gif until Configure appears, and then press r_bottona.gif or arrowbutton_sa.gif .
  3. Press d_bottonb.gif until Maintenance appears, and then press r_bottona.gif or arrowbutton_sa.gif .
  4. Press d_bottonb.gif until Init NVRAM appears, and then press r_bottona.gif or arrowbutton_sa.gif .
  5. The Init NVRAM Are you sure? message appears on the operator panel. Press arrowbutton_sa.gif .
  6. Turn off the printer, and then on again.
Nov 16, 2007 | Dell 3000cn Laser Printer
Xerox WorkCentre C2424DN All-In-One Laser Printer Logo
428 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
