Question about Epson TM-U220 Matrix Printer
"Unable to initialze COM1" - Problem with EPSON "TM-U220PD" Recei
Printer Model - EPSON "TM-U220PD" Receipt Printer
I have not installed the drivers for the same.Can I use this!!
I am not able to print on Printer - giving error :
"Unable to initialze COM1".
  • Rigoberto Vazquez May 11, 2010
    you need make special cable to work ok, what kind of ports you have incomputer an printer, 25male or female, or 9male or female, give me that data and i send you how make the serial cable
informatica
  • 1114 Answers
SOURCE: Epson TM-U220PD
Necesitas colocarse para los productos de la ?POS? en el Web page siguiente: https://www.epson-pos.com/cgi-bin/sdssm/main/td_login.jsp?sel_lang=es
Posted on Jul 29, 2007
SOURCE: User Intervention required on Epson
i am pulling hair trying to install epson tm u220pd on xp and vista for weeks now please help
found some drivers but printer is not responding
Posted on Dec 02, 2008
BoxenRyan
  • 31 Answers
SOURCE: What is the IP Address for Epson TM- U220PD
The best way to connect to this printer is to plug the network cable from the printer into a PC, set your PC to Static IP 192.168.192.100 Subnet 255.255.255.0
Save your settings, and than open internet explorer, or firefox, and access the printer by going to 192.168.192.168
This will allow you to change the settings to your current subnet, and save.
Hope this helps.
Sincerely, Ryan Deschaine Systems Engineer Boxen Solutions LLC http://www.boxensolutions.com
Email address: ryan@boxensolutions.com
Office number: 262.432.3120
Mobile number: 262.364.6196
Fax: 414.918.8432
AOL: BoxenRyan
Twitter: BoxenRyan
W172 N9175 Shady Lane
Suite 418
Menomonee Falls, WI 53051
Posted on Jun 30, 2009
SOURCE: EPSON PRINTER DRIVER
i need driver of TMU-220 printer for windows 2003 server
Posted on Jul 13, 2009
SOURCE: Epson printer TM U220 (User Intervention Required)
I spent a good week trying to find an answer to this problem... and finally I HAVE THE SOLUTION!!
it's to do with the Port settings.
go to BIOS and change the port settings on your computer.
there are a number of different options that can be selected, just try them one by one, the one that worked for me was "Normal" try that one first, but it may be differnet depending on the printer.
if your LPT port is using it's own driver (not using BIOS to run) you cant change the settings using the BIOS. see if you can change it useing the settings for the dirver. if not try updating the driver. if that doesn't work, and nothing else works, reinstall Windows, that should fix the problem as a last resort.
good luck.
Posted on Jul 23, 2009
Unable to install Epson TM-U220B[U220 with UB-U02III usb interface] on Windows 7 AND XP!
Hi!
Are you using a third party USB adapter or a USB interface? On the self test page that you printed does it say USB connection or something that will say about USB? or does it say parallel or serial connection? try to check the dip switches setting if its configured properly. visit epsonexperts.com site for more info.
Dec 24, 2011 | Epson TM-U220 Matrix Printer
I need a printer driver for Epson TM-U220PD receipt printer for XP
http://www.posmicro.com/RECPRINTERS/EPSON/EPSON%20DRIVERS.htm here you go if it works let me know via a message or thumbs up if not i will continue to help you
Mar 16, 2011 | Epson TM-U220PD Matrix Printer
Trying to install epson tm u220pd with USB port, what drivers do I need? Plug and play does not install it in setup wizard
if your using TM-U220PD which is a parallel , you should connect it in parallel port then use this printer driver http://pos.epson.com/developers/techresdetails.htm?productpk=545
Feb 18, 2011 | Epson TM-U220 Matrix Printer
To install Epson printer TM-U220PD Model M188D
What is the baud rate of the EPSON TM-U220D MODEL M188D?
Feb 14, 2010 | Epson TM U220D Printer
good luck.
Dec 11, 2008 | Epson TM-U220PD Matrix Printer
User Intervention required on Epson TM-U220PD
I had the same problem with the user intervention required status on the printer. I tries reinstalling it several times through the Epson Driver Utility but got the same message each time. I got it to work after making two change but do not know which one (if either) got it to work. First i uninstalled the printer driver through Add/Remove Programs and not through the Driver Utility. I also set Dip switch 1-1 to on which enables auto line feed with parallel interface, with other interfaces this switch changes other things.
Dec 02, 2008 | Epson TM-U220PD Matrix Printer
TM-U220PD oN WINDOWS VISTA STARTER
Hi, you should try these drivers for Vista...has a preety nice install wizard (works on vista for me).
http://rapidshare.com/files/167170222/TM-http://rapidshare.com/files/167170222/TM-U220.zip.htmlU220.zip.html
good luck
Nov 17, 2008 | Epson TM-U220 Matrix Printer
Error LED keeps flashing
your printer needs to be serviced
http://pos.epson.com/service/servASPP.htm
look for a service provider on this website
Feb 20, 2008 | Epson TM-U220PD Matrix Printer
Epson TM-U220PD
Jul 29, 2007 | Epson TM-U220PD Matrix Printer
Epson TM-U220 Matrix Printer Logo
301 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
