Question about Sylvania 6719DF 19" TV/VCR/DVD
Television will not air all cable stations
We got this television from our grandmother. We do not have the original remote, but have a Magnovox Universal Remote. We unplugged our old tv and plugged in this one. Before we had over 70 cable stations. This tv has not only shorted it to 22 stations, but all the cable stations are on the wrong channels. For instance, cable channel 65 is now channel 14. I have never had a television do this and have no clue as to how to fix it. Any help would be appreciated!
Re: Television will not air all cable stations
If when you turn it on it starts to run through the stations let it go and finish.
Posted on Feb 16, 2008
0 characters
3 Points
Magnovox tv i need the codes to program a rca remote to the magnovox tv
Codes for Magnavox TV with RCA remote control are:
1004, 1014, 1046, 1051, 1060, 1061, 1062, 1066,1067, 1072, 1073, 1074, 1075, 1076, 1077, 1078, 1082, 1083, 1112, 1136, 1161, 1164, 1166, 1176
Jun 26, 2012 | Standard (CRT) Televisions
You are going to have the original remote and the owner manual to do this--Universal remotes never had or will have key features the original one has.
Apr 11, 2012 | RCA 27F650T 27" TV
I can not turn the captions off on my magnovox television
It sounds as if you have the closed caption option activated on your TV. The easiest way to disable this is to search your remote for the closed caption button. It is most likely the button marked CC or Closed Caption. Good Luck
Jan 11, 2011 | Philips Magnavox 27MS343S 27" TV
Have a sansui tvs273 tv. Need to switch it from
If your set does not have a menu button built into the set your out of luck unless you can find a replacement or universal remote.
Sep 11, 2009 | Sansui TVS203
I cannot get digital to appear on television.
You will need to call your cable company to help you with that issue.
May 12, 2009 | RCA TruFlat 27F520T 27" TV
Not receiving my local cable stations
You need to make sure the TV is set for "cable" tuning and not "standard" or "air." (If you are getting only local off-air channels and no cable stations at all, be sure you have a good cable and connection to the set. Normally, even if the TV is set for "air" you will get the low-number cable channels 2-13.) This is usually a selection through the TV's set-up menu. With a universal remote, it may be difficult or even impossible to get to all the menu entries. Most replacement remotes don't support all the original remote functions. Try with yours and good luck. Once you get the TV set to the proper tuning, you should have all your cable channels.
Jan 03, 2009 | Durabrand BH1304D 13" TV
Remote control not working
is the remote original and ment for the television? if not I would suggest a universal remote from any local retail shop to replace the non working remote.
Jan 02, 2009 | Toshiba 32A33 32" TV
My grandmother has a Emerson tv Model # 5000A652-0617067
Hi and welcome to FixYa,
Initially, removing the constant Ch 3 would require disabling the OSD (on-screen-display). However, this would require the use of the original remote.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 13, 2008 | Emerson EWF2004 20" TV
Digital or not
Sory to say that this set DOES NOT have the digital tuner required for over-air digital broadcasts. IT does have a digital tuner but only for cable and analog over-air stations. You would only be effected by the chagneover if you uise rabbit ears or a rooftop antenna. If you have cable or satelite or any other subscription TV service, you will not be effected.
Sep 24, 2008 | Emerson EWF2004 20" TV
Standard (CRT) Televisions Logo
103 people viewed this question
Top Sylvania Standard (CRT) Televisions Experts
Kenneth Walker
Are you a Sylvania Standard (CRT) Television Expert? Answer questions, earn points and help others
