Do a hard reset first and then check. If it do not help, it's main system control memory ic will be faulty. Contact any service technician to get this set repaired. If you wish to get more details visit the site linked here. http://electronicshelponline.blogspot.com/
Ron, F60 is a general error code usually related to a failure on the video processing board. You could fix this by just replacing that board. Try to place it in standby mode first by unplugging it, wait a couple of minutes and then plug it back in. When the 000000's starts, hold down the power button for 15-20seconds. The unit should then be in standby mode. From this mode try to start it normally using the power button and see if it cleared the error. You could also try a complete reset by powering the unit off and press and hold the "Stop" and "Channel Up" buttons at the same time for a few seconds while powering the unit up. Hope this helps, good luck.
It could be overheating.. Is it fairly consistent at 75 seconds? To test put the unit in the fridge for 30 minutes then quickly connect it up and test. If it is longer then 75 seconds then something is getting to hot. I've put hard drives (especially laptop ones) in the freezer if I need to copy off data but it clicks/stops working at room temp.
Unplug the unit. Plug back in and wait till you see 000000. Press and hold the power button in at least ten seconds or until the clock shows up. This worked to fix mine.
Yes, it would not recognize any type of disc. The disc icon was always present on the display even though no disc was inserted. Also, mine went out while recording from HDD to DVD. Panasonic had mine repaired in two business days and it' s working great.
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
