XP Prof installation can not find the Hard disk drive
Hi all,
I have problem with installing XP Prof to my HP XW8200. While installing XP, it brings the error, that no hard disk is found.
I have the hard disk Seagate ST373454LW, ultra320-SCSI 73 GB.
Who can help me.
Thanks in advance.
Kader
mk.entwicklung@gmail.com
    President:
  • 627 Answers
There are 2 ways to fix the problem
1. go to bios and change sata mode to IDE
2. when booting up from windows cd press F6 and insert the harddisk SATA driver which was given
if you don't have it better try 1-st solution
Posted on Jul 16, 2009
    Scholar:
  • 57 Answers
Hi,this is very simple problem.
before installing XP press F2 (go in system setup)
and there look for every option,there will be an option for hard disk.on that option select "SATA"
AND THEN PRESS F10(to save your choice)
after that exit and insert XP cd,window will start installing.
cheers
HP xw 4400 will not recognize my hard drive when trying to install OS Windows XP Prof.
Windows XP had a hard time recognizing hard drives larger than 127 GB. The best solution is to install Windows XP with service pack 2 or 3 already slipstreamed. Otherwise, you are going to have to partition your hard drive with at least 1 partition of 127 GB or smaller.
Dec 08, 2012 | HP xw4400 Workstation PC Desktop
HARD DRIVE NOT EXIST ERROR!!!
If you installed Linux successfully on your hard disk then the hard disk is OK.
If you are installing Windows Xp and it does not detect the hard disk but the BIOS detects the hard disk then -
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
May 01, 2012 | HP Computers & Internet
XP installation problem - HP Cpmpaq 6720s Laptop [HDD detection error]
The hard disk is not detected because this model notebook has a SATA hard drive installed and the XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX.
Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Aug 12, 2011 | HP Compaq 6720s Notebook
HP Workstation xw8200
Server 2008 is not detecting your drives, because it does not have drives for what ever hard drive controller you are using. You will need to determine which controller your drives are attached to and load the appropriate driver during setup. I believe this system has built in SCSI and SATA controller and often shipped with add - in storage cards. Our came with a promise sata raid controller.
Apr 20, 2009 | HP xw8200 PC Desktop
Bought HP Pavilion dv2910tx,not able to install Windows XP. Help
If the install cannot detect the hard disk then the hard disk is faulty and needs replacing or the disk controller is faulty.
You can check if the hard disk is faulty by :-
Go into the BIOS and check if there a hard disk diagnostic.
If not then remove the hard drive and connect it to an USB hard drive adapter and plug it into a working computer's USB port.
If this computer see it as an external hard drive and you can view the contents of the drive then it is OK and the fault is the disk controller on the laptop.
To setup XP.
You insert the Windows CD and boot up the laptop with the CD.
You have done this correctly to get the hard disk error message.
Apr 15, 2009 | HP Pavilion dv2000t Notebook
Vista to windows xp prof., toshiba satellite l305-s5894
hello , friend its very easy to do that, steps are
1. insert bootable cd/dvd xp prof. cd.
2. But be cautious because the xp profsn doesnt contain the drivers for ata hard disk. so pls find on net the drivers for ata hard disk drivers, also update it in bootable xp profsnl dvd . recreate bootable dvd of xp with advanced bootable xp,
3. or find it from your friend with latest updates requirement. and do from it.
4. Boot from tht cd and start the installation.
5. once it i completed install all video, audio e.tc. drivers.
6. if you dont have that drivers pls download it from toshiba site by entering the toshiba serial no
Mar 25, 2009 | Toshiba Satellite L305-S5894 Notebook
NTLDR missing on changing harddisk connection
put the xp bootable disk in computer and boot from it, choose repair option. it will slove your problem.
Feb 24, 2009 | Microsoft Windows XP Professional With...
Problem while installing Win XP Prof.
The prolem is with Windows Xp cd...
When i try to install through the Genuine Win XP cd then it works fine...
Ok...
So use the original softwares....
Feb 16, 2009 | Intel DG31PR Motherboard
Exactly same slow working especially slow boot up and shut down problem with Cpmpaq EVO N610c.I reformatted twice and installed windows xp professional but still same proble.i have 30 gb hard disk with...
Hi there
Don't bother with service pack 3, it will only slow the pc down even more, what you need is a memory upgrade so the machine can perform well, also a better hard drive would be a good idea
kind regards and please don't forget to rate us
Dec 09, 2008 | Microsoft Windows XP Professional With...
Computers & Internet Logo
122 people viewed this question
David Payne
David Payne
