Question about Acer Aspire 5600 Series 5630-6951 Laptop
Acer 4715z monitor flickers
My monitor is flickering. I do not know what was the problem, that flickering was gone before now it came back. Do I need to replace my video card? What is the best video card for my notebook that I could use in gaming as well? Thanks..
  • blue_shadow0 Jul 16, 2009
    I will try this solution. Thanks for your help aggrovendor..
  • 43 Answers
Hello Blue_shadow0,
Your monitor may be flickering because the connection of the LCD is loose on the motherboard. You would need to open up the laptop and check the connection or bring it to someone who can do it for you.
Posted on Jul 16, 2009
Screen making quick flashes
This could be a LCD screen problem or a video card problem.
Connect an external monitor to your laptop, power up the monitor first then boot up your laptop. The video will automatically switch to the external monitor, then go to the Internet and see if this flicker occurs on the external monitor.
If it still flickers then the video card has a problem.
If it does not flicker the the LCD screen maybe faulty.
Get back to me with the results of these test and I can advise the nexr course of action.
Apr 30, 2012 | Acer Aspire One Netbook
Acer Laptop Screen Flickers & Jumps
Please connect the laptop to an external monitor. If no flickering on monitor screen, from my previous experience, this is more likely loose connection of video cable connected to the LCD. So talk to Acer support again and require the replacement of LCD.
CompQ
May 11, 2010 | Acer Aspire 6930-6082 Notebook PC
Monitor flickers then goes to black/blank screen.
have you tested it for gone conponments
Aug 14, 2009 | Computers & Internet
Acer AL1914 flickering background
check the monitor refresh rate setting.right click on the back ground on the main windows screen. Choose proprieties from the menu that opens, then click on the settings tab on the top of property window. Next click 0on the monitor tab and increase the refresh rate at the bottom of monitor window. That should do it.
Jan 24, 2009 | Acer 19" LCD Monitor
Monitor screen shaking and flickering
Check to make sure the cables are connected tightly. Wiggle the cable, does it get better or worse? Might need a new cable. And reseat the video card inside the computer. If that doesn't fix it, then yes you will probably need a new monitor.
Jan 15, 2009 | Acer AL1917W LCD Monitor
Flickering screen
My screen flicker on xp but on win7 please help me?
Regards, Chas
Jan 06, 2009 | Acer X193W LCD Monitor
Acer X223W flickers using DVI cable, but ok with VGA!!??
Acer X223W flickers using DVI cable, but ok with VGA!!?? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
715G2892 2 3 Acer PWTVAC21MQDL Power Supply for X223W
Dec 19, 2008 | Acer 22" X223w LCD Monitor
Acer al2002w flickers and goes black
Hi....there,
Well, you've got a busted backlight inverter... Need to replaced a new one...
Nov 30, 2008 | ViewSonic VX2025wm 20.1" LCD Monitor
Back ground screen flickering
If it flicker continually that may well be either the video card (hopefully not part of the motherboard) or the monitor. Your best bet is to tt on someone else's machine. If it does not flicker then you probably have a bad (or soon to be very bad) video card. If, your video card is built into your machine, don't give up....you can buy a video card and install it....they are not expensive if you are not a big time gamer. Price ranges are anywhere from $8-20 if you are a normal PC user. Pricewatch.com can give you some insight. You will need to know what type of slot you have available....presumably AGP (but PCI, if you have an open slot on the motherboard, will also work....AGP is faster.)
Jan 20, 2008 | Acer AL1916W 19" LCD Monitor
Screen flickers
Computer Video Card Support and Help The below image is an example of a screen running at 640 x 480 which means 640 ... Refresh rates below 75 Hz can produce an often-imperceptible flicker.
Monitor Help ... you may encounter a flicker or a noticeable steady line scrolling from the ... While new monitors (VGA / SVGA) do not have this issue.
Good Luck , Please dont for get to Vote/Thank You.
Dec 22, 2007 | Acer Aspire 3610 Notebook
Acer Aspire 5600 Series 5630-6951 Laptop Logo
363 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
