Question about Samsung (SP0822N) 80 GB Hard Drive
My hard disk do not detects by the machine. - Samsung (SP0822N) 80 GB Hard Drive
  • 952 Answers
Thanks for using fixya.
If your computer doesn't detect the hard drive, its possible that:
1. There is a problem with the data cable for the hard drive. Change the SATA cable or IDE cable.
2. Power connection to the Hard drive might be loose. Make sure its connected properly.
3. The hard drive may be bad already. The best way to find out is to try and connect it to a different computer.
4. Its also possible that the port on the motherboard is already bad but this seldom happens.
Posted on Jul 16, 2009
I lost power at my house and when the powr came back on my hard drive won't turn back on
how do you know that your hard disk is not turning on? Get the message displayed on the screen when you turn on your desktop first, if it says "boot device failed" or something like that (depends on motherboard model, company and bios version) , check your hard disk is detected or not by bios if not so, open your desktop cup's cover were something made with plastic or rubber on you hand and touch hard disk to see if it is running while pc is on (if running, you will feel something moving inside). If hard disk is detected by bios then it's a case of damaged operating system, just recover or re install operating system. This kind of problem happens for bad sector of hard disk caused by sudden power loss. If hard disk is not detected by bios or running, make sure machine is turned off first, just unplug the power cord of hard disk and plug it back then restart your machine to see if hard disk runs. If not so , go to some repairing shop to check your hard disk.
Jun 24, 2012 | HP Compaq Presario SR1320NX PC Desktop
My hard disk was being used in an HP machine now it cannot be detected by the machine or any other machine the harddisk is hitachi deskstar model HDP725025GLA380 help me
dear sir,
i think your hard disk is broken.. try to put your hard disk in a refrigerator for one night and then try to connect again to your machine, if you still get the same problem i think you need a new hard disk
May 17, 2011 | IBM HITACHI Deskstar P7K500...
Hard disk is not detecting samsung sp0411n internal hard disk is not detecting
Make sure the power cable and IDE cable is plugged in properly then boot your computer up again. If it does not work, test it on another computer to see if the hard drive works at all.
Sep 18, 2010 | Samsung (SP0411N) 40 GB Hard Drive
Not detecting hard disk
first thing to do is to remove and reconnect the hard disk to the system. devices like hard disk not detected often is just a result of loose connections. if this will not work, may be a good idea to test another hard disk with your computer or test the hard disk on another computer to isolate if the hard disk will need to be replaced.
Sep 04, 2010 | Computers & Internet
PXE-E61: MEDIA TEST FAILURE, CHECK CABLE PXE-M0F: exiting Broadcom PXE ROM. Operating system not found. how 2 solve or repair? help me...
The PXE-X61 error means that the laptop cannot detect the hard drive. This can be caused by a faulty disk controller, or a faulty disk drive.
1st. Reseat the hard drive and see if the laptop boots up.
2nd. Go into the BIOS configuration and see if the BIOS detects the hard drive.
3rd. If the BIOS can't detect the hard disk, the remove the hard drive and connect it to an USB hard drive adapter and plug it into a working computer's USB port. If this computer detects this drive as an external disk drive and you can see the contents of the hard drive, then the hard drive is OK and the fault is in the laptop.
4th. If the hard drive cannot be detected then the hard drive is faulty, you need to replace the faulty hard drive in your laptop and install Windows to get an operating laptop again.
May 14, 2009 | E-Machines eMachines Desktop PC
All drive not detected
Check your power supply that its working or not. If its working then
Please check all the cable inside your system and then try attaching 1 by 1 i.e. attach first hard disk and than start your machine and see that it is detecting or not.
If its detecting then attach cd-rom and start your machine.
If its not detecting then remove hard disk and attach CD-ROM only.
If CD-ROM is also not detected then there is problem with your cable.
Mar 16, 2009 | ASUS P4V8X-X Motherboard
New 160 gig hard drive, can't load XP on Fujitsu S6210
Insert the new hard drive in your laptop, boot up and go into the BIOS.
Check if the hard disk setting is set to Auto (detect). Check the system configuration and see if it detects the hard disk.
If there is a hard disk diagnostic utility within the BIOS, run it to check the hard disk.
You can also test the hard disk by booting up with a boot floppy disk, run fdisk.exe to see if can display, create a partition, and format the hard drive etc.
If not of this works then it is highly possible that you have a faulty disk controller in your laptop.
Dec 18, 2008 | Fujitsu S6210 Notebook
No Hard Drive detected
just probably went out .. defective .. maybe u can contact western digital or seagate whoever made it and they might warrenty it out for you
Oct 26, 2008 | Samsung SpinPoint V80 SV1203N 120 GB...
Hard disk problem
i suggest that you'll buy another hard disk.. repairing hard disk is a tough job.. machines had done it, it is a very difficult job if its manually repaired... your hard disk maybe damaged if your system can't detect it. Just make sure that the cables are properly place/attached.
Jan 25, 2008 | Seagate Barracuda 7200.7 40 GB Hard Drive
Samsung (SP0822N) 80 GB Hard Drive Logo
125 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
