Question about Jasco Ge Intellicorder
Vertical section display problem
  • 906 Answers
Good Day Sir, click the link below to see the product warranty information.
GE intellicorder
hope it will help you.
Posted on Jul 26, 2010
Where is horizontal and vertical output scan section?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Type in the brand name or the IC number to your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Feb 19, 2015 | LG Televison & Video
Tv only displays a horizontal line
Possible failure of the vertical drive section. This can be due to fault in the power supply to the vertical driver, fault in the vertical coil or failure of vertical pulses from the sync circuit.All these might need the use of signal tracing if there are damaged components. In many cases it can be failure of electrolytic capacitors in this section, use in parallel to confirm with the same value. finally DRY solder joints in these circuits specially on the vertical IC cannot be ruled out.
Nov 30, 2011 | Sanyo DS25390 TV
3 vertical very thin lines on display how can i fix them
This is due to retrace and can due to higher screen voltage or a fault in the VERTICAL section.
Reducing the screen voltage will confirm this and if so there is a failure of a 10-20MFD/250 Volt capacitor.
If not a weak capacitor in the vertical section will show the retrace and replacement of the cacpacitor in this section must solve the issue.
Oct 01, 2011 | iiyama Vision Master Pro 514 22" CRT...
Monitor displays half screen sometimes and goes back to full screen later. Some days you get the full screen but today it is half screen one time and then full screen another time. It finally quit...
The monitor have problem in vertical section of the board.Maybe the vertical output or any parts around the vertical ic is loose connection circuit,what we called,cold solder so its better to resolder the board at the vertical section.
Jul 11, 2011 | NEC PlasmaSync 61MP1 61 in. Television
Philips tv 20pt1782 want service manual
hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me..
Jun 10, 2010 | Lexmark All-in-One Printer with PictBridge
HCL 17" monitor display problem
Hi there ,
It seems that you have a vertical section problem ,It might be possible some capacitor might have gone wrong
Jan 24, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
TV screen dislay partial horizontal beam
you had a problem on vertical section of your tv, if can fix it ,change the 100/50 volts capisitor on .vertical section or else all capasitors in vertical section
Oct 07, 2008 | Televison & Video
Display adjustment
hi there, bottom adjustmet means a vertical section control adjustment. a vertical size, vertical position control adjustment. do some check up on users control manual adjustment. ty
Dec 29, 2007 | Philips Magnavox 24MC4306 24" TV/VCR/DVD
Double picture
your problem is in vertical section. 1 any capacitor in vertical section is defective. 2 transistors in output ckt might be defective 3 loose contact in vertical section. 4 problem in feed back circuit(if you are a technical person )
Sep 14, 2007 | Emerson EWF2704 TV
Jasco Ge Intellicorder Logo
70 people viewed this question
Top Jasco Home Security Experts
Lawrence Oravetz
Are you a Jasco Home Security Expert? Answer questions, earn points and help others
