Question about Ovens
Maytag oven will not light
Our maytag oven will not light model number mgr5770abb help.... Oven will not light. When temperature is set or broil is set, the curcuit is tripped. Where is the reset button on the range?
  • 248 Answers
There is no reset button on range. Do you mean your house breaker is tripped? I would check for bare wires shorting to ground.
Look for evidence of mice, as in droppings. If so they probably chewed on wires.
Posted on Nov 18, 2007
How can i tell if the hi limit thermostat in my maytag wall oven is bad
test with a multi meter on each end of the wire prong connector, place each end of ur meter prong on both 1 and 2 of the connectors, and test for continuity ohms or a close circuit. have ur meter on a low ohms setting as the level of ohms is low. if it shows an open circuit or no continuity, its defective. Infinity is the meter not showing anything like a number 1 and not moving?
Apr 26, 2015 | Maytag MEW6530DDW 30" Electric Single Wall...
My gas oven doesn't work but the stove part does. The product is only 2 years old.When I put the Bake or broil button on the oven doesn't heat up. I am sure the pilot light is out but I don't know how to...
To answer the question fully, I'm gonna need the model number. Pull out the bottom drawer, and the model should be located on the side of the frame or on the drawer itself. Might even be behing the oven at the top, should be a metal plate that flips up.
Feb 21, 2011 | Maytag Ovens
We have a wall mounte singe maytag oven. When I go to set the oven temp. the panel reads"door" and I am unable to set it. I have opened/closed the door and put the lock lever on and off, but to no avail....
Hello there:
Here is all of the possible error codes for the door and what they mean and what to look at
DOOR Bake or Broil
· Defective latch switch
· Shorted wire from ERC 10-pin connector, pin 10 to ground
· Door latched Replace latch switch if defective.Replace wire from 10-pin connector if defective DOOR Self-Clean
· Open wire from ERC 10-pin connector, pin 10 to ground
· Door not latched Replace latch switch if defective.Replace wire from 10-pin connector if defective LOCK Not in Self-Clean
· Oven temperature sensor resistance too high Check oven temperature sensor resistance, wire harness and connections, replace defective component
Sep 28, 2010 | Maytag MEW6527DDS Electric Single Oven
Maytag gas oven wont restart after pre heat
you have a bad oven sensor /faulty connection or bad control board.look for probe coming thru inside rear wall.should read 11k ohms cold.go bad a lot part number Hope this helps ,please rate my response :)
Jun 25, 2009 | Maytag 24" Built-In Single Gas Wall Oven -...
Stuck in broil mode
sounds like you need to call MAYTAG repair service ,control board has probably failed .we do not recommend DIY fixing of any gas appliance.
Feb 15, 2018 | Ovens
Maytag oven top heating element won't come on unless on broil
You are probably going to find the lower heating element has failed. Your symptoms describe that failure exactly.
Reply back if you want instruction as to how to repair.
Feb 15, 2009 | Whirlpool RBS275PD Electric Single Oven
Maytag gas oven mgr5770abb Does not light when I try to use oven. Broiler works fine. When I try to turn on the oven, the broiler igniter does not glow. If the bottom igniter was bad, wouldn't the top one...
first I would check to see if you have power (120v) at the bake igniter..when you set in to bake...use a multmeter..(when you turn on the oven to bake only the bottom igniter will come )
good luck be safe
let me know if I can help
Aug 15, 2008 | Maytag CWG3100A Gas Single Oven
Maytag oven calibration
Maytag single built in oven model cwe9000bcb beeps intermittenly. Reset stops for about 1 minute. Two control panel boards replaced since 2002 with same problem. Can it be fixed?
Dec 18, 2007 | Maytag CWE4800A Electric Single Oven
Have you tried to broil or bake? if only one of them work you have a bad ignitor. let me know and we can go deeper
Aug 23, 2007 | Maytag CWG3100A Gas Single Oven
Ovens Logo
107 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
Are you an Oven Expert? Answer questions, earn points and help others
