Question about Xerox Office Equipment & Supplies
Dusty density sensor - Xerox Office Equipment & Supplies
  • Michael Wang Jul 16, 2009
    Phaser Xerox 6200B
    yellow light on, -----dusty density sensor
    check the info wipe off the sensor by dry towel
    but still could not solved
    clean it again, still the yellow light on
    Phaser 6200B
Hi there
Is this a Xerox printer? In any case, please provide the make and model of the printer and exactly what seems to be happening so that I can assist better.
Thanks
nLinked
Posted on Jul 16, 2009
  • Anonymous Jul 16, 2009
    Thank you for clarifying.
    There are three steps that can be taken to try to solve the dusty density sensor error. Please take the following steps in order. Click on the links for step-by-step instructions and follow carefully:
    1. Clean the density sensor
    2. Replace the transfer roller (video available)
    3. Turn the printer off, wait 30 seconds and turn the power back on
    A step or a combination of the steps above should solve the error.
    Best regards
    nLinked
I had a problem my color laserjet printer 8500dn that is asking to clean density sensor I don't no how to do it please help
Hi Elias, The link below is a user manual for a color laser jet 8500, 8500n, 8500dn, I had a look and the answer to your question (Clean density sensor) is on page 155 (To clean the density sensor
1 Open the upper right door.
2 Use the brush located next to the sensor to remove all toner particles from the sensor)..... This WILL Help...CHEERS..
http://h20566.www2.hp.com/hpsc/doc/public/display?docId=emr_na-c00656644
Mar 30, 2016 | Office Equipment & Supplies
E=9 Ricoh FW 780 Black and White Copier
toner density sensor voltage is less than 0.5 volts or more than 4.5 volts.
cLEAN THE
1) Toner density sensor 2) Flow of the developer at the toner density sensor area
Jul 02, 2012 | Ricoh FW 780 Black and White Copier
Sc390
SC390 = Toner Density Sensor abormality
Possible causes:
  • Poor concentration of developer
  • Toner density sensor faulty
Are the prints/copies coming out ok? If the copies are very faint or heavily overtoned then changing the developer may cure the error code. If the copies look OK then you probably need to get the toner density sensor replaced by an engineer.
Hope this helps.
Feb 10, 2011 | Ricoh Aficio 450 Copier
Machine status P-9 what is this message?
Black Imaging Unit failure
• All density readings taken from the density pattern produced
on the Transfer Belt are 0.5 g/m2 (IDC Sensor
photoreceiver output) or less during max. density
adjustment (Vg/Vdc adjustment).
on the Transfer Belt are 4.5 g/m2 (IDC Sensor
Photoreceiver output) or more during max. density
adjustment (Vg/Vdc adjustment.)
Remove and reset the Black Image Unit. If this doesn't help the Image Unit may need to be replaced.
May 25, 2010 | Konica Minolta bizhub C250 All-In-One...
994 service density sensor
The 994 Density Error indicates that the printer's system card has encountered an unrecoverable error. The 994 Density Error can be caused by the density sensor becoming dislodged from the sensor board. This normally requires a service call. However, for basic troubleshooting, try powering the printer off, wait ten seconds, and then power the printer back on. If still no go, if possible, connect the printer's power cord directly into a grounded wall outlet. In rare instances, a surge protector or uninterruptible power supply (UPS) can generate false error messages. If problem persists, I strongly recommend contacting your Authorized Service Provider or Lexmark Technical Support for assistance. I hope I can assist you more on this.
May 10, 2010 | Lexmark C912 Led Printer
Error code e03-40
---Copy Density Sensor output adjustment-----
1. Sensor connector is disconnected.
2. Sensor is defective.
3. SPC PCB connector is disconnected.
4. SPC PCB is defective
there is a sensor in the drum unit that measures/sensors toner density on the drum. the sensor is usually dirty and needs a clean. there could be a number of causes so a technician needs to be called.
May 01, 2010 | Panasonic Workio DP-3520 Copier
I HAVE IR3300 IF I USE THE AUTO DENSITY THE COPY IS GOOD AND CLEAN BACKGROUND IF I MAKE AN ADJUSTMENT TO DENSITY LEVEL THE COPY HAS A DARK BKGROUND, TO BAD ,THATS WHY I ALWAYS USE AUTO DEN.
when the drum starts to get old these type of things can happen. It may be that it just needs to be cleaned if it has been a while or if it's in dusty environment.
Apr 13, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
How to clean Density Sensor of Hp 3500 ?
Thank you for this info. I used your advice to fix my HP printer and it worked. By the way, great link to HP support parges on the www.partshere.com site. I was able to fix my printer and by the way purchased more printer parts and fusers. Thank you again!
Feb 27, 2008 | HP Color LaserJet 3500 Printer
Density sensor out of range
CLEAN THE DENSITY SENSORS POINTING AT THE TOP OF THE TRANSFER BELT. A COLD RESET CAN HELP TOO
Jan 20, 2008 | HP Color LaserJet 3500 Printer
CDT Calibration Error
CTD (not CDT) stands for Color Toner Density Error. Your bad sensor is not on the printer, but on one of the color toners.
Oct 15, 2007 | Samsung CLP-500 Laser Printer
101 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
