Question about Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan 2300 2.3 ci Firewood Excesive oil lube to chain ?
Hi anyone , my saw seems to pump out much to much oil to the chain? I believe approx one oil tank to one fuel tank of petrol is a rule of thumb? Well mine uses about 3-4 tanks of oil to one of fuel. you can see it just running out almost. Does anyone know what maybe causing this to happen. I am a mechanic by trade but not on small engines but am sure I can do the job.
  • 1 more comment
  • leejim Jul 16, 2009
    Hi, I have been using the Mc Culloch chain oil.
  • leejim Jul 22, 2009
    Thankyou for your help and Parts and Operation Manual.
    Jim D.
    Jim D.
  • 76 Answers
Try using thicker chain oil
Posted on Jul 16, 2009
How much compression should the saw have?
What Causes Too Much Compression on Poulan Chain ...
homeguides.sfgate.com > ... > Other Types of Mortgages
Many makes of gasoline-powered yard tools, including Poulan chain saws, use two-cycle, or two-stroke, combustion engines. ... Pull the rope out and oil it to see if that helps the problem. ... How Much Compression Should a Stihl 066 Have? ... Pull Starter on a Poulan Chain Saw · Oil Pump Removal on a Poulan Chain Saw ...
The Timber Trades Journal and Saw-mill Advertiser
Nov 26, 2015 | GCSP Husqvarna 340 345 346 350 353...
What type of oil is used for my 2055 2.O CI woodsman chain saw?
This engine is certified to operate on unleaded gasoline.Before operation,gasoline must be mixed with a good quality synthetic
2-cycle air-cooled engine oil designed to be mixed at a ratio of 40:1.Poulan/Weed Eater brand synthetic oil is recommended.Mix
gasoline and oil at a ratio of40:1.A 40:1ratio is obtained by mixing 3.2 ounces of oil with 1 gallon of unleaded gasoline.
As far as bar and chain oil:
Genuine Poulan R bar and chain oil is recommended to protect your unit against excessive wear from heat and friction.Poulan R oil resists high temperature thinning.If Poulan R is not available,use a
good grade SAE30 oil. Never use waste oil for bar and chain lubrication.
Oct 20, 2014 | Garden
I have a1640 partner and the oiler pump does not pump out oil when in use. I cleaned the saw and I have lost the cap which fits on the end of the plunger of the oil pump
Hi allanpriest...
Forget the auto oiler...use a handheld oil gun to lube the chain on your saw...just lube the chain approx. every 2 - 4 minutes of use
Please take time to rate me
Sep 15, 2011 | Electrolux Garden
Poulan 2300 Firewood chain doesn't oil
She is long of tooth. Some oiler parts are NLA. Item 17 on the "Power Unit" print is the actual oil pump. Do not mistreat it; do not blow it out with air; they are no longer available.
http://www.ordertree.com/modelinfo/PWE/2300AV-Gas-Saw/75.2300AV-Gas-Saw.1.59.1.html
Please see this thread, post 5
http://www.arboristsite.com/showthread.php?t=120981&highlight=poulan+xxv+oiler
The *.pdf is your oiler. I suggest you read the entire thread. and save the *.pdf to your hard drive. HTH
Lou
Feb 10, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan Pro 42/18 gas Chain saw: The chain oil hole that feeds the upper slot seems to be blocked. Does that rubber assembly just pull out or does the whole area have to be taken apart. Is it gravity feed...
GS, there is a pump driven by the clutch sprocket/drum. Operate the engine with the bar off. There should be oil coming out.
a) If so, the hole in the bar is plugged with saw dust. This is very common on all brands of saws.
b) If not, then remove the clutch/drum assembly and inspect the worm gear drive of the pump.
*note, the threads on all chain saw clutches are Left Hand reverse threads.
Nov 13, 2009 | Poulan Pro Chain Saw 46cc 20"
What is the most likely cause of oiler not working
Several causes exist. Most likely are:
1) Clogged oil-hole in bar.
2) Clogged strainer in oil tank. (part # 530056533)
3) Unhooked pickup hose in oil tank. (part # 530038373)
4) Faulty oil pump. (part # 530071259)
Of course, check oil level and use proper bar&chain lube.
Hope this helps,
Dolf-
Oct 16, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Chain Lube Leak
It is the nature of the beast. Many chainsaws suffer from this malady. I own a bunch.
Lou
Try loosening the oil cap prior to bed.
Aug 04, 2009 | Poulan Pro Chain Saw 46cc 20"
Poulan oiler don't work
Common problem with Poulan and Craftsman gas saws. Take off the chain and chain guide and clean out all the saw dust etc. Start saw without chain and look for port where there are signs of oil. If port is clear of sawdust, then it is likely the pump which is located behind the chain break assembly. you can get the diagram on Poulan website and the replacement pump will cost about $15 - $20 to replace yours.
May 22, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Oil
The oil holes in the bar get clogged with saw dust. remove the bar and chain and run a utility knife in the chain slot and blow it all out with a compressor if you have one. if you still have no lube then its a pump problem
Mar 21, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
OILER NOT WORKING
Poulan Pro 260 LE chain saw chain bar lube system is not working.
Mar 17, 2009 | Garden
Poulan Pro 42CC 2 Cycle Chainsaw, 18" Logo
705 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
