Question about Kirby Ultimate G Bagged Upright Vacuum
Kirby sofa cleaner
How do i clean my sofa with the kirby vacuum?
  • Anonymous Nov 30, 2008
    how to put the parts on the kieby to clean the sofas
    Problem Solver:
  • 5 Answers
Hi, my name is Jon and I have an Ultimate G Kirby and have sold Kirby and the solution to this problem it is very simple. All you have to do is first disengage the belt by lifting the hood and twisting the plastic thing that says Kirby. Twist it all the way till the red arrows meet up then you will know that the belt is disengaged. Next you're going to disconnect the front by pushing the small metal lever/lock under the hood to the right and the front end should come right off. REMEMBER put the vacuum on the highest setting so this will be much easier to do. Then what you want to do is connect to hose and you will do so by connecting the hose in the same manner in which you would connect the front. There is a perch for the hose or any of the other attachments to rest their "feet" on as you will see the end of the hose is contoured to fit the Kirby in the same way the front end does. Lock the hose in place with the metal lever/lock by putting it over to the left. REMEMBER to disconnect the belt when you take off the front end and ALSO to reengage it when you put the front back on. I hope to have solved your problem, and I'll talk to you later!
Posted on Nov 26, 2007
I am shampooing a berber carpet with my Kirby Ultimate G and no excess water or suds accumulate in tray. Either while suds dial is on or off. Why do suds come out under tray in straight line no matte
Will work with:
  • Kirby G3 vacuum cleaner
  • Kirby G4 vacuum cleaner
  • Kirby G5 vacuum cleaner
  • Kirby Gsix vacuum cleaner
  • Kirby Ultimate G vacuum cleaner
  • Kirby Ultimate G Diamond vacuum cleaner
  • Kirby Sentria vacuum cleaner
  • Sentria II (Sentria2)
This is unused shampoo attachment. We buy new parts and assemble this shampoo attachment so you will be the first one to use it.
Set includes:
  1. Tray with shield
  2. Nozzle
  3. Brush roll
  4. Belt
  5. Container with cap
  6. Hose
  7. 12 oz. shampoo
NOTE - pictured Kirby Sentria shampooer box may not be included.
If you have never used this shampoo, we highly recommend reading our ONLINE MANUAL. This is a simple but very effective unit but you have to learn how to use it and "common sense" will not be enough! HOW TO - V I D E O S
Tank with soapy solution is attached in place of the bag. It utilizes the air coming out of the exhaust to blow soapy water on a small screen that turns it into thick foam. The foam is simply laid over the carpet (you must vacuum before you shampoo). Foam allows the spread of a small amount of water over the area so carpet is not soaked all the way through. Foam is left on the carpet for a few minutes so it has just enough time to moisten the fibers of the carpet and loosen the dirt (not too long otherwise foam may dry). Then foam maker is set to "OFF" and you slowly pull Kirby vacuum over the area where you laid the foam. The rotating brush in the shampooer nozzle rubs the moisture off carpet fibers and and throws it into the tray in front of the unit. You will not see gallons of dirty water but that is because you did not put it on the rug in the first place. Carpet should dry within 1-4 hours (depends how many times you laid the foam and what is humidity in the room). After it dries it has to be vacuumed. Solution that did not get picked up with the shampooer brush dries and shampoo additives do not let the dirt stick back to the fibers of the carpet. It is loose when it dries so in order to pick up what is left, you must vacuum again.
You can use any carpet shampoo sold in your local store but make sure that this is carpet shampoo that makes foam and pay attention how much you have to dilute it with water as various shampoo products come in different concentration. Avoid using "just anything" that makes foam. Some household chemicals (such as dishwasher fluid) will do great job but it will leave carpet unprotected so dirt will stick to it so well that you will have a filthy rug in no time. Kirby Vacuum Shampooer
GoodVac com
Feb 14, 2015 | Kirby Ultimate G Bagged Upright Vacuum
I need a owners manual for a Kirby G5 vacuum cleaner
Hello, this is Ava with Think Crucial.
You may find the User's Manual for your Kirby model by clicking the link below.
Kirby G5 Owner Manual
You can purchase a wide variety of high quality Kirby replacement parts for your Kirby vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for readers, use code: FIXYA10
I hope this was helpful.
Ava B.
Think Crucial Customer Care
Apr 03, 2012 | Kirby G5 Bagged Upright Vacuum
How do I change a balt on a kirby G 2000 Limited Edition vacuum cleaner
Here is a link to a video showing how to change the belt on a Kirby
Sep 08, 2010 | Kirby Ultimate G Bagged Upright Vacuum
Can I shampoo a couch?
Yes<br /> <h2 class="Heading1a Underline header"><span>Instructions</span></h2> <!-- google_ad_section_start() --> <div class="thingsYouNeed"> <h2 class="Heading5a">Things You'll Need:</h2> <ul> <li> <span>Vacuum and its hose attachments</span> </li> <li> <span>Shampoo specific to the couch's fabric</span> </li> <li> <span>Rug shampooer</span> </li> <li> <span>Steam cleaner, possibly</span> </li> <li> <span>Rag and cotton swabs</span> </li></ul> </div> <ol id="intelliTxt"> <h4 class="Heading4a">Preparing the Sofa</h4> <li id="jsArticleStep1"> Vacuum the sofa, its pillows and its cushions with the hose attachments. Do not forget the arm rests and backing of the couch. This will clean loose dust and dirt.<br /> </li> <li id="jsArticleStep2"> Dust the wood areas with a soft rag and a cotton swab for the area between the material and wood.<br /> </li> <li id="jsArticleStep3"> Find your warranty. If it is still in effect, the warranty may be null and void if you apply any cleaning solutions. Call the company for cleaning instructions.<br /> </li> <li id="jsArticleStep4"> Determine the sofa's fabric. This tag is typically found under the cushion area.<br /> </li> <li id="jsArticleStep5"> Buy shampoo specifically for your sofa's fabric.<br /> </li> <li id="jsArticleStep6"> Rent a rug shampooer.<br /> </li> <h4 class="Heading4a">Cleaning</h4> <li id="jsArticleStep1"> Assemble the shampooer according to its directions.<br /> </li> <li id="jsArticleStep2"> Test a small area of the sofa. The best place may be the back of the couch or under the couch if possible.<br /> </li> <li id="jsArticleStep3"> Clean the entire couch. This will prevent watermarks.<br /> </li> <li id="jsArticleStep4"> Allow it and all its parts to dry before reassembling the cushions and pillows.<br /> </li></ol> <div style="overflow: hidden; color: rgb(0, 0, 0); background-color: transparent; text-align: left; text-decoration: none; border: medium none;"><br /></div><br /> <!-- from fixya rte -->
Jun 12, 2010 | Kirby G6 Bagged Upright Vacuum
How do we change the belt on our Kirby Vacuum Cleaner
Here is a link to a video explaining how to change the belt on a Kirby vacuum. It is at the bottom of the page
Jun 02, 2010 | Kirby Heritage II Vacuum
Do you have to use kirby cleaning solutions or can you use another form of carpet cleaner to clean and shampoo my carpet?
You should always use Kirby Shampoo.Other shampoos have abrasives in them,which could clog the tank,or ruin the bearings at the end of brushroll.
Oct 09, 2008 | Kirby Vacuums
Kirby Sentra vacuum burning belts
Generic problem for all Vacuums
posted by campoclan on May 02, 2008
Have had Kirby vacuum for a couple of years since I've had it I burn at least two belts in two months. I keep roller clean, what is the problem?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Some of the problems that people have is that they feel they have to have the vacuum head all the way to the floor and that makes the belt work that much harder. The key to the best cleaning is to raise the height adjustment all the way to the top and once it’s there then drop it down one notch or setting @ a time until you here the tone change. Then try it to see if the vacuum if picking up well if not drop it down one more notch and that should be the setting it is supposed to be for your type of carpet. And remember to use the genuine Kirby belts instead of the Kirby replacements, they will work better. And your suggestion that to keep the brushroll clean and free spinning on each end and also keep the bottom plate clean of dirt and grease because if there is a build up it will move slower and leave black marks on the carpet. I hope this will help and if not contact your local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions. Customer Service – United States & Canada 1-800-494-8586
Hours 8:00 am to 5:00 pm (EST) U.S. & Canada Fax # 1 (216) 529-6146
Mail To:
Consumer Relations
The Kirby Company
1920 West 114 Street
Cleveland, OH 44102
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 02, 2008 | Vacuums
Kirby Ultimate G Bagged Upright Vacuum Logo
145 people viewed this question
Top Kirby Vacuums Experts
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
