Question about Vulcan EF3 Deep Fryer
Fryer work for few seconds and down - Vulcan EF3 Deep Fryer
    Sergeant:
  • 270 Answers
Change the temperature settings in it.
Posted on Jul 16, 2009
How do i get the pilot light to remain lit on my new SLG100 Anets deep fryer
Did you hold the pilot light button down long enough? It takes between 20 seconds - 1 minute to properly heat the thermistor before you can turn the switch to "On".
Mar 04, 2016 | Anets SLG100 SilverLine 100 lb Commercial...
Deep fryer won't melt. or warm up the oil
Faulty switch or heating element replace the faulty part if possible or replace the fryer.
Mar 03, 2016 | Vulcan Kitchen Appliances - Others
We have a yellow flames
There are few things which causes fryers to produce yellow flame on burners. First- Low gas pressure and volume, second- carbon or soot formation on burner face and heat tubes. Check first if your fryer has one of these conditions and try to address this as soon as possible.
Apr 29, 2011 | Pitco Frialator Kitchen Appliances -...
When placng seafood in fryer at work a foam quickly forms and rises to the top of the fryer. What's causing this and how can I change this?
The seafood contains water, the water reacts with the oil and causes the bubbling.
Try placing the seafood onto some absorbent paper for a few minutes before adding it to the fryer.
Or try dunking it in to seal it for a few seconds before you fry it off
Jul 20, 2009 | Pitco Frialator 45C Deep Fryer
Comercial deep fryer pilot light goes out
This problem could be caused by a few different things. You should check the condition of your pilot and the thermocouple, if the pilot is weak due to being dirty you will not generate the optimum Millivolts to run the fryer, you may need to dissassemble and clean the pilot. The thermocouple needs to be correctly placed in the pilot assembly, if it has dropped down to where it is not in the flame it will not work correctly. You may need a new thermopile as it may not be generating millivolts as needed. Gas pressure can cause this as well, if the pilot goes out then the main burners come on you should check the gas pressure. One more thing to check is the hi-limit thermostat, if this is cutting out early your pilot will go out. Imperial uses a self-resetting limit, after a few minutes your fryer will relight and work until if cuts out again. If your fryer pilot stay on with the thermostat off for long periods of time and does not go out immediately when the burners come on and the pilot is clean, you may need a hi limit. This is a lot of info, I hope it helps.
Nov 29, 2008 | Imperial IFS50 Deep Fryer
Imperial fryer IFS-40
I had a very simular problem. My fryer would do exactly as you described, but sometimes the pilot light would stay on until the burners tried to re-ignite and then it would go out.
I finally had to call the gas company. They took the pilot light apart and cleaned it. The fryer works perfect now.
Hope this helps!
Ken
Oct 18, 2008 | Imperial IFS40 Deep Fryer
GAS VALVE TIMING OUT
I had a simular problem. The gas company disassembled the pilot light and cleaned it. The fryer works perfect now.
Hope this helps!
Ken
Oct 08, 2008 | Imperial IFS40 Deep Fryer
Model 1068 fryer - euro-pro
You have to make sure that the control panel slide rails are correctly inserted.
I was very frustrated, and considering I did not have the packaging/receipt, was ready to toss. My Wife slid the control panel/elements out off the pan, then back in, voila!
Mar 27, 2007 | Euro-Pro F1066 Deep Fryer
Vulcan EF3 Deep Fryer Logo
109 people viewed this question
Top Vulcan Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Treefrog15
Treefrog15
Are you a Vulcan Kitchen Appliances - Other Expert? Answer questions, earn points and help others
