When trying to make copies it often puts out blank pages. It is not complaining of low toner.
  • spearsn540 Jul 17, 2009
    No its putting thru one at a time. The first sheet often comes out clear and dark enuf to read well. The next one is off a bit, and if you choose to print say, 5 at a time, it prints ONLY the 1st perfectly, the others will print lighter,[ especially any picture portions, they are worse, the print is better].
  • Rostra May 11, 2010
    Is it just putting through two sheets at once, and you only notice the blank pages when you pick up all the copies, or is it actually spitting out single blank sheets?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 118 Answers
Check your developing unit whether it is lock in right position or not
Posted on Jul 16, 2009
WHEN COPYING OR RECIEVING FAXES THE PAGES ARE BLANK. TONER STILL HAS SOME LEFT IN IT. Is this a bad drum?
Could be or the toner is to low to pick up. DR-200 drums only have copie live of around 9 thousand copies. Hope this helps
Aug 13, 2010 | Brother IntelliFAX 2600 Fax
Canon NP4050 putting out blank pages
The NP 4050 has been known for given blank copies... Is the developing unit locked in place... There is a Grey or blue lever inside the front door to the right... It is under the toner hopper. It's been along time... I believe the lever should be clicked to the right and up. Also there is a locking screw that holds it in place, Most times that screw is missing and the unit falls away from the drum unit and you get blank copies and the front door will close.. Good Luck
May 01, 2010 | Office Equipment & Supplies
The printer runs properly but will not print; A blank page cycles
It is not the toner. There are 2 things you can try yourself, anything else requires service. First try opeing and closing the right hand side door. Try this several times if necessary. There are contacts in this door that sometimes don't make contact and opening/closing the door will sometimes resolve blank copies. The other thing you can try is remove the toner then pull out and reseat the drum unit. Here again there are contacts that need to be made that can cause blank copies.
Good Luck and Thank You for using Fixya.
Apr 09, 2010 | Sharp AL 1631 Copier
Received blank pages. Could this happen if the
Make a copy of something to be sure. It will tell you when you are low on toner
Feb 04, 2010 | Brother IntelliFAX 5750e Laser Fax
I changed my toner cartridge today and now it's not copying
Having 2 (defective?) cartridges that behave in exactly the same way seems too unlikely to me. So I have to ask the obvious question....did you pull the seal to release the toner? If it's an original there should be one, if it's remanufactured, there may or may not be one on it.
Jun 20, 2009 | Canon Office Equipment & Supplies
Konica Minolta PagePro 1350W laser printer. Have
your carteidge OPC duram is faulty .
so change cartedige
Apr 25, 2009 | Konica Minolta PagePro 1350W Laser Printer
RICOH MP3500
maybe theres no developer in the machine
Nov 10, 2008 | Ricoh Office Equipment & Supplies
Magicolor 2530 DL
The streaks are typically a sign of a toner drum going bad, or possibly just dirty, or even caused by the toner being low, as you have mentioned it to be. 1 way I know to 'clean' the drums is to have the printer run multiple blank pages. If your software will not allow you to print blank pages, type a single character by using this little trick, hold down the ALT key, and type 2 5 5 on the number pad in a blank text document. This will allow you to print the "blank" document, I would suggest about 10 copies. This should help for a short duration, and doesn't use any toner.
Hope this helps!
Backu
Oct 30, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Blank Copies
The Unit where you've put the toner cartridge could be to far from the drum. Make sure your developer unit (unit where you've put the cartridge in) is locked in place.
Mar 14, 2008 | Canon NP 7130 Black and White Copier
43 people viewed this question
k24674
