Question about Lanner FW 500 (FW-500) Firewall
HW reset FW500ME to factory default
I have firewall FW500 with MikrotikOS and I forgot admin password. Can You help me please? I need known what jumper on contact will be switch on for reset settings.
thanks
Vlada
  • vs99 Jul 18, 2009
    Thank for Your idea, but I have FW500ME and this box not have reset button. :-(
    Sergeant:
  • 173 Answers
Press it's back side you find reset button press it for 10 seconds then all settings are reset to defaults.
Posted on Jul 16, 2009
How can I reset my I'd username and password?
If admin page allow to create another user account, go ahead to add a new user with known password.
Otherwise, reset to factory default is the only way to remove the password (reset the password).
Be sure to back your configurations before doing factory reset because factory reset will erase everything you have set.
Oct 01, 2014 | Computers & Internet
Xirrus XN4 forgot password
To reset a Xirrus Array to factory default:
Connect to the console with Putty via Serial - Setting the Baud to 115200.
Power cycle the Array and watch the boot sequence very carefully. Press Spacebar access bootloader
Use the default UN/PW: admin/admin
- You should be at an XLB> prompt
-Type 'env reset' and press enter
Array will reboot and all settings should be back to factory default.
Nov 09, 2012 | Computers & Internet
How to change password for linksys E1200
If you are able to log in then go to administration and you will find an area there to change the password. If you are unable to log in because you forgot the password that you set you will have to do a factory reset by pressing the reset button for more then 10 seconds. This resets the router back to default user/password of admin/admin or admin/password
Jul 08, 2012 | Linksys E1200 Wireless Router - Ieee...
I forgot the password for the 192.168.1.1 page what do i do
Please do the following.
1. If you have changed the default password you will have to reset router and the password will be set to the default password. To reset the router to factory default keep the reset button pressed for 15 seconds while the router is powered on the reset button is located on the back of the router inside a small hole which needs to be pressed using some pointed object like a pen or a pin.
NOTE** its importaint to note that if you reset the router to factory defaults you will lose all the configuration and you will have to reconfigure the router***
2. if you have not reset/ changed the password ever try using the following user name and password
username password
admin admin
system admin
root root
admin
System
root
Aug 18, 2011 | Gateway Wireless-B Router (wbr-100)
I forgot my Password for NETGear WGT624 Please help
Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
or
if there is a small hole in the front or back of the router push a hair pin in to reset to factory settings
hope this helps
Jan 17, 2011 | NetGear WGT624 Wireless Router
I forgot my netgear modem router password
If you have changed the default password, you need to reset the router to the factory settings to get in with the default user and password (user admin and password as password, or if that doesn't work try 1234). Note that you will lose the ISP settings and wireless settings when you reset the router.
Here's a video on how to reset the router to the factory default settings: http://kbserver.netgear.com/media/flash/training/Troubleshooting/NG_WGR614V9Router_TS_LostPassword.html
Dec 25, 2010 | NetGear : DG834G 54Mbps Wireless ADSL...
I am a admin at a new company and they do not know nor can they find the Admin login and password. Is there a way to hack in to the SonicWALL PRO 230 Firewall unit?
Deafault user: admin
password: password
default ip: 192.168.168.168
if in case you cannot get in, you need to reset the device to its factory default.
thanks
eric
Oct 29, 2010 | SonicWALL PRO 230 Firewall
Cant login never had username or password if i did i forgot
Depending on which revision you have there are two possibilities
Default Username is: admin
Default Password is: password
or
Default Password is: admin
If neither of these work - you may have setup a new username and password and forgot - on the router you will see a reset point - reset the router to factory defaults and the username and passwords above will now work.
If this helped you then please help me and vote kindly, thank you.
Oct 14, 2009 | NetGear WGR614 Router
Change router password forgot it
you can reset the router. Configuration will be reset to factory defaults : Web address 192.168.1.1 ; username: admin; password : admin
Hope it helps.
Sep 26, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Forgot password to add new computer to router
Hi!
Press the reset button for 10 seconds. It set the factory default
settings. The router will erase all information, the DSL settings too.
After that you can login in with the default password, via web
interface:
http://192.168.1.1
username: admin
password: admin
The default username and password is admin/admin.
I hope it hekos.
Jan 09, 2009 | Linksys Wireless-G WRT54G Router...
Lanner FW 500 (FW-500) Firewall Logo
223 people viewed this question
Top Lanner Computers & Internet Experts
David Payne
David Payne
Are you a Lanner Computer and Internet Expert? Answer questions, earn points and help others
