Hello sir, i am using a electrolux-eaw18crp window ac..te problem is ..whenever i turn on my ac...all lights are on,but no air blows,neither fan works nor the compressor..i dont know wats wrong..can u please help me or give a easy solution...because i am scared of opening the ac...
  • 534 Answers
Sounds as if there is an electrical short at the on off switch. Would recommend having a qualified tech look at unit. Good Luck
Dave
Posted on Jul 16, 2009
We understand that your problem is: I have an Electrolux PLHS267ZCB4 refrigerator that has an intermittent cooling problem. The compressor works, but the fan does not blow the air across the coils....
Hello, Thank You for using FixYa. I will be helping you today.Find out if the new updated revised board was installed. Was it the board on the back of the unit? If so there is a new board available to fix this.I would have them come back out and verifify the updated version to make sure its the newest one.
Thank You and please rate my answer if it was helpful..
Jun 12, 2011 | Electrolux Refrigerators
I have a 2006 elantra and whenever i slow down or stop the needle goes into the red zone and the a/c blows hot air. when i drive faster again the needle goes back to normal and the a/c blows cold air...
your electric fan for the AC is not working for whatever reason so when idles its all getting hot the engine and the AC system .This sort of work can be difficult to diagnose correctly and a code reader is about as good as a bible at mosque so seek the advice of a skilled mechanic who should be able to pin point the fault in seconds
May 30, 2011 | Hyundai Elantra Cars & Trucks
The air comes on and blows, but the fan outside doesn't spin....tho the air feels a bit cool, the apt never cools off
hello, if the compressor is running and yet the condenser fan motor is not most likely you have a bad capacitor to the fan or if it's a dual capcitor the fan side is bad. Another possibility is the motor itself could be shot but you would need a meter to check. with the power turned off and take you meter and put one meter lead to the ( common) wire and take the other meter lead to each additional wire coming from the motor one at a time, if you dont have resistance between any of the wires then the motor has a open winding and should be replaced.
Apr 26, 2011 | Weather King 10AJA2501AH Air Conditioner
Our window AC/heat unit fan only buzzes when turned on- no matter whether you turn on fan only or heat or cool mode.
so the fan does not spin and blow air? it could be a stick broken fan try free spinning it make sure its turned of. if fan spins freely its probably your start capacitor which is not to expensive.
Nov 10, 2010 | LG Heat cool Window Air Conditioner
Ac doesent blow air
If the fan is not working,then the fan motor is bad,or the start capacitor is bad.Pull the unit out so you can work on it,near the plug in.Be carefull,and use a stick,backscratcher,or something like that.Turn the ac on to cool,high blower,and turn the fan bladeclockwise to see if it will try to start turning on it`s own.Careful not to gouge the coils,and try to turn the fan reall good.If it starts,let it run,for about 15 minutes.If the fan,does not quit,then replace the start capacitor.If the fan wont start turning on it`s own,or the fan stops after a while,replace the fan motor.I hope this was some help.
Oct 06, 2009 | Frigidaire FAH106N1 Wall/Window Air...
Groaning Noise While AC is on
this sounds like the AC compressor is failing, the engine idles slower in drive so noise is more apparent. you are likely going to need to replace it soon.
Jul 23, 2009 | 2007 Suzuki Forenza Sedan
Air conditioner is not blowing cool air, but fan still blows
check the compressor with the ac running and make sure the compressor is kicking in and out in not the compressor might be bad or te clutch on te front of te compressor, sometimes u can get to much freon in them to i did it ounce
May 30, 2009 | 1998 Cadillac Eldorado
Hello, I have a Kenmore 580.75124500 ac/heater
It is probably the compressor. You will need to check if the compressor is being called to come on. Do you hear the compressor running? If you do, I would remove the unit from the wall or window, and wash it down real good with a hose being careful not to get the electronics wet. If not and the unit sound different than it did before, it's probably time to buy a new one.
Mar 31, 2009 | Frigidaire FAC125P1A Window Air...
My oven isn't heating up. Te fan works and the grill and the light comes on but no heat for the oven
it turned out it was the circuit breaker. The burners worked but not the oven.
Jul 19, 2008 | Electrolux Heating & Cooling
Heating & Cooling Logo
67 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
